Tamiya Char B1 bis COMPLETED 03-04-07
    July 2004
Posted by wbill76 on Sunday, January 21, 2007 11:38 PM
Today was one of those days where I just had to be building...you know, one of those days where the urge strikes and you are compelled to start up something new? Trouble with that is that it was also conference championship playoff Sundayin the NFL...so while watching the games, I began work on the Tamiya Char B1 bis kit as a way to fulfill the need to build while watching the games.
Here's the starting point:
Beginning with Step 1, the "caterpillar" style of roadwheels is assembled by creating no less than 32 pairs of wheels, 16 to each side, and the cradle they rest on. Fortunately, Tamiya molded these with very small sprue connection points so cleanup was minimal...but it doesn't change the fact that there are indeed 32 of those suckers to deal with...at least they are steel and not rubber rimmed! The wheels are not glued into the cradle, only dry fit, and the instructions explicitly say not to glue them so they remain rotatable.
Step 2 calls for the installation of the wheels and their cradle into the lower hull. Since the wheels aren't glued down, this is a tricky exercise requiring an extra set of hands almost, particluarly since the fit is a tight one. I managed to drop several wheel pairs in the course of doing this, fortunately none went permanently missing. The detail plates for the front and rear are also installed in this step and fit nice and clean.
Step 3 is very simple involving the assembly of the sprocket and idler halves, each of which gets a polycap in the middle. The idlers had a slight seam in the middle that I sanded down out of habit more than anything else as it's highly doubtful it will be seen on the finished vehicle, but better safe than sorry I guess. Don't be tempted to remove the "sink marks" on the iders, they actually belong there and were intentionally molded.
Step 4 deals with the assembly of the 75mm gun and the housing/mount for the right side idler along with the left side idler mount as separate pieces. The Lion Marc set replaces the kit barrel assembly entirely, with a brass piece for the gun mount itself and a turned aluminum barrel complete with rifling. The brass piece identically matches the dimensions of the kit piece and incorporates the polycap onto the elevation arms, a perfect solution given the weight to allow the gun to remain positionable. The socket for the turned aluminum barrel needed a bit of attention with a needle file to get it to fit, but that was minor and little CA gel to secure it was all that was necessary.
Step 5 installes the front idler mounts on both sides into the lower hull plate along with the lower side skirts that cover/protect the roadwheels. The instructions say to paint the lower edges of the skirt in flat brown, I believe because these are actually rubberized canvas (or actually rubber) mud/dust covers, but not 100% sure.
Step 6 installs the inner rubber skirts along with the side access maintenance hatch panels on both sides. What's very ironic to me is that with both skirts installed, the wheels are hidden from view...and are still rotatable but for no real purpose I could see except that they do, in fact, turn. Wink [;)]
Step 7 calls for all the holes in the upper hull, molded as a single large piece, to be opened up with a pin vise to allow the skid plates and other details to be installed. Curiously in this step, they do not tell you to open up the two rectangular panes to create the mud chutes, although the areas are clearly molded for removal. I drilled out a series of holes around their perimeter and then cut through with a sharp knife, then sanded the openings with a sanding stick to complete the job.
Step 8 calls for the mud chutes to be installed, be careful with these as they have to go in just right to align properly. They are conveniently labelled L and R to keep track of which side they go on, but you can still turn them around if not careful which side is top/bottom when you install. The rear fenders/mudguards are also installed into the upper hull along with the track skids, the left side radiator housing, the sprocket drive mounts, front lifting hooks, and two of the rear deck access panels among other small details.
Step 9 directs you to remove 6 rivets that are molded on the rear deck, which does require some care given their proximity to other molded on details, but are taken care of with a sharp knife point easily. The sprockets are installed onto their mounts from Step 10 using their polycaps and no glue. The upper and lower hull are then joined together and while the instructions suggest using tape, I found the fit to be snug and only a little bit of finger pressure required to get a good join.
Step 10 constructs the driver's hatch and periscope housing along with the two headlights, one standard, the other auxiliary. Since "Marne" has the auxillary, this required opening up a hole in the front hull plate which is installed in Step 11. No pic taken of this step due to its minor nature.
