Ok, time to post pics of my sorry WIP. "Modern Submarine Series", ARII, 1:700. In short, do NOT buy these kits! So bad at many levels...
I started with the Japanese set of moern subs:
First thing, BOTH kits are EXACTLY the same, down to the Japanese words etched on the sprues. Seems what they did was to pack the same sprues in 2 different boxes with 2 different decals. Oh well.
You are given TWO subs per box, one full hull, one waterline. You are also given a "base" and a cheesy plastic "water" mockup, in case you want to display them au natural:
Construction is, well, 7 pieces, of which NONE fit. Detail is massively offscale (very big). The con tower has an extra set of holes:
Yes, a hole to put in the "water wings", an extra one to... ??? there is an extra "stick" (instructions unclear), maybe another mast thats inserted into the extra hole? if that is the case, the width of the "mast" is about 20-50x too large. I solve the issue by using that extra "mast" to plug in the extra hole, snip, and fill with tamiya liquid primer:
I also "scratchbuilt" (lol) some extra masts. The propeller is also off-scale (too thick, too large). Why did I bother finishing? I am using these ARII subs as experiments, testing various liquid putties and combinations of black/red modern submarine painting. never knew there were so many shades of black and anti-fouling red.
Cheers, james
