Build Complete #9 Cyber-Hobby Orange Box Sherman M4A4 75mm WIP
    January 2009
Posted by Schnobs on Thursday, October 1, 2009 12:34 AM
Hey Steve!
Good catch on the weld for the cheek armor and the remaining pieces I will be sure to add that tomorrow.
I looked at a lot of references before I mounted the cheek armor I don't think that was an exact science and I think I am stuck with this placement.  I used a lot of thick CA on the piece but I will see what I can do.
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance. That principle is contempt prior to investigation." Herbert Spencer
    August 2009
Posted by M1Carbine on Thursday, October 1, 2009 2:38 AM
Ed, the sherm is looking great man.  Nice to see all the goodies you got at the show are getting used.  Cant wait to see more bud.
Bob
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Thursday, October 1, 2009 5:58 AM
 Schnobs wrote:
Hey Steve!
No rivet counting intended.
http://i184.photobucket.com/albums/x242/shawnasingh/rivet.jpg
 I don't think the "exact" placement is important.....  just wanted to make sure you were aware of it since you are putting such an ernest effort into this.
http://www.innovationbyinstinct.com/services/hosting/clients/accountyp/status/DisasterMaster/%23t1-4.jpg
 https://i.imgur.com/LjRRaV1.png
    January 2009
Posted by Schnobs on Thursday, October 1, 2009 10:50 AM
Thanks Bob the assembly is going slow and I can't wait for the painting but like they say the Devil is in the details!
    January 2009
Posted by Schnobs on Thursday, October 1, 2009 10:54 AM
No worries Steve I didn't take it that way at all.  Some pictures have the cheek piece higher than others so I compromised on the placement but I missed the attachment welds so I am torn between using some Archer transfer welds I have or using milliput.  I want to try the transfers out so I might use them for fun.
As always I appreciate your and everyone's thoughful feedback on my work it has helped me to improve and "correct" assembly errors. Smile [:)]
    July 2003
Posted by disastermaster on Thursday, October 1, 2009 10:11 PM
You're a good man dude.http://i248.photobucket.com/albums/gg172/indigo_silk/have%20a%20good%20day/Great_Weekend-blue.jpghttp://www.innovationbyinstinct.com/services/hosting/clients/accountyp/status/DisasterMaster/%23t1-4.jpg
    January 2009
Posted by Schnobs on Thursday, October 1, 2009 10:50 PM
I try to be Steve.
I am so close to gettting the remaining details done.  I thought I would post my progress today to keep my momentum.  I detailed the turret except for the antenna mounts which are in the mail and should show up tomorrow.  I applied some welds to the cheek armor with Milliput and I was informed it was only welded on three sides.  Who in God's name cares about these kind of details?  Apparently me because that's what I did.
I also bent up some music wire for hatch handles and cut down some resin periscopes for the crew hatches.
    July 2003
Posted by disastermaster on Thursday, October 1, 2009 11:22 PM
PerfecT!
You could try a bit of that on those side plates too.....http://i731.photobucket.com/albums/ww317/schnobs20/AFV%20WiIPS/Cyber-HobbyOrangeBoxShermanM4A47-73.jpghttp://www.innovationbyinstinct.com/services/hosting/clients/accountyp/status/DisasterMaster/%23t1-4.jpg
    July 2004
Posted by wbill76 on Friday, October 2, 2009 9:56 AM
Rolling right along with this one Edmund! I agree with DM, some welds for the side plate patches would be a nice added detail. Thumbs Up [tup]
    July 2007
Posted by Utoshita on Friday, October 2, 2009 11:29 AM
Dear Mr. Schnobs,
I am in the fortunate position to be a couple of steps behind you, I learn so much from just following you.
Thank you so much for this!
With regards to the weld seems I think you are so spot on with what you have done with the turret's added armour.
The side reinforcments need the same treatment but this should not be overdone.
A good weld seem does not have to add "surface" material, it should melt the materials beeing joined and fill where required.
Basically that means that a negative weld, where the materials are sinking together is better then a joint where welding material is added on top off the plates to act as "glue".