Step 11 installs the front hull/glacis plate, the driver's hatch, and periscope mount plate to round out the hull armor panels. The fit of the glacis plate wasn't 100% perfect, some liquid glue had to be employed where it joined the lower hull and on the side, but that's all...no putty work will be necessary. I also installed the main blackout headlight with the cover in the closed position, although the option exists to install it open with good detail on the light if you wanted to go that route. The front tow bars and hooks are also installed and fit snugly into their designated places. Last but not least, the 75mm gun mantlet is also installed. Since "Marne" didn't have the pigtail lifting hook, I didn't add that detail but I did drill out the bolt holes top and bottom that would be present for the weather cover for the gun housing with a small drill bit prior to installation. These holes aren't marked or called out for on the kit parts, so I had to check the references carefully. The box art is a close, but not perfect, match of how they should be placed.
To round out the day's activities, Step 12 was completed with the installation of the right side crew hatch, grab handle, and rain/mud shield. The kit parts include a nicely detailed insert for interior detail on this hatch but since no other interior is included in the cavernous space of the hull, I left it on the sprue and just installed the hatch in the closed position.
I have to say that so far this kit has been an absolute joy to build. Total time to get to this point was about 6 hours altogether and there are 9 more steps remaining.
    January 2005
Posted by biffa on Sunday, January 21, 2007 11:47 PM
i built this one a couple of months back bill im just now finishing the weathering (last of my back log from 2006) and what a great kit it is i had fun with it i should have it done in the next few days what paint scheme you goin with? i did the green and sand coloured "bourrasque"
Ron g.
Posted by tigerman on Monday, January 22, 2007 1:05 AM
Man Bill, this is your third in-progress on the first page! I love your tutorials. Everything that is important in them comes from your hands on work. Like your others, this should be fun to watch.
 Eric
    July 2004
Posted by wbill76 on Monday, January 22, 2007 8:24 AM
Ron,
The painting guide with the Echelon decals indicates the Khaki/Sand two-tone scheme, so that's the one I'll run with. "Marne" has a similar scheme to "Bourrasque" although it's a later run variant with different features (different fenders, exhausts, etc.). Since you've got yours in the final stages, that means it will be finished by the end of the day, right? Laugh [(-D]
Tigerman,
Lately I've been trying to keep busy and keep the stash under 100 kits...been successful so far, but it's been tough...have set myself the goal of only adding kits when one gets built, it's been helping from a psychology standpoint...but have to be careful not to produce a backlog at the paint/finish stages. Big Smile [:D] Glad you like the walkthroughs, I have a fun time writing them up...and have managed to catch several things by taking the progress shots that ordinarily I might have missed...the camera doesn't lie after all. Wink [;)]
    August 2006
Posted by Gun Tech on Monday, January 22, 2007 2:48 PM
Road wheels..............    road wheels.......... Dunce [D)]   That is insane Bill! I'm looking forward to what will surely be another great looking vehicle!
Jean-Michel    "Arte et Marte"
    September 2005
Posted by treadwell on Monday, January 22, 2007 5:41 PM
oh crap--- I GIVE UP!!-- bill, you da man!!!-- lol-- i havent even got to post on the completion of your init. Tiger I and you have another going--- HEY! message to Ron --- you better shake yer booty boy -- bill may have a bigger factory---Laugh [(-D]-- lol -- just in good fun guys!Big Smile [:D]-- oh yeah, almost forgot, this one looks pretty interesting- the char b1 is the only french tank that even remotely interested me--it has a significant place in history no doubt!!--- treadTongue [:P]
    July 2004
Posted by wbill76 on Monday, January 22, 2007 8:36 PM
Gt,
When I saw that first step, I had to take a very deep breath, but fortunately it wasn't nearly as bad as I thought it might be. Big Smile [:D]
Treadwell,
Ron's got me beat by a long shot...he's already got 3 done and posted while I have only 1...at that rate I'll never catch him! Pirate [oX)] The Char is a tank that I've "fought" in online way back when...a slow lumbering beast that packed quite a punch, and when Tamiya announced this kit, I didn't pick it up at first because of the price but found a good sale eventually and snagged one. I've also discovered through talking with Roy and looking more closely at the reference photos that there are a couple of areas on the front hull, the curved area for the driver's hood and the area where the mantlet meets the bolt plates, that will require some putty work to correct, so will take care of that before proceeding onto the next steps, other than that the fit/engineering has been top notch.
