Ok, as promised Andrew here's what I'll be building for this GB.
The kit will be the great 1/48th Tamiya P-51D. I've built this kit before and it almost falls together. Probably 3/4 of the kits in my stash have some measure of AM accessories and this one has quite a bit although most of it is minor. I'll be adding Ultracast exhausts, props and spinner, wheels, flaps, and seat; Eduard canopy mask and interior PE set; Eaglestrike decals and one other item of note which I'll get to in a sec.
The markings will be of this aircraft.
Sharp-eyed observers will note this particular aircraft is a filletless P-51D. The Tamiya kit is a filleted P-51D.
There are several aftermarket replacement tails to build a filletless P-51D, but I decided to try something that had come out about a year or so ago. I'll be using the Loon Models resin replacement filletless fuselage.
It's an entire drop replacement resin fuselage for the Tamiya kit. I'm pretty interested to see how well this works.
I'll get a start on this after the holiday.
Cheers
