Another quickie... Jagdpanzer IV L/70 - DONE Pg.2
    December 2008
Posted by psstoff995's lbro on Friday, October 7, 2011 7:58 PM
Great work Marc! YesYes
Always liked those Jagdpanther IVs.
-Will young modeler Test fit master
    March 2010
Posted by macattack80 on Friday, October 7, 2011 8:47 PM
Looks great!  I like the weathering.   Thanks for posting the WIP.
Kevin
    April 2005
Posted by wing_nut on Friday, October 7, 2011 10:19 PM
Hey guys...thanks for the comments.
Marc
    July 2006
Posted by redleg12 on Saturday, October 8, 2011 6:00 AM
 Look at the last picture....the left track appears to toe in. Give it a look.
Otherwise it looks fantastic, Very nice weathering job...I love the rusty muffler. At least it is bigger than a peanut butter jar!!
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    April 2005
Posted by wing_nut on Saturday, October 8, 2011 6:23 AM
Thanks Mike.  Yes there is a bit of a toe in.  The idler mount is sort of Z shaped with the axle and pivot point offset. In 1/72 scale it is really thin and the DS tracks are a tight fit.  Made tighter when I put the pins in the hull for the sag between the return rollers.  Looking at the picture I am wondering if a small spacer can be stuck between the idler and hul to keep it straightHmm
Marc
    January 2006
Posted by SprueOne on Saturday, October 8, 2011 10:48 AM
ah, I was going to ask about the tracks. AM? kit stock? how the sag was set? etc. I'm glad I read all the way through. Anyway looks like a good little model or at least you made it look good.
Nice touch with the rebuild of the cleaning rods Idea
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    July 2004
Posted by wbill76 on Saturday, October 8, 2011 10:57 AM
Nice work on this one Marc! Only suggestion I can make is to detail the jack block on the hull rear to go with the other wood details you've done on the tools. Nice job on the cleaning rod replacement. Yes
    September 2007
Posted by SuppressionFire on Saturday, October 8, 2011 11:13 AM
Found if you stretch them its better than dealing with tight tracks. Worst case scenario you have a link or two extra. Also the idler can be moved forward as a extra precaution without sacrificing accuracy.
The sag is well done and I am curious as to how you did this?
Excellent job on the Jagpanzer L/70!Toast
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    April 2005
Posted by wing_nut on Saturday, October 8, 2011 11:13 AM
Sprue, Bill... thanks.
Sprue, are all your tracks questions answered? Happy to supply more info if ya need it.
Bill, already doneWink
Marc
    January 2006
Jagdpanzer IV L/70 - 1/72 tracks
Posted by SprueOne on Saturday, October 8, 2011 12:55 PM
I think so. You mentioned pins to create sag, so I'm guessing they are rubber bands supplied stock in the kit.
They looked well handled and painted that I was thinking, "indie links" but in, "1/72"? Then I read your previous last post.
However, if they are not rubber bands from the kit, then please elaborate...
    May 2005
Posted by terry35 on Saturday, October 8, 2011 6:01 PM
Marc another excellent build, if it was 35th it would be brilliant but 72nd thats master craft work.
Terry.
    November 2006
Posted by dupes on Saturday, October 8, 2011 7:09 PM
Ooooh, nice! Nifty little base you've got there, too. Yes
Aren't many of those little DML 1/72 kits that don't have solid potential in them.
    April 2005
Posted by wing_nut on Saturday, October 8, 2011 7:42 PM
 SF... stretching the track?  Why didn't I think of thatWink That and moving the idlers.  Great suggestions. Thanks.
Sprue, Not sure if the Dragon DS tracks are considered rubber bands or not.  But indies in 1/72?  Oh my... I just threw up a littleIck!.  After the track ends are glued and dry I put them on and take a drill and press the track down a little with the bit and put a hole in the side of the hull.  A short piece of stiff wire is pushed in the hole and back from the edge of the track.  Dome between each roller and Bob's your uncle... sag.
Hi Terry thanks for stopping by and the comments.
Dupes, yup their 1/72 are real nice . When I went through the stash looking for something for the Blitzkrieg GB I found a few more.
Marc