    July 2004
Posted by wbill76 on Monday, January 22, 2007 10:36 PM
Just a short update today. After getting some helpful advice and checking some reference photos on the Char Francais site about the cast/seams around the driver's hood and 75mm gun mount, I put the putty to work. Also drilled out the opening in the driver's periscope for the peep hole. The putty work is a little tricky due to all the rivet heads but with a little care, the areas were taken care of. Also removed the incorrect solid molded handles on the rear deck access panels and sanded those areas smooth. There are photos that show an angled piece in front of the mud chutes, have to see if I can scratch something together out of scrap PE to do the job there too.
    July 2004
Posted by wbill76 on Tuesday, January 23, 2007 12:54 PM
I managed to find a pair of good candidates for the mud chute deflectors on an old Eduard PE fret. They were perfect right down to the curved/angled edge but were too long so had to be trimmed to fit with a pair of side cutters to be flush with the sponson edge. Also sanded down the edge/seam on the left side of the driver's hood as that too should be one piece and not have a join line at least until it meets the glacis plate.
Also did some more putty work on the front hull around the left side tow bracket since that's supposed to be one piece bolted onto the front hull. I wasn't 100% satisfied with the mantlet top hole alignment so I filled in one hole with putty and redrilled it to get it closer (not perfect) to where it needed to be. Also sanded down the missed seam lines on the tow hook swivels and discovered I'd overlooked a rather large sink mark on the underside of the right side tow bar.
I'm going to scrounge around and see if I have a left over x-shaped tightening wheel from either the DML or Tristar Flak 38 kits as the main headlight is supposed to have one of these on the back side of the latch for the blackout light cover.
    July 2004
Posted by wbill76 on Tuesday, January 30, 2007 10:55 PM
A minor update today in the form of completing Step 13, which deals with the tracks. The instructions call for 61 of the individual links to be snapped together to form each track side. Each link required just a little bit of clean-up on the small nub left behind on each plate face, easily done with a sharp #11 and a little care not to gouge the surface. The links snap together very smoothly and are the rivetted design. Test fits show that they will have to stretch just a bit to be connected up, but after about 20 minutes of clean-up and assembly per track side, two fully workable tracks are ready to roll. My hat's off to the design team that came up with these, probably the easisest set of indy link tracks available in a kit today. About 5 links are left over as "extras" as provided, not sure what they could be used for, but always better to have a couple of spares around I guess!
Posted by tigerman on Wednesday, January 31, 2007 6:53 AM
Why can't all indies be that easy. Would make the timid less so, including myself.
 Eric
    July 2004
Posted by wbill76 on Wednesday, January 31, 2007 3:36 PM
I agree! Although I think the Char track types lend themselves easily to this type of approach, others have done the same thing with resin type indy links for other vehicles, so it's not out of reach to use this method IMHO. Not sure about the design technology limitations for more conventional track types, but these went together like a dream, quick and painless.
    December 2003
Posted by buff on Wednesday, January 31, 2007 3:51 PM
You're blazing along there Bill.  It's really coming along.
On the bench: 1/32 Spit IXc
    April 2006
Posted by FingersEddie on Wednesday, January 31, 2007 4:10 PM
Yep, those tracks are cool, they're gonna' look real nice weathered too!
"Ask not what you can do for your country, ask what your country is doin' to you!" "If liberty means anything at all, it means the right to tell people what they do not want to hear." "Say 'NO' to censorship, it leads to a dictatorship!" http://public.fotki.com/paulyrichard/
    July 2004
Posted by wbill76 on Wednesday, January 31, 2007 11:21 PM
Buff, Fingers, thanks as always for the comments.
Continuing on...
