QUOTE: Originally posted by Anthony
But, what I don't understand is that: How could this man steal the tank in the first place. The tank was stationed in the National Guards base under security guard. This man was no longer a memeber of the Army, yet how could he pass all the checkpoints and security gates without proper ID. How could he sneak in. Furthermore, even when he got into the tank and left, why didn't the National Guards stop him right there, they had much better chance and firpower to stop him there. It took much later that the LAPD(whose firepower was no match for a tank) to stop.
Drive by your local National Guard armory or US Army Reserve Center. It wasn't until after 9/11 that the security was increased. The motor pools are probably on the local police's security rounds, but these areas were not guarded around the clock. The Armories and Reserve Centers do not store any amount of ammunition there. The full-time workers there would work normal Monday-Friday and during the weekend drill (normally the first weekend of the month). Go there on a Saturday or Sunday that no monthly drill is scheduled and no one would be there. Go there on a normal workday after 5:00 PM or before 7:00 AM and no one will be there.
If you every graduated an armor course (or combat engineer course where you learned to operate the CEV/AVLB), commandeering a tank parked in an empty motor pool would be fairly easy. All you would need is a heavy duty bolt cutter and perhaps an adjustable wrench. A determined intruder could get through whatever chain link fencing was up (use bolt cutter, squeeze through a gap, find a place to climb over, drive your car into the fence, etc.). Climb up on the nearest tank, cut the lock using the bolt cutters, and start it up. Might have to connect the batteries (hence the adjustable wrench) to get it to fire up. Again, a former armor crewman would have no problems firing up a fully operational tank.
Once inside, combat lock the turret from the inside and away you go. BTW, if the guy had combat locked the loader's hatch from the inside, they probably wouldn't have been able to open it so easily.
By the time the police respond to or discover the motor pool was broken into, the person would be well on his way. Of course, this incident is pre-9/11 and security measures have been stepped up.
