Thanks to everyone for being so supportive and sharing invaluable tips and extremely inspiring pics. Due to changing internet providers, working a ton of overtime, and catching up on some home projects, I haven't been able to post any updates. Finally got a break in the action, so I'll try to catch things up - yet be brief
I finished all of the pre-paint assembly. I drilled out the bolt holes where the side skirts would be - Phil_H would be proud haha! That turned out very good. I did have a couple location problems where I had to fill and re-drill, but I got it to look acceptable. I also filled in the location holes where the pioneer tools would have gone, and I puttied any minor gaps I found throughout the model
This has been a tremendous learning process, and I couldn't be more pleased with how I'm progressing. The slow pace can be hard to take sometimes, as anxiousness creeps in, but it's bearing the fruit I'm looking for. What's most important is I'm enjoying it a lot
I fired up the new paint station for the first time today, and it was a lot of fun. As I've done with the assembly, I used the experienced advice I've received here to aid with getting started airbrushing. I decided to prime with a rattle can simply because I already had some and I believe in easing into things like this, so I'm trying to balance between keeping it simple for progress' sake while still being adventurous enough to advance my skills
That being said, after using the airbrush, I will probably drop the rattle cans altogether. The control with an airbrush is just too good to not use. I'm really amazed at how easy airbrushing is. It's really incredible. I really have to thank Don Wheeler and Paul Budzik. Their information on airbrushing and painting, I firmly believe, has shortened my learning curve with the airbrush immensely. If anyone new to airbrushing happens to read this, I cannot recommend those two gurus enough - check them out!
Here's a couple pics to show how things have turned out...
Here's the exhaust pipe that I hollowed out
Here's the model primed (this is after the first coat. You can see the bad skirt hole locations if you really look. After some touch-up and a second coat of primer, they aren't noticeable at all now)
Here's the result of my first go with an airbrush. I used Tamiya XF-1 Flat Black to do a little pre-shading - I'm not actually very concerned with that technique in itself here, it was mostly a way to get started with the airbrush. I used an Iwata HP-M1 set at around 18psi with the nozzle about halfway open (single-action). The paint was thinned to the obligatory milk-like consistency. I used Tamiya's X-20A thinner just to be on the safe side, with this being my first go and all, but I will probably use a simple home brew going forward (a mix of distilled water, IPA, flow-aid, and retarder). As you can tell, I don't have great control yet, which is to be expected whenever a hand tool is used for the first time. But with the aforementioned tips helping to get the paint flowing properly from the get go, I can focus on those skills quickly, which is where that learning curve shortens dramatically
Next up is to paint the road wheels and tracks, then color on the hull and wheels, then detail the tracks, then decals and weathering. Then, it will finally be done!
Just to make everyone jealous (well, probably not everyone hahaha!), here's my awesome airbrush array. Bottom left to right: Iwata HP-CS for detailing, and a Paasche H for primers and clears. Top left to right: Badger 200 for metallics, then an Iwata HP-M2 and HP-M1 for larger and smaller color coats, repectively
Hope everybody enjoys what's left of the weekend. Got a big four-day holiday weekend coming up, woohoo! On deck is a Spitfire Mk1 and a '67 Chevelle SS396. I'm going to try to do both of them simultaneously