Step 14 calls for the installation of the 4 tow chain hooks on the rear hull along with the 2 tow pintles. The instructions include a close-up drawing showing the correct alignment of the hooks and the holes that the hooks go into are "keyed" in their shape to also aid in this. The hooks are two different sets with A24 going on the right side and A25 going on the left. It's important not to mix these up as the hooks are different sizes and designed to sit at different positions/angles relative to their size. The holes that take them are slightly oversized, at least on my hull, and required a little bit of putty to fill in. This step also directs you to install the two tool racks on the top rear hull deck in holes that were pre-drilled out back in Step 7. Before you can mount them, you need to remove 2 molded on rivets for each rack support that otherwise would interfere with their proper positioning. Each rack support has only a single locating hole so getting them lined up and straight took some fiddling to get both correct, but nothing earth shattering. The tow pintle areas also needed a little bit of putty help to get them to look correct due to the cut out holes being slightly larger than the insert arm, a similar problem as encountered on the front hull.
Step 15 gives you the option to install either the earlier vehicle style spaced mudguard fenders or the flush fenders. For "Marne" since it's a later vehicle the flush fenders are correct. I used an emory board to sand down the front and rear areas to a slightly thinner look vs. the molded bevel look, others might choose to replace these with brass, but the kit supplied items work just as well IMHO unless you want banged up or damaged fenders. A test fit showed that it's not necessary to have the tracks installed at the same time as the fenders since the tracks can be slipped into place and then secured later on, so I've left the tracks off for easier painting/detailing for now.
This step also installs the turret ring and the pot for the radio antenna along with the wire guard. The wire guard, part B21, is molded solid but on the actual vehicle it was an open bottom square arrangement, so I used the pin vise to drill out a starter hole and followed that up with a needle file to hollow out the front and rear. I didn't hollow out the middle portion of the body but I suppose that could be done as well if you're really determined to get that look. Smile [:)]
I also modified the upper hull by shaving down the bolted on plate cover just behind the turret where the radio wire is supposed to enter the hull via an insulated cover. I scrounged around in the spares bin and found an old blackout light part that was just the right height and domed, cut off the support arm and used only the "lamp" part since it had the dome shape I was after, and drilled out a hole to accept the radio wire which I'll add in a later step. It's not a perfect match but it's close enough vs. trying to scratch or sculpt one on my own I guess. I will install the wire as a two piece arrangement using fine guage steel wire once the antenna is installed, one piece going from the insulator into the guard and another from the guard to the antenna base.
Back in Step 7 I'd forgotten to open up the holes for the base of the antenna pot, so I shaved off the locator pins and just glued it directly to the hull after mounting the wire guard and getting everything all lined up properly. A drain pipe of some sort is also installed, part B18, that leads from the engine compartment into the left fender to complete the step.
    April 2006
Posted by FingersEddie on Thursday, February 1, 2007 3:46 PM
Rollin' along nicely, Bill!
    July 2004
Posted by wbill76 on Friday, February 2, 2007 8:22 AM
Thanks Fingers, I've got to travel to Australia on Sunday for a week so have been trying to squeeze in as much time here and there as I can.
    September 2005
Posted by treadwell on Friday, February 2, 2007 7:52 PM
heya billBig Smile [:D]-- the char is comming along nicely!!-- it is a very intriging and unusual lookin vehichle--it is, to me, like the missing link between wwI and wwII--pretty dam cool--you know I always enjoy your builds!!--- have a great time in the 'land down under' and throw another shrimp on the barbie for me!!-- treadTongue [:P]
    July 2004
Posted by wbill76 on Friday, February 2, 2007 9:37 PM
Funny thing about travelling to Australia...you lose a day going out because of the dateline but when you fly back you actually arrive in the States before you left! I was careful with this trip though, timed my flights to LAX to allow for enough time to be able to watch the Super Bowl before I catch the flight to Sydney. 14 hours in coach...yahoo! Shock [:O]
I agree with you on the Char...it's got the classic "between the wars" look and feel about it. Spent endless hours driving one up and down the hills of northern France in an online game (Ron knows what I'm talking about) so kind of have a love/hate relationship towards it. Wink [;)]
    January 2005
Posted by biffa on Saturday, February 3, 2007 2:23 AM
moving along nicely Bill, i used to grab a rifle out run these big slugs all the time back in the day hehe i rarely drove one, anouncing you were coming to town 30 minutes before you got there was asking for trouble Big Smile [:D] have a great time in oz.
Ron g.
