#6 OLD Tamiya Panzer IV Ausf H WIP- COMPLETED!
    April 2009
Posted by deafpanzer on Saturday, August 6, 2011 12:55 AM
BaBill- Thanks for the compliment!  Hope you get to play better tomorrow... we can split $$$ if you win. Big Smile
Guys- Earlier Pat (shoot&scoot) noticed that the muzzle brake was cocked.  I am so glad he did because the brake would have fell off by itself.  When I was about to have it fixed, it just fell off.
Now it has been fixed with CA... I have to spray Dunky over the muzzle brake again when I have the chance.
I have decided to give my second top choice of camo scheme a go.  The edge was not hard or too soft...
Using this poster putty to hold the templates...it allows little space between the skirts and templates for softer edges.
It took a while to cut all templates... i used my boys index cards since they are much thicker and stronger.
Here's the result... you will notice the spots where putty were to hold the templates.
Tomorrow I will touch up the Dunky to hide putty spots and see how it looks.  What do you think?  I only want honest answers... Big Smile  I am not too sure if I like this.
Maybe I should re-do and cut templates using straighter lines instead of doing curvy templates?
Andy
Posted by tigerman on Saturday, August 6, 2011 1:37 AM
Clever way to attack the complex camo. I think it came out looking quite good. I think with some fading and weathering it will be great.
 Eric
    April 2009
Posted by deafpanzer on Saturday, August 6, 2011 2:40 PM
Eric- Thanks for the compliment.  I took another good look at my camo work and I have decided I will re-do.  You will understand why...
A guy in other forum posted this actual picture of Pz IV #505...
The actual camo scheme is not even close to the drawing by the artist.  Lesson learned not to rely on drawings. Anyway I really like the actual camo scheme shown in picture so I will give it another stab.  This time I will apply dark green as base coat on the skirts and airbrush Dunky spots.  It should be alot easier that way...
Andy
    July 2004
Posted by wbill76 on Saturday, August 6, 2011 3:41 PM
So long as you're happy with the end result, that's what matters most Andy! Yes I liked the way you approached the scheme with the template cut-outs using index cards in the first pass but can also see why you might want to re-paint from an accuracy standpoint. Color plates can often be subjective depending on the artist and what their source material was at the time they were created.
    July 2006
Posted by bufflehead on Saturday, August 6, 2011 10:29 PM
Andy, I just posted a comment in the Ostfront GB not realizing you had a thread going on over here!  Man, I can see why you want to redo the camo!  The actual camo shown in the photo IS quite different than the color plate!  Its a much softer camo pattern that looks more like yellow over a green base!  Even the number on the turret schurzen is a different size!!  I'm sure you're camo correction will be spot on!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
    April 2009
Posted by deafpanzer on Sunday, August 7, 2011 12:39 AM
Ernest- Yep, I thought I'd keep our friends here in Armor updated what I have been doing.  I am glad I did because I received a great deal of information such as incorrect camo scheme I picked... now I am feeling better so I can go back to our GB and finish my Panzer IV.
Bill-Yeah, lesson learned at my end and I will make sure to check with other references if available.  Safe to say that I am happy with my second attempt on the camo scheme.  As usual thank you so much for dropping by! Beer
Guys- Like I said earlier I wasn't too happy with the result and somebody sent me the actual picture of the Panzer IV #505 in other forum.  Jeez, the artist's drawing wasn't even that close and I liked the real scheme.
http://www.militarymodelling.com/sites/1/images/member_albums/70745/ts.jpg
It showed how soft the camo edges were so I decided to follow this actual scheme.  Since the picture of #505 panzer showed that it has more dark green, I repainted the base coat using MM Dark Green after pre-shading job.
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00900-20110806-1700.jpg
With help of my new best friend... iPad sitting next to the airbrush booth I did my best to copy the scheme.
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00901-20110806-1701.jpg
Then I freehandedly airbrushed the Dunky spots...
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00902-20110806-1831.jpg
 http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00906-20110807-0053.jpg
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00907-20110807-0054.jpg
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00908-20110807-0054.jpg
This time I am pleased with the result but it is not over yet.  I will do a touch up job on the dark green area.   Then I am thinking about doing an over spray of heavily thinned dark green to make the camo blend better.  Or should I use Dunky instead?
What do you think?  Thanks again for the comments and looking... Beer
Andy
Posted by tigerman on Sunday, August 7, 2011 1:03 PM
I'd overspray it with dunkelgelb, since that was the base coat at the time. Or you could go with washes.
