Thanks Gamera and Kevdog, your compliments are greatly appreciated. I am not a prolific military armor builder and take many of my processes from the experts here and other forums. While we felt we learned something from this build, it always has room for improvement, we just decided to call this one D-O-N-E. I may make a separate display base with a blown bridge crossing, other figures, and perhaps another vehicle, but all that would be another build basically. Thanks again for following along.
Jon_a_its, regarding the weak plastic joints in suspending the bridge, theres a few things you should know. First, we cemented the bridge to the hinge point on the tank to provide a stronger finished product. Second, by doing that it took a significant load off the cable connections. Third, we created several parts from metal to replace certian plastic ones, including at the points where the cable connect to the eye loops. Fourth, the fix position of the bridge also help us when we rigged the winch cable through the turnbuckles for length and to keep them taught. Fifth, we did not use the kits provided string and instead found a strong nylon cable weave that better replicated the steel cable in scale and also strengthened the build. Hope this helps...
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