    July 2004
Posted by wbill76 on Sunday, February 4, 2007 12:25 AM
Ron,
Since they were infantry support tanks, they had speed governors to make sure that they didn't surpass their bretheren on foot...which makes for a verrrrrrrry slooooooow drive at times! Wink [;)]
I made a lot of progress today, completing all the major construction almost by accident since I hadn't intended to get quite this far along.
Step 16 presents an option between two different types/styles of exhaust configuration. For "Marne" the correct type are the fish-tail straight exhausts with the longer protective shrouds, so I used parts A26 and A11 to construct mine. The exhausts have a fine seam line that was a little tricky to remove but no other difficulties were encountered.
Step 17 directs you to install the mufflers onto the rear deck, which is easily accomplished since there are locator holes in both fenders to insure a squared-up fit. The protective guard rail, B33 is also installed and this part requires some cleanup since all the posts/rail sections have a mold seam and the joints where the posts meet the top rail also have sink marks that need to be dealt with. Last but not least, the concertina antenna support is constructed from two part halves. This design produces a join seam that has to be trimmed/sanded down without damaging the ridges on the flexible housing, I cleaned mine up using the back edge of a #11 blade for the interior surfaces and a fine grit sanding twig for the ridges themselves. I also installed the antenna wire leading into and out of the protective guard housing. The wire is just that, steel wire, that I bent to shape and glued in place with CA. The tip where it meets up with the antenna base was filed down with a square needle file and the antenna base is dryfit for now and will be removed for separate painting later.
I also didn't realize until writing this up that I neglected to install part B6 over the access door on the rear engine deck, fortunately it's not too late to still do that!
Step 18 deals with the pioneer tools and the tow chain. The pioneer tools consist of a crowbar, sledgehammer, pick, and shovel that install together as a package of tools. The crowbar and pick are on the bottom with the sledge and shovel on top. The fit is very complex and I gave up trying to dryfit it, everything looks like it ought to fit properly so I'm not too worried about it and will install them later after painting is done.
I installed the rear hull tow swivels and did as the instructions directed by cutting the hook portion on each to accept the chain later on when that gets installed.
Step 19 begins the work on the turret by way of constructing the 47mm gun and mount along with the commander's cupola. The Lion Marc barrel requres that the one-piece Tamiya gun part A12 be trimmed down to the two mounting pins and a hole drilled out to accept the aluminum barrel. Tamiya provides 2 barrels since it's an A-sprue part, so I wasn't too worried about doing this surgery and not having a "plan B" if needed. It wasn't needed and the gun installed fairly easily, the barrel end did require a little bit of clean-up with a needle file but nothing serious.
The commander's cupola is a two-part affair, which means that the join seam that goes right across the top in the middle needs attention. I used some liquid glue to get as tight a join as possible and then came along behind that and sanded the join down. I also chose to position the armored visor cover in the open position although the darn thing kept wanting to slip down into a semi-closed position until it set up...so I had to keep the handling to a minimum.
Step 20 constructs the turret and also presents the option to have the large rear hatch open or closed. There's zero interior provided so since I wasn't planning on doing the included figure, I chose the closed hatch option. While the instructions seem to indicate that you should install the hatch part C4 before you join the turret top to the bottom, I decided to join the turret halves first and then install the hatch later. The two parts have a good fit but this join also requires some sanding to get it to look even. The Char Francais site indicates that there's a weld seam or a casting line around the base of the turret, however when I checked the photos on "Marne", I didn't see any evidence of this so kept the look smooth.  The 47mm and coaxial machine gun mantlets were also installed as separate pieces and took a little bit of fiddling with to get them to sit properly since the gun mount has some play in its installation due to it being elevatable with the polycap mount from the previous step.
The final step is Step 21, it calls for the installation of the turret and the two smoke candles that are to go on either side on the fenders. The candles needed some cleanup due to the fact that their curved end faces are not molded flat, so a large seam/shift line is evident and needs to be taken care of.
That's it for major construction, it's now ready (once I install that part from the step I missed!) for painting.
