Moving on to the body. Before any assembly on the body, which is a one piece cast, has to be cleaned up including cutting out the excess resin from all the window areas. The first assembly to the body is to glue in the front grille in place.
Next is to complete the front adding the bumper, tow hook holders the PE Chevy logo and the PE bridge marker plate. On each side the base for the rear view mirrors and the door handles. Let me just say the door handles are a PITA to remove from the pour block without breaking
In the rear, the bumper and tow hook holders. Also the PE rear window handle and license plate cover. With the PE cover added, the PE bolt plate and resin tow hook can be added.
The rear bumper on the M1009 has 4 bolt heads, which are not on the kit bumper. I used some PE rivet heads to add these to the bumper.
The kit includes an antenna mounting bracket in PE. This bracket is for a full size antenna for the RT-524, which I mounted in the rear. I went into my PE spare parts to find the PE to fabricate the smaller bracket for the short antenna used on the R-442. With the antenna brackets in place, the kit includes PE antenna wire grommets. One is mounted above each antenna mount on the body.
That’s it for now. The body is off to the paint shop.
As always feel free to leave a comment either positive or negative
Rounds Complete!!
