Panther Pillbox Questions.
    January 2005
Posted by fantacmet on Sunday, December 28, 2008 10:48 PM
I know the panther turret was used in pillboxes, but what I want to know is, how different were the turrets on the pillboxes from the ones on the tanks?  Also did the ones on the pillboxes have zimmeritt?
Also some photo's of the pillbox itself so I can build it(I already have the turret), would be great, of course from what I can see some of them are under ground, and that may be a good way to do it, is to bury the box itself under the ground.
    December 2008
Posted by psstoff995's lbro on Sunday, December 28, 2008 11:21 PM
here are some pictures I found of some Panther pillboxes, looks like most of them were built under city streets. And the second picture has zimmerit so, to answer your question, yes, at least one does...
Sorry, if that takes a while to load, I found a few pictures. Big Smile [:D]
Good luck, and I hope that I helped
-Will young modeler Test fit master
Posted by T26E4 on Sunday, December 28, 2008 11:44 PM
They weren't built into city streets.  The Panther Turm stellung was a complete component, sometimes using derelict turrets (the first and 4th pics show an ex-ausf D turret), sometimes getting them fresh from the factory.  Some had the production cupola, some had a replacement hatch.
It was a turret mounted on a huge box.  In the pics above where the stellung is in a street, it's literally IN the street.  A hole was dug out and the huge box and turret were emplaced. You see some where the box was completely flush with the ground, in the last two pics the box was raised a bit because its hole wasn't as deep and debris strewn to cover it.   HTH
Roy Chow
Join AMPS!
http://www.amps-armor.org
    January 2005
Posted by fantacmet on Monday, December 29, 2008 1:10 AM
This is absolutely PERFECT!!!!!  Now when I built it with zimm on the turret(I don't feel like removing the zimm), and someone whines about it not being accurate, I can show them the pic.  WOOHOO.  I think in order to get around building a nicely detailed box though, I'll bury it much like those were.  This is GREAT.  Now I gotta think of a setting.  Perhaps some figs standing around, maybe some sangbags and a machinegun emplacement.  Hrm....
Posted by T26E4 on Monday, December 29, 2008 2:14 AM
Not an MG emplacement.  The turret would have had a wide field of fire.  You wouldn't want to be set up near it.
Roy Chow
Join AMPS!
    January 2005
Posted by fantacmet on Monday, December 29, 2008 2:25 AM
Yeah thats true enough.  Getting ahead of myself here.  Any idea's?  I've got a German officer fig with a matching motorcycle I could work in there somehow.  The turret doesn't have an interior, and I don't plan on putting on in.  I think it has a rudimentary breach.  Which I suppose might be enough, if I put a platform in it and plop a figure in there to fill up the hole.
Posted by tigerman on Monday, December 29, 2008 2:50 AM
Many were in Italy and undoubtedly sans zimmerit. Your Choice.
 Eric
    January 2005
Posted by fantacmet on Monday, December 29, 2008 4:14 AM
Well no matter what I do I can't get zimm to to match up to the PE zimm that's on it for the pieces that are missing.  So I am thinking use the turret on a pillbox, and "burn out" the hull.  I found a pic of a Panzer IV today, that is completely stripped out.  No engine, no bulkheads, no interior, nothing.
    September 2005
Posted by Kykeon on Monday, December 29, 2008 1:57 PM
Not all of the photos posted above are of Panther turret pillboxes, the last two are whole Panther wrecks, dug into the street, with dirt and cobblestones piled around the hull.
Trojca's Panther Variants in Color has 5-view scale drawings of a Pantherturm Stahlunterstand.
Another book on the subject is Tank Turret Fortifications by Neil Short, 224 pages with 200 black & white photographs and diagrams. ISBN: 1 86126 687 1.
There was also a Panzertracts publication on Pantherturms, but it must be out of print, as I can't find it on their website. As I recall, it also described Pantherturms on concrete and even wooden platforms.
Osprey's German Defences in Italy in World War II has several photos, including the cover, plus a full color, cut-away diagram of a Panther turret pillbox. Many of the Pantherturm in Italy had 1-meter thick concrete collars around the steel box as added protection.
Here are a whole pile of photos, including some plans;
http://forum.valka.cz/viewtopic.php/p/59008
    May 2005
Posted by terry35 on Monday, December 29, 2008 7:43 PM
Found this one if its any use to you. Seems quite modern but seems to have a either an MG spot to the side, could also just be the door. But the Hatch is interesting, probably from the Hitler or Gothic lines in Italy. As I look closer the hatch seems to remind me of one from a lang or similar, the turret roof looks custom built for this item......well If I had a spare turret I know what i'd be doing right now.
Terry.
Posted by tigerman on Monday, December 29, 2008 8:17 PM
Great picture Terry. Great field of fire over that parking lot. LOL Appears to be a tank in the background also.