    August 2006
Posted by Gun Tech on Sunday, February 4, 2007 9:59 AM
Looking good Bill! That one offers a lot of details you will be able to work with in your weathering. Can't wait to see it completed Smile [:)]
Posted by Anonymous on Sunday, February 4, 2007 10:36 AM
Looking great! An interesting piece!
    June 2006
Posted by SteveM on Sunday, February 4, 2007 11:06 AM
A whole week without BillBoohoo [BH] What the Censored [censored] am I gonna read for the next seven days? Oh, well, s'pose I'll have to work on my own model!
Safe travels, Bill.
Steve
Steve M.
On the workbench: ginormous Kharkov dio
    July 2004
Posted by wbill76 on Sunday, February 4, 2007 11:17 AM
Anthony, thanks for the comments!
GT, so many possibilities with this one from a weathering perspective, I'm looking forward to it!
Steve,
Thanks, going to be hard knowing that I won't be able to do any work until I return on Thurs/Fri. Big Smile [:D]
As a quick side note, here's the correction from back in Step 17.
    June 2006
Posted by SteveM on Sunday, February 4, 2007 11:33 AM
When my wife suggests a trip, vacation or even a long weekend to the coast, my brain starts calculating time missed at the bench. She knows it, I know it. The blank expression on my face reads like 72 point print. Am I wrong for this?
Steve
Steve M.
    December 2003
Posted by buff on Sunday, February 4, 2007 6:19 PM
Steve
Not a chance.  Just try convincing her of that.
    April 2006
Posted by FingersEddie on Monday, February 5, 2007 12:06 PM
Well done Bill, its nicely built up!
    July 2004
Posted by wbill76 on Tuesday, February 6, 2007 4:50 AM
Steve,
I agree 100% with buff. Big Smile [:D]
Fingers,
Thanks as always! Mind's already working through the paint/finish/weathering approaches. Wink [;)]
    July 2004
Posted by wbill76 on Saturday, February 10, 2007 6:28 PM
Had the chance to put in quite a bit of time today with the AB. Efforts started off by putting down a primer coat of Italian Dark Brown. I didn't go with the usual Flat Black primer coat this time around because I 1) don't know what kind of primer color the French used and 2) didn't want the stark shadows that a Flat Black would produce for the two-tone camo. The Italian Dark Brown seemed like a good compromise, it was dark enough to insure none of the light-tan Tamiya plastic got overlooked and would provide some decent shadow/contrast for the camo so I ran with it. Just as I was finishing up, I managed to get a drop of thinner on the rear deck which produced a nice perfect round spot on the engine deck hatch. Thankfully, it was only the one drop and not a flood as it could've been!
One of the chief advantages of a primer coat, besides providing a surface for painting, is the opportunity it provides for checking seams and sanded areas to see if they really are as smooth as they looked before painting. This time around I found two areas that needed more attention. The first was the driver's hood, the putty and sanding that I'd done earlier wasn't quite even, so I stripped off the paint and sanded it back down again. I used a q-tip dampened with thinner to remove the paint vs. scraping it away so I had a nice large area to work with and not have to worry about fouling the sanding stick with paint in the process.
The second area that needed attention was the join on the turret on the right side. An ever so small step had been left behind and the paint showed it up crystal clear, so it too was stripped and sanded down.
Once those areas were taken care of, I laid down the first color of the 2-tone scheme. I chose MM's Khaki since they have it listed as the French armor "green" and applied it with the general purpose nozzle on my Aztek at about 20 psi. I used it to sketch out the pattern instead of an overall coat, using the finishing guide supplied with the Echelon decals as a template. I figured this would give me more freedom with the second coat in terms of visualizing the overall pattern and also conserve some paint in the process. Wink [;)]
For the second color, I mixed up some Dunkelgelb with Light Gray in about an 80-20 ratio more or less in a spare mixing bottle. I wanted a lighter shade vs. the standard dunkelgelb and was trying for more of a "stone" color with the combination.
This was applied with the same nozzle and psi as the Khaki and the rest of the pattern was filled in and adjusted. I did have to go back a couple of times with both colors to correct for overspray and fine tune things a bit, but all of it was done freehand and after a couple of hours, the pattern was completed to my liking.
I'll let this set up overnight and work on the tracks and tools to round it out in terms of base finish tomorrow most likely.
