Hmmm..........sometimes my level of stupidity amazes even me......The 12 engine nascelle halves for the gigant, are, in fact, numbered on the inside. So you attach 1 to 1, 2 to 2, 3 to 3, etc. To eventually end up with the six engine nascelles.
Ie: each nascelle is different, to allow for the different thickness of the wing the farther away you get from the wing root. Doh! I got some sanding and filing ahead of me, for sure. Cardshark, be warned ! (I know you wont make the same mistake as me anyway)
This is the first multi-engine kit I've made where the engine nascelles were not moulded as part of the wings (ie: you construct the engine and then attach it to the wing)
You can see the size of the beastie compared to a 1/48 Superfortress. Something tells me the Gigant will only ever be a 1/72 kit, a bit like the B-36 or B-52. Anyway, back to the bench.
Paul.
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it" -Norman Bates