 Eric
    May 2005
Posted by terry35 on Monday, December 29, 2008 8:25 PM
Spotted that, When I said modern I meant painted and maintained, I wonder if the barbed wire is original , looks badly corroded. The car in the back ground kinda looks like a former east european YUGO, or a VW golf or polo, but the red looks YUGO, just trying to place it.
I personally only know of these devices being used in Italy and Berlin, wonder if they turned up in other places?
German fortifications are a pet interest of mine, the Flak towers in berlin facinate me.
Terry.
    April 2008
Posted by smeagol the vile on Monday, December 29, 2008 8:29 PM
As was said earlier, the panther turret pillboxes were not the tank burried in the ground, they were bunkers built with a turret installed on the top of it, those things with the tank burried in the street, or just the turret sitting in the grass, are not it.
    May 2005
Posted by terry35 on Monday, December 29, 2008 8:37 PM
She's not sitting on the grass, check out these other shots, and note that there is a hill behind her.
http://images.google.ie/imgres?imgurl=http://www.krawa.info/panther2.JPG&imgrefurl=http://www.krawa.info/Museen/Pantherturm/pantherturm.html&usg=__1SPyfnczfhbxC2WD8ALBtdBp5E4=&h=986&w=1512&sz=185&hl=en&start=15&sig2=IT50V9-O_zx1pVFyvfo1cg&tbnid=aq8TiBsaEUVyeM:&tbnh=98&tbnw=150&ei=2IhZSa7XJsqQ-ga08e26Dw&prev=/images%3Fq%3Dpantherturm%26gbv%3D2%26hl%3Den%26sa%3DX
 and this
 http://images.google.ie/imgres?imgurl=http://www.orasoft.net.pl/~leszek.ch/e_pt4.jpg&imgrefurl=http://www.orasoft.net.pl/~leszek.ch/e_pt.htm&usg=__U2541SjTrWGSWSINL6SJW11-IJw=&h=328&w=500&sz=35&hl=en&start=7&sig2=tam-XdwQO_qdc_yfj6mVvw&tbnid=ilQFSUnHBgLB2M:&tbnh=85&tbnw=130&ei=2IhZSa7XJsqQ-ga08e26Dw&prev=/images%3Fq%3Dpantherturm%26gbv%3D2%26hl%3Den%26sa%3DX
 http://www.nahverteidigungswaffe.de/index2.htm?http://www.nahverteidigungswaffe.de/GermanVeh/Regelbau687-01.htm
 She is in Germany.
Pretty cool, just an image search.
Terry.
    May 2005
Posted by terry35 on Monday, December 29, 2008 9:00 PM
Really just check out these absolute GEMS, no other way to put it, theres even busted ones with interior "bits" well whats left.
http://images.google.ie/imgres?imgurl=http://i153.photobucket.com/albums/s236/miloslavhrabec/Pantherturm%2520auf%2520Stahlunterstand/pantherturm-1.jpg&imgrefurl=http://forum.panzer-archiv.de/viewtopic.php%3Ft%3D6068&usg=__A9XnP-TOo43SriHqr-VktVPcS7k=&h=800&w=664&sz=89&hl=en&start=57&sig2=gBY6jJUpD_NkUYDjuRd2gA&tbnid=fuSsRu3yGScndM:&tbnh=143&tbnw=119&ei=O4xZSeHNI4eQ-gaNs6DIDw&prev=/images%3Fq%3Dpantherturm%26start%3D40%26gbv%3D2%26ndsp%3D20%26hl%3Den%26sa%3DN
 I think these are what we were looking for all along. Well Goodnight to all. Its 3am here in Ireland.
Terry.
    April 2008
Posted by smeagol the vile on Tuesday, December 30, 2008 1:20 AM
Cant give you a difinitave answer, but I can guess, panthers had a great anti tank cannon, and I can only speculate that they put the turrets on the bunkers for anti tank, so, why not use the best?
    September 2005
Posted by Kykeon on Tuesday, December 30, 2008 1:33 AM
Many different turrets were used to make this type of fortification. Obsolete tanks were often used for this purpose. Captured French tanks were commonly stripped of their turrets for this use and their chassis used for SPGs or artillery tractors. Panzer II, III, IV and Panther turrets were all used. Panther turrets in particular were favored for their heavy armament and armor protection. Some were taken from wrecks, others were purpose built, with thicker roof armor and a simplified hatch and periscope.
Posted by T26E4 on Tuesday, December 30, 2008 1:33 AM
Lots of French 37mm armed turrets taken from tanks captured in '40 appear on Atlantik Wall fortifications and other locales.  I've seen Pz 38(t), Pz I, Pz II, Pz III turrets too.  I'm sure whatever was workable probably found a 2nd life
Roy Chow
Join AMPS!