Disatser Master kindly provided these links;
Thank You so much for sharing!
With Kind Regards
Utoshita
Deliriant isti Hominem!
    January 2009
Posted by Schnobs on Friday, October 2, 2009 11:50 AM
Thansk Bill, Steve & Utoshita for your posts and suggestiosn for the side armor as well.  I plan to add weld seams I just ran out of energy yetesterday.  I have a cold and I tell my wife I might die but I don't think she believes me! Smile [:)]
    July 2004
Posted by wbill76 on Friday, October 2, 2009 1:19 PM
Probably has something to do with the fact that you're still able to build and post! Laugh [(-D]
    January 2009
Posted by Schnobs on Friday, October 2, 2009 2:11 PM
LOL!  That might be it Bill!  Smile [:)]
I need you guy's opinion on stowage. I stll need to add the front headlights and guards and also add detail tto side applique armor and also handle to gas can stowage.
Here are some mockup shots of my stowage and I still need to cut off the Formations Pioneer tools which I am not looking forward to.
This is a Canadian vehicle so will I need to add the welded rod to the turret to hang the turret items and camoflage netting?
How does this look?
    August 2008
Posted by Pvt Mutt on Friday, October 2, 2009 2:45 PM
Edmund I don't know a thing about Shermans but I remember reading a post about one and the guy was reminded not to forget to drill a drain hole in those shields around the fuel caps.
You might check with the experts first.I just thought I would point it out just in case.Smile [:)]
The extras look good on there btw        Tony the Mutt
Shoot Low Boys They're Ridin Ponys
    January 2009
Posted by Schnobs on Friday, October 2, 2009 2:48 PM
Thanks for reminding me to do that Tony it's on the list!
    July 2006
Posted by redleg12 on Friday, October 2, 2009 7:11 PM
Edmund - Some thoughts on the stowage....the back looks fine, you will need some tie downs to keep it in place as you go down the road.
Now the turret I think is overdone. First, where are the tiedown points for all that is attached to the turret. Remember they did not glue it onShock [:O]. Next, it is too bulky on the turret. if the turret were to rotate, does all the "stuff" clear everything else.
You could put a little on the front just don't block the vision ports.
Just some thoughts!!
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    January 2009
Posted by Schnobs on Friday, October 2, 2009 7:33 PM
Rounds Complete!!
Hi Michael congrats again by the way! All good points and my research points to the following:
This stuff on CW tanks was usually strapped through small footman's loops welded to the turret side unlike US who welded on bars.  They did not use CA I hear! Big Smile [:D]  Odd thing here is that the camo net shown on the right side was officially stowed on the left side forward, with eight loops to strap it down.  Of course, crews could rearrange things--and did. I am taking the liberty to switch sides so I can get the Resicast boots on the side of the turret whcih are really cool. The turret does rotate with all stowage in place if the crew hatches are closed.  I have some really nice "rope" that came with the Resicast kit tie everything down accordingly.
Your "thoughts: are always welcome my friend!
    May 2008
Posted by BeltFed on Friday, October 2, 2009 8:30 PM
Remove the little nub protruding off the .30 cal.  The barrel was flush with the muzzle on the real thingWink [;)]
    January 2009
Posted by Schnobs on Friday, October 2, 2009 8:37 PM
Yes that would be problematic if fired.  Wink [;)] I will nip it off and drill it out.  I must of mounted it backwards.... Thanks for the catch.
    October 2008
Posted by RickLawler on Friday, October 2, 2009 11:25 PM
Hey Edmund,
Nice work on the Shermie.
Stowage -
As long as you've got the Milliput out (from your welding), I might suggest that you make a few small tarps or blankets to place under the resin items.  This will provid a nice base tor the resin pieces to sit upon so they look to have some weight and follow the contours of the vehicle better....rather than appear just plopped on board - hard surface to hard surface.
Rick
    July 2003
Posted by disastermaster on Friday, October 2, 2009 11:28 PM
Here'ya go....http://www.toadmanstankpictures.com/alabama_m4a3e2_34.jpg
....earlier models such as this one had two weep holes side by side (on both sides) plus the single one. Later models only had one plus the single one (on both sides).