 Eric
    January 2007
Posted by the doog on Sunday, August 7, 2011 3:33 PM
Looks good with the came, although I would overspray with a very light DY--almost like "dust". That would be a better reflection of the natural weathering already evident in the photo.
You could also do a light gray filter. That would actually look pretty cool.
Posted by Tojo72 on Sunday, August 7, 2011 3:48 PM
really nice job on the zimm,camo looks good also
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Monday, August 8, 2011 5:16 AM
Whoa Andy, you're gettin' good at this.......http://th13.photobucket.com/albums/a281/kaijafon/smileys/th_taubenfutter.gif
http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
 https://i.imgur.com/LjRRaV1.png
Posted by Anonymous on Monday, August 8, 2011 7:06 AM
deafpanzer
IMO, you freakin' NAILED IT! Bow Down
    March 2011
Posted by modeler#1 on Monday, August 8, 2011 8:34 AM
I have that same book deafpanzer
On the Bench: Nothing atm
    March 2010
Posted by Hercmech on Monday, August 8, 2011 9:17 AM
The camo came out much better the second time. Even for scale, the first attempt looked a little hard edged.
I think when the weathering and filters are done it will soften up your free hand even more and make it look spot on (no pun intended)
Looking awesome so far.
13151015
    December 2008
Posted by psstoff995's lbro on Monday, August 8, 2011 9:30 AM
SPOT ON! Yes
Love love the pattern
-Will young modeler Test fit master
    April 2009
Posted by deafpanzer on Monday, August 8, 2011 3:29 PM
Doog- Glad you liked... will do that next but first I need to paint the rest of the panzer.  Stay posted...  oh, did you finally try one of those Carolina BBQ if you can give up being a vegetarian just for a day? Big Smile
Anthony- Thanks for stopping by... zimm part was fun which surprised me.  See you in Pz III GB soon?
Disastermaster- Only one smiley face?  I was expecting few.  Only kidding... again thanks for the compliment!  And I hope you are going to build something soon...
Manny- Nailed?  Thanks for making me feel better now.  I wasn't too sure earlier but know it will look better after filtering and weathering.
Modeler #1- Same book... Vietnam Experience next to my iPad?  It was one of best Christmas gift from my parents.  WWII was only my interest when I was very young but later I studied Vietnam War history when I was in high school back in the 80's.  And I have huge respect for our Vietnam veterans...
Hercmech- Agree with you... I am thinking about doing hard edged camo using same method on one of my future builds but it has to be a late variant or something like that.  Maybe a Panther? Big Smile  Thanks for stopping by!
Psstoff- Thank you for the comment. Yes  More to come...
Andy
    July 2004
Posted by wbill76 on Tuesday, August 9, 2011 7:50 PM
Definitely an improvement Andy and much closer to the photo! Yes I will echo the recommendation on a light dusting of the DY vs the Green...you don't want a green "mist" over the yellow as that will likely produce an unwanted contrast vs. actually blending the colors together. The DY mist will do double duty of creating a foundation of dirt/dust for later filters/washes as well and would be the way to go IMHO. Looking forward to the next evolution on this old girl!
    August 2006
Posted by ogrejohn on Tuesday, August 9, 2011 8:18 PM
Much better Andy! Can't wait to see it finished up!
    October 2009
Posted by PANZERWAFFE on Tuesday, August 9, 2011 11:17 PM
WOW!  Have not been in the armor side in a while and this is what I've been missing!  Looks AWESOME, that is right on!!  Do moreYes
Rob
    April 2009
Posted by deafpanzer on Tuesday, August 16, 2011 11:08 AM
Bill- I am glad you liked the second attempt better.  I went for tan over spray this time... thanks for letting me know not to use green.  The camo will probably be toned down after I apply washes and MIG pigments too.
John- Always great hearing from you my Hoosier friend... guess where I am going for next three days?  Brown county state park where a conference will be held.  Not too far from you I bet...
Rob- Happy to have you back! Glad you liked the camo job... more to come!
Guys- Here's update on my Panzer IV Ausf H... airbrushed the camo freehanded on the rest of the tank. Did touch up couple of times before I over sprayed heavily thinned tan paint all over to bring the camo together.  It really helped... thank you guys!
