make your own m1a2 oif decals
    November 2012
Posted by t-bolt on Saturday, September 7, 2013 3:04 AM
Thanks HeavyArty.
is it ok to put these items: sleeping bag and sleeping mat
on the side of the turret or on the side of bustle rack (not inside)?
Posted by HeavyArty on Saturday, September 7, 2013 9:22 AM
Yes, they can go outside the bustle rack.  What is holding them on though?
    November 2012
Posted by t-bolt on Saturday, September 7, 2013 11:10 AM
Can you tie them with string?
Or are there hooks on the turret side?
On my model, I just glue them.
Whai do you think? Will it look strange?
    March 2004
Posted by subfixer on Saturday, September 7, 2013 11:27 AM
They use straps, nylon line, rope, or whatever. You just can't glue them on, it will look strange if there isn't some kind of attachment method that is apparent. You can't use the ol' Velcro excuse.
I'm from the government and I'm here to help.
Posted by HeavyArty on Saturday, September 7, 2013 1:33 PM
subfixer
Exactly what I was getting at.  Usually, they are attached w/webbing straps.  Rope is not really common.
    November 2012
Posted by t-bolt on Monday, September 9, 2013 2:42 AM
subfixer and HeavyArty,  thanks for the replies.
Here are some pictures:
I have not put the webbing straps, but to me I think it looks ok without them.
What do you think?
    November 2012
Posted by t-bolt on Saturday, September 21, 2013 3:03 AM
I manage to take some more pictures:
    November 2012
Posted by t-bolt on Saturday, September 21, 2013 3:07 AM
I am thinking about adding some paint chipping.
Is it appropriate for modern armor such as M1A2?
What color should I use? dark grey or dark green?
Posted by HeavyArty on Saturday, September 21, 2013 3:42 AM
Modern CARC paint doesn't really chip.  Is is a very tough, epoxy-based paint that is very strong and chip resistant.
It is looking really good.  If you want realism though, the ALICE pack bags hanging off the sides should all be green.  The US Army dodn't issue them in any other colors.  Trumpeter messed up the CIP panels on th erear and sides as well.  They should not be see through.  They are like louvered siding on a house.  Tamiya's ones from their Modern US Military Equipment set are correct and very nice.
    September 2008
Posted by White Shadow on Sunday, September 22, 2013 7:49 PM
T-bolt,
 If you only need black markings, you can make them in MS Word and print them out on laser decal paper using a standard b/w laser printer.  HTH.
Regards,
Georg
    November 2012
Posted by t-bolt on Monday, September 23, 2013 6:17 AM
@ HeavyArty
You are really a gold mine of information about all things M1A2.  Yes
Thanks for sharing your knowledge.
I did not know that modern tank paint does not chip.
This is new information for me.
Does this mean all the colors?
or only sand color?
Thanks for telling me that all ALICE bags should be green.
I did not know about that either.   :D
And yes I think I am going to use that tamiya us modern equipment set for my next abrams.
Too bad there are too many inaccuracies in trumpeter kits.
No wonder it is so cheap.
@ Georg
I am using photoshop and regular inkjet canon IP1600.
i do not have a laser printer.
However, I find the result is quite acceptable.
Posted by HeavyArty on Monday, September 23, 2013 1:36 PM
Yes, all the modern paint is very chip resistant.  It is a formula called CARC (Chemical Agent Resistant Coating).  It is a very strong, epoxy-based paint and is available in all the colors in current use.
Posted by Rob Gronovius on Tuesday, September 24, 2013 8:32 AM
t-bolt
or only sand color?
Newer paint is very durable; however, if you want to paint a Desert Shield/Desert Storm era tank, those tanks were 3-color NATO camouflaged and then received sand paint over it. Those tanks chipped very badly because of the hasty paint jobs. You'd often see large chunks of the sand paint missing and the green/brown/black beneath it. The same properties that made the paint resist chemical adhesion also made the paint resist paint adhesion.
    March 2013
Posted by garzonh on Tuesday, September 24, 2013 9:25 AM
It is coming out very nice!.
I agree that you should add some strap, ropes or something holding the bags.
Not only it gives a feasible/realistic look but makes the illusion that bags are very heavy.
If you allow me for some small advice,  I used masking tape, and even realized that the rough side of the tape, gives a great texture and also allows for pigments to adhere more easily.
Here is what mine looked... at close up
    November 2012
Posted by t-bolt on Thursday, September 26, 2013 3:41 AM
@ Rob
Thanks for the reply.
I think I have seen some pictures of M1 tanks which paint chipped very badly somewhere.
Your info explains it all.
Do this happen only to desert storm era tanks?
no OIF/OEF tanks?
@ garzonh
Thanks for the kind words, pictures and the advice.
Your pictures give me some idea to put some straps to my tank.
Your advice is very welcomed since I have just started this hobby again.
Your  straps look very realistic.
What kind of masking tape do you use?
You only cut it and paint it?
    March 2013
Posted by garzonh on Thursday, September 26, 2013 7:06 AM
Good morning my friend,
I used a low adherence masking tape, like the ones used for painting interior homes to make lines. They are blue in color. I think a standard masking tape has too much glue and is more difficult to work with.
I used a ruler and sharp hobby knife over a hard surface and cut straight lines, usually 20" long. Then paint them just with acrylics and a brush, I did a second layer with more paint and thinned and lighter shade of same green, on both sides. I did had some trouble with the paint on the sticky side, some of it will peel off. Don't panic.
Then just used as rope, i glued the tip of this "rope" to the back with super glue and regular glue, then I had to tight it using two tweezers one in each hand. This is the tricky part, because both tips are small and you can't use your fingers. This is where some surgical experience is handy, is like making stitches.
Once you have the appropriate length and tied it down and tightly, cut the excess and glue the other side to the back of the part.
As I mentioned if some paint comes off during this process, just use some pigments it will cover the problems, and give it more realistic, used, weared off look.
    November 2012
Posted by t-bolt on Tuesday, October 1, 2013 7:18 AM
Hi garzonh,
Thanks for the detailed explanation.
Too bad there is no blue masking tape in my city.
Is it possible to use the usual tan brown masking tape?
Posted by Rob Gronovius on Tuesday, October 1, 2013 9:38 AM
Blue masking tape is an industry standard painter's tape sold in stores like Lowe's, Home Depot, Walmart, Big Lots, Target, Kmart, etc. wherever interior house painting supplies are sold.