    January 2009
Posted by Schnobs on Saturday, October 3, 2009 12:07 AM
Hey Rick,
Thanks Rick it seems like I am spending more time making corrections and researching than anything but that's half the fun.  I just learned a lot about Type 19 A & B Antenna mounts and height of arials today.  There was another resin piece that came with the Resicast kit that already had a tarp half covering the lad I took a few shots to get your opinion.  I can use this one or try to make my first Milliput tarp.
    January 2009
Posted by Schnobs on Saturday, October 3, 2009 12:09 AM
Hey Steve,
My M4A4 has a square peice in that postion should I drill two holes through that on each side then?
    December 2008
Posted by model maniac 96 on Saturday, October 3, 2009 12:31 AM
Looking good, I like it!
Thanks, Jim
"Veni, Vidi, Vici" Julius Caesar: I came, I saw, I conquered.
    August 2005
Posted by Phil_H on Saturday, October 3, 2009 12:38 AM
 Schnobs wrote:
Hey Steve,
Hey Edmund,
I believe that the two holes in the "box" section in the pic are actually covered by the little "square" piece which is shown in your kit, but not in the full-sized pic from Tony above.
See this pic: http://data3.primeportal.net/tanks/jan_peters/m4a4_sherman/images/m4a4_sherman_34_of_44.jpg which appears to have a small plate welded over this area (which appears to be represented on your kit).
    January 2009
Posted by Schnobs on Saturday, October 3, 2009 12:56 AM
Hi Phil!
I wonder what that welded piece is for?  You realize I will not sleep until I find out?  Confused [%-)]
    January 2012
Posted by I make stuff on Saturday, October 3, 2009 1:21 AM
Edmund,
I am torn between the two versions of stowage.  The first one is certainly busier, and will look better with the varied textures and colors...
but...
Now that i think about it, Europe, Fall, and yeah, I'd probably want to toss a tarp over my stuff that was riding outside.
SO other then to offer my thoughts, I am, again, no help whatsoever.
Sorry, man.
Bill
    July 2003
Posted by disastermaster on Saturday, October 3, 2009 1:40 AM
 Schnobs wrote:
.........You realize I will not sleep until I find out?  Confused [%-)]
Apparently the weep hole (most likely just one) is there behind the plate. Check this out, maybe you can go to bed now...........http://www.toadmanstankpictures.com/m4a4t_40.jpg
here, you can barely see it in the extreme right top corner ................                         http://www.toadmanstankpictures.com/m4a4t_02.jpg
The other (rearmost) weep hole appears to be present in this next picture..... http://www.toadmanstankpictures.com/m4a4t_41.jpg
below is is probably how it looks under the plate.http://www.toadmanstankpictures.com/m4a2_faxon_07.jpg
oh, and here's a pic http://www.toadmanstankpictures.com/m4a3d_12.jpgto help with the slight gap http://i731.photobucket.com/albums/ww317/schnobs20/AFV%20WiIPS/Cyber-HobbyOrangeBoxShermanM4A47-84.jpgyou have on both the rear idlers (actually they don't appear to be molded correctly).
  http://smilies.sofrayt.com/%5E/l0/sleeping.gif   ............ nitey-nite big boy.
    January 2009
Posted by Schnobs on Saturday, October 3, 2009 10:47 AM
Morning Bill,
Yes I am torn as well they both look great but the first one is more visually interesting so I am still wresteling with it.  I was able to mount the Formation headlights last night which are really sweet.
I am doing more research on headlight guards to make sure I get the placement right.  I lost one of the rear PE Edward PE lightguards to the Carpet Monster and then I found it crushed beyond repair so I replaced that with the platic one after I shaved it down a bit.
Steve pointed out some more work for me to do on the rear idlers before I can paint. I should be able to paint later today or tomorrow......
    January 2009
Posted by Schnobs on Saturday, October 3, 2009 10:49 AM
Hey Steve,
Thanks for the sharp informed eye as always I will take care of the Idler seam before I paint.
