SprueOne,
Thank you for the compliments. There were a couple of details that jumped out at me when, I was processing the pics for upload. The tension adjusting mechanism on the front left needs some attention. I realized that I did not even weather that part. . One of the wing nuts for the flimsies is MIA. . All in all I am pretty pleased with how this turned out. A lot of different learning curves due to experimenting with different mediums.
Tony,
Thank you so very much for stopping by. Not to mention the compliment. I have been following your Dicker Max build. I'm loving the headlight assembly you went with. Your SPGs are always a treat to follow. There are some logging roads I've ridden/driven where you come across 2-3"+ quarry rock and the finer rock just hasn't covered it. Ouch.
Andy,
Thank you for the compliment. I was going for a summer (ish) feel on this one. At some point I want to do another winter dio. Or perhaps a wet fall, early spring one instead.
Well gentlemen, aside from a couple of details that need my attention, I am calling this one completed. And just under the seven month mark no less. This one gets the award for bench hog just for that alone.
I shot a fair number of pics for this one, as I was playing with some new lighting at the bench. Two side lights and a couple of homemade diffusers. They seemed to work fairly well. Comments and constructive criticisms are always welcome.
Loaded for "Bunker"
After I shot this pic and saw it on a bigger screen a couple of possible titles came to me. "The Hope of Something better", or "After the Job is Done..."
Thank you for following along on this stop and start, three steps forward two back build.
Sincerely
Dave
