Mike,
That's kind of why I'm doing the weathering in sections. I keep referring back to the ones already completed as I do a new one in order to try and keep some consistency going while still having enough realistic variation over the whole thing. It's tough...I take a lot of breaks in this process which makes it slow going but insures I don't get in a big hurry and make a costly mistake, or at least I hope it does.
Day 15 Log: September 18, 2004:
Errors/Issues: None
Steps Completed:
--Continued the weathering process on the railroad carriages. Completed both front and rear using the MM Steel and black pastel combination. Sealed both up with Testors Dullcote as I'm now having to move them around quite a bit and keep finding traces of black pastel show up on my fingers at the worst moments... [:0]
---Added the kit-included copper safety chain to the shell loading deck. It was somewhat of a pain, not enough to qualify as an issue, but still a pain, because the chain links do not slip over the attachment points as indicated in the instructions. The links are too small to do this easily, but nothing a little CA and accelerator couldn't handle.
---Began the weathering on the gun barrel and mount/elevation mechanisms. These are now completely weathered but still unsecured due to waiting on replacement parts from Dragon. This makes it particularly difficult to work on but I think it's better to take care of it now while I still have some flexibility to it than trying to work with it locked down.
--Re-puttied and sanded the breech block joint area after examining it and discovering gap/seam still visible (sometimes it pays to let things sit for a while and come back to them with a critical eye!).
---Used the airbrush to repaint the breech and touch up some areas that had scuffed since the last paint application. Used up the remaining 1/2 bottle from the previous painting so that makes 4 bottles of Schwarzgray that have gone into this beast.
---Constructed the kit-included shells and canvas powder bags. Painted and weathered them. One shell and the bags will go on the shell cart with a figure pushing them, not sure what I will do with the other 3 shells provided, but will no doubt put them to good use.
Total Time today: 8 hours
Total time to date: 69.5
Progress Pics:
Additional Comments:
Weathering is taking longer than anticipated. I still have the gun cradle itself to weather and it has a lot of surface area to deal with. My intention is to finish the base weathering, apply a gloss coat to the cradle, add the decals, then gloss coat to seal and dull coat over that and then add weathering as needed. The figures on the shelf are starting to mock me, they know all too well why I've saved them for last...
As another note, the MM Steel is showing up in the pics as more pronounced than it actually is under normal lighting conditions. I use two 60W lamps for taking the pics and this lighting is somewhat harsher and the digital enhances the brighter look as a result.
