1/6th scale Early Production M4 Sherman
    September 2003
Posted by Daywalker on Monday, September 7, 2009 5:02 PM
Man, this thing looks just like the real deal- my hat's off to you on this one. Bow [bow]
Frank
    April 2005
Posted by armourguy on Thursday, September 10, 2009 7:49 PM
I applied the tank's pattern and markings. All markings are hand painted. The model is ready for the next step.
    December 2008
Posted by psstoff995's lbro on Thursday, September 10, 2009 8:13 PM
Excelent! Great work armorguy. Great work on the camo.
Is "Dynamite" a custom marking or of this actual tank?
-Will young modeler Test fit master
    April 2005
Posted by armourguy on Sunday, September 13, 2009 11:12 PM
Thanks, Dynamite is my own creation. The tank is now 95% complete. All that remains is to install the tools and turret mounted M2HB 50.cal
The tank weathering was completed, the fire extinguisher box handles, and grease fittings were all painted red, the tail lights were painted along with the insulator for the MP-48 aerial base.
The mirrors were installed into their frames. As a side note, the side view mirrors were used for transport driving. These parts would be prone to damage so when in battle these would be stored in side the vehicle.
On the tank's copula I installed a Panzerwerk periscope and periscope mount. To fit the periscope mount I had to modify the stock panzerwerk piece. To make the part fit I simply removed the base plate and installed.
The other periscopes were also painted and installed.
A panzerwerk Bow 30. cal and 30.cal barrel was added.
The tank's tracks were also assembled and installed. The original Viper came with a set of Plastic T48 Rubber chevron tracks. The problem with these tracks was that they were very inaccurate. The track teeth were molded into the track pad, and the inner portion of the track pad had a large channel molded into them. On top of that the plastic material that they were made of was brittle. In their place I used a set of Panzerwerk ABS plastic T-48 tracks. These links are far superior to the kit supplied tracks and are worth every penny! The tracks come with the end corner Duck Bill connector.
A small angle is molded into the tooth. For added track flexibility these angles were removed.
The tracks have a nice articulation and the tank rolls very niclely.
    December 2008
Posted by psstoff995's lbro on Sunday, September 13, 2009 11:19 PM
Looks good! Almost there, I can't wait to see it finnished. Thumbs Up [tup]
    April 2005
Posted by armourguy on Friday, September 18, 2009 11:23 PM
The last of the parts were added and the tank is now finished. To quote Queen "Another one Bites the Dust!".  Over the weekend I'll be shooting an out door dio, and make the tank's gallery webpage. Once the gallery is complete it is off to the next one  ;)
The tank's Tools and "funiture" were built and completed.
I have added to the product line a Set of US AFV tools. I have had these tools since I built the M10, but I never got around to adding them to the website. http://www.eastcoastarmory.com/ustankparts.htm
The tank's gas caps were machined out of aluminum, and their retaining chains were added.
Chain was also added to the tow Hitch and the tow hitch mount.
For the tank's AA 50.cal I used the Dragon 1/6th scale Plastic 50.cal kit. The kit is an excellent detailed 50.cal. The kit also goes together very nicely, but needed very few enhancements.
The gun has a functional bolt and charging handle, but a spring was added to make the bolt return.
The gun's barrel has sveral notched molded into onto the ring. Due to the way the parts were molded the notches are absent on two sides of the ring. So the two notches were added to the ring.
The gun's top ammo hatch is functional that has two molded notches. These notches are too small and the plate is held in place, but the door tends to fall out. To fix this I drilled out the notches and used a small wire brad to hold the plate on keeping it's functionality.
STOCK
ALTERED
For the Gun Cradle, I used the Armorpax white metal kit. The Armorpax kit is also a very nice add-on. To make the cradle pivot I used two micro slot screws that were screwed into the guns pivot points.
The gun comes with a nicely detailed ammo belt, but the problem is that the ammo Belt is made out of ridged styrene, and is not flexible. DS styrene would have been a better choice for the ammo belt material. The kit also comes with a nice ammo box, but the ammo box is not for WWII. The Kit's tripod is also excellent, but is not going to be used on this model.
For the ammo I used a DID cloth and brass ammo belt. The 50.cal shell casing were left natural brass, and bullet heads were painted copper and tracers were added to every 5th round.
    April 2005
Posted by armourguy on Thursday, September 24, 2009 3:09 PM
I will start the next tank over the weekend and I'll have some progress posted by early next week.
As for Dynamite, I filmed the tank's out door diorama with a few of my other US armor. I have many more images, which I will post soon along with the tank's gallery website. Enjoy!
    December 2008
Posted by psstoff995's lbro on Thursday, September 24, 2009 6:44 PM
I really like that sherman! And those are some great looking armor pieces!
Great build. Bow [bow]
    April 2009
Posted by deafpanzer on Thursday, September 24, 2009 8:43 PM
WOW! Thumbs Up [tup] Damn, this is so sick! Thumbs Up [tup] Wish I'd have your skill and dedication to build those 1/6th scale models.  Now you have made me wonder how many you have built so far.  I recall you have Puma & Jadtiger from your recent forums or something like that.
What tank are you planning to build next?  It is always a pleasure following your process.
Andy
    April 2005
Posted by armourguy on Tuesday, September 29, 2009 8:40 PM
In my personal collection I have about 20 1/6th scale tanks with more on the drawing board. you can see my full collection here  http://www.eastcoastarmory.com/battlezone.htm . As for my next tank it will be an M3 Lee. here is a sneak peek
The tank's gallery webpage is completed, and I have all of the diorama images posted.
http://www.eastcoastarmory.com/tnt/dynamite.htm[/url
    July 2009
Posted by Back to the bench on Tuesday, September 29, 2009 10:31 PM
Simply amazing!! Actually nothing simple about it, just amazingThumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup] I can almost hear the clatter of the tracks and smell the exhaust!
Gil
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Wednesday, September 30, 2009 2:50 PM
This is absolutely unreal.....
 https://i.imgur.com/LjRRaV1.png
    July 2009
Posted by Marcus-Sirilicus on Wednesday, September 30, 2009 5:54 PM
Dude, just tell us the truth....
You and Wayne Szalinski got together, and you plan on being shrunk to 1/6th of your size.
This is just Amazing!!!!
    April 2009
Posted by deafpanzer on Wednesday, September 30, 2009 8:00 PM
Thanks for the link to the website listing all of your completed models.  Jeez, you must have been BUSY for a long time.  Looking forward to follow your next build... M3 Lee is one of my favorite tanks.  Bet you are planning to paint yellow stripes around the turret!  Keep sending us the pictures...
Andy
