WIP Tamiya Sherman
    January 2007
WIP Tamiya Sherman
Posted by claudez on Sunday, May 3, 2009 3:12 PM
     OK Here is my Tamiya Sherman 1/35.. Still have to load it up with gear, washes, pick out fine details etc.. As always criticisms and comments especially helpful and welcomed..Model is airbrushed with MM olive drab, tracks are MM rust with powdered graphite and pastels for details..
Posted by Tojo72 on Sunday, May 3, 2009 3:49 PM
 claudez wrote:
     OK Here is my Tamiya Sherman 1/35.. Still have to load it up with gear, washes, pick out fine details etc.. As always criticims and comments especially helpful and welcomed..Model is airbrushed with MM olive drab, tracks are MM rust with powdered graphite and pastels for details..
Looks pretty good so far,Ilike the dusty,faded look, any self respecting sherman will have lots of stowage,looking foward to the finish.
P.S
 Someday I would like to convert one of these to Odball's tank,I have the figures in my stash.
    June 2007
Posted by satisfaction on Sunday, May 3, 2009 4:59 PM
Like the fading.  Did you use different shades of the same green or is there a reddish brown thinly sprayed in there?  Nice effect and would like to know what you did!
    January 2007
Posted by claudez on Sunday, May 3, 2009 6:02 PM
Thanks. The fading of the national insignias was just misting Model Master ANA Dark Earth ( RAF color) over the stars with the airbrush so that they were not 'shiny and new" . I also used MM rust airbrushed at a fine setting for the marks and highlighted with medium grey pastels. The machine gun barrels were painted flat black and then polished with graphite on a cotton swab.
    February 2009
Posted by model man on Sunday, May 3, 2009 6:45 PM
looks great . i'm in the process of finishing one myselfPhotobucket[img]http://Photobucket[img]http://Photobucket" border="0" />[/img][/img]
Posted by T26E4 on Sunday, May 3, 2009 8:46 PM
Nice job so far.  One thing to note: the tracks you have on this are the T-48s which were mostly rubber -- does that change how you want to finish them?    They look fine as is but know that they weren't all metal tracks.
anthony2779 : as for making Oddball's tank, go here:
from http://www.formationsmodels.com/
Roy Chow
Join AMPS!
http://www.amps-armor.org
    July 2006
Posted by constructor on Sunday, May 3, 2009 9:54 PM
Nice build. I like the subtle weathering which is also how I weather my models. The Tamiya Sherman although quite old is still a pleasure to make.
    August 2005
Posted by Phil_H on Sunday, May 3, 2009 11:39 PM
Hi Claudez,
The overall finish is great - I love the subtle weathering. Thumbs Up [tup]
Please don't take this as a criticism, but the legs of the headlight brush guards and lifting rings could use a little attention, as the mounting holes are quite apparent. A few applications of Mr Surfacer or Tamiya Liquid Surface Primer applied with the point of a toothpick will do the trick.
Posted by Tojo72 on Monday, May 4, 2009 6:00 AM
Thank-you sir,I have been aware of that set,but way more then I want to spend now,but maybe some day.
    January 2007
Posted by claudez on Monday, May 4, 2009 7:32 AM
Phil_H   Thank you for your astute criticism. I hadn't noticed, but now that you mentioned it , it is painfully obvious that they aren't seated correctly. I haven't used Mr Surfacer yet.. not sure if it can still be found in the States. When I start loading up the tank with stowage items, tracks, bogies, crates, wood, etc  hopefully some of this will be obscured. I may go back and try a little liquid cement and a stiff short bristle brush to eliminate the marks. Thanks for noticing.. Its the only way our skills can improve.
Claude
    January 2007
Posted by claudez on Monday, May 4, 2009 7:38 AM
  1. Model Man  Very nice.. what color did you use for the overall? I especially like the subtle weathering of the hull.
    April 2005
Posted by wing_nut on Monday, May 4, 2009 7:40 AM
Claude it looks great.  you should find the Mr. Surfcaer. My LHS has it in stock.
Marc
    August 2005
Posted by Phil_H on Monday, May 4, 2009 7:58 AM
Hi Claudez,
It's uncanny the way the camera can pick up something that the Mk.1 eyeball can miss. Many a time I've taken photos, only to find a gap or mould-line in plain sight that I've somehow missed. I'm sure you'll find a suitable solution. Mounting strategically placed stowage was another thought that I had considered and I thought that you may also have plans to do the same. Smile [:)]
    February 2009
Posted by model man on Saturday, May 9, 2009 12:09 PM
I used tamiya olive green with some dark yellow and white added. I mixed it until I liked the shade. I sprayed it overall with thinned mars black oil paint in these photos. I will post completely finished photos soon. Thanks for the compliment.
    February 2009
Posted by model man on Saturday, May 9, 2009 11:11 PM
here are photos of my finished Sherman. I am wait for a stencil set for markings.I had alot of fun with this finish.Photobucket[img]http://Photobucket[img]http://Photobucket[img]http://Photobucket[img]http://Photobucket" border="0" />[/img][/img][/img][/img]
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Sunday, May 10, 2009 12:51 AM
Aw heck, wish I had  caught this before you painted.....
http://tbn0.google.com/images?q=tbn:-Z8AQFjXh78ntM:http://www.usarmymodels.com/AFV%2520PHOTOS/M4%2520SHERMAN/M4%2520Sherman%2520Left%2520Turret.jpg
see how the pistol port is faired in.
Great finish!
http://www.innovationbyinstinct.com/services/hosting/clients/accountyp/status/DisasterMaster/%23t1-4.jpg
 https://i.imgur.com/LjRRaV1.png
    July 2006
Posted by redleg12 on Sunday, May 10, 2009 5:18 AM
Claude - Nice work. Great job on fading the markings.
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    November 2004
Posted by spacepacker on Sunday, May 10, 2009 8:51 AM
Very nice looking, I'm glad some Sherman's have been posted.
Good reference for me, a Sherman is my next build...Kenny
    January 2008
Posted by Bodge on Sunday, May 10, 2009 10:40 AM
Looks greatThumbs Up [tup]