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00924-20110814-2158.jpg
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00925-20110814-2159.jpg
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00926-20110814-2200.jpg
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00927-20110814-2200.jpg
This is my favorite shot.... bird view of the panzer as you can see how camo scheme is breaking up its shape.  No way those wingy b@stards will be able to find me and my panzer!
http://i713.photobucket.com/albums/ww137/aleffler/Panzer%20IV%20Ausf%20H/IMG00928-20110814-2201.jpg
It is ready to do the next stage... detail painting and decals! Tongue Tied  Thanks for looking and comments are always welcome... Beer
Andy
Posted by tigerman on Tuesday, August 16, 2011 12:30 PM
I think it looks great Andy. I love the overhead view. All you need now is a really good weathering job to bring this boy home.
 Eric
    March 2010
Posted by Hercmech on Tuesday, August 16, 2011 12:36 PM
Very nice. Love the subtle fade. Looking forward to seeing it all wrapped up.
13151015
    July 2004
Posted by wbill76 on Tuesday, August 16, 2011 1:47 PM
It all tied together very nicely Andy, now on to the detail stage to bring it to life! Beer
    August 2006
Posted by ogrejohn on Tuesday, August 16, 2011 5:26 PM
Looks like you nailed it Andy! The camo looks great!
Yep, Brown County State Park isn't too far away. It's really beautiful there in the fall when the leaves on the trees start changing colors.
    April 2009
Posted by deafpanzer on Tuesday, August 23, 2011 7:13 PM
Eric- Thanks!  Sorry about the slow response... Embarrassed
Hercmech- I am so glad you liked the subtle fade... thanks for dropping by!
Bill- Thanks buddy!  I am working on that part... detail painting.  I think I am going to need your help... look out for my next post in few minutes.
John- Brown County State Park was beautiful... enjoyed my stay there.  Hope they will have the conference there again next year...
Andy
    April 2009
#6 OLD Tamiya Panzer IV Ausf H WIP- HELP!
Posted by deafpanzer on Tuesday, August 23, 2011 7:43 PM
Guys- Small update on my Panzer IV... detail painting in process and attached the wheels to the hull.
 I ran into tracks issue and I hope you guys can help me out here.  Tongue Tied
I used ModelKasten tracks (SK-17) and the instruction said to use 97 tracks on each side.  So I did 98 tracks during the assembly to start with.  BUT it wasn't long enough!  I had to add four more making it 102 tracks to fit each side.  Unfortunately I broke couple of links during 'cutting off the sprue' stage.  Now I am left with only four links to be used as spare tracks in the front... Sad
It doesn't look that good and I'd hate to spend another $30 for more tracks from MK.  I was wondering if any of you have few tracks to spare... like 5 or 6 links?  Or is there a smaller set I can order?
HELP PLEASE!
Andy
    December 2008
Posted by psstoff995's lbro on Tuesday, August 23, 2011 7:54 PM
That's very odd (as far as I know) and unfortunately I have no tracks to give you.
However, the tank is looking very nice...  Maybe the crew had the same problem with cutting their tracks off the sprue as well and that's why they only had a couple left... Stick out tongue
    December 2006
Posted by detailfreak on Tuesday, August 23, 2011 9:34 PM
                    Hey buddy,would a small quantity of leftover magic tracks doya,and if so solid or open guide horns,and late cleated type or not.Let me know I already have your 1020.
                                                  Greg"Detailfreak"RowleyYes
[View:http://s172.photobucket.com/albums/w1/g-earl828/]  http://i158.photobucket.com/albums/t104/cycledupes/1000Roadwheels4BuildBadge.jpg
    April 2009
Posted by deafpanzer on Tuesday, August 23, 2011 10:43 PM
Psstoff- Thanks for dropping by!  Bet your day was exciting because of the earthquake today.  My brother lives in Fairfax, VA and it was his first...
Greg- I am so glad you brought up the subject Magic Tracks!!!  I didn't think of those earlier... Bang Head  I went thru my stash and found a perfect match... coming from Hummel kit.
Problem solved... thanks to you my friend Greg! Big Smile
I learned few days ago that I may take my family to Minneapolis next summer for my son's performance at Danish Culture Center.  I am going to buy you couple of Beer if you can meet me there!
Andy
    December 2006
Posted by detailfreak on Tuesday, August 23, 2011 11:46 PM
                         Just keep me updated. Glad to have jogged your memory on the track issue.
    July 2004
Posted by wbill76 on Wednesday, August 24, 2011 11:43 AM
Glad your track issue got worked out Andy! The Tamiya hull must not be the correct length if it required that many links to get the tracks fitted. "Normal" Pz IV track runs are usually 98-100 links and the MK track sets always include extras for breakage but not always enough for the spare runs too if you break too many. Beer
