the doog wrote: |
Plastic_Punisher wrote: | .....what dont you like about future? i know alot of people love it, just wondering why you dont use, to each his/her own, but im just curious. |
The "Future" question has been hugely-debated here, but I will suffice to say that, on acrylic-painted models it is simply an unnecessary step. It can be, and is used on enamel-painted models, and as an acrylic barrrier, it helps to protect the delicate enamels coat from thinners used in washes and filters. So if you use enamels to paint, you're probably going to want to use it. My main peeve about it is that it is soooo "high gloss"--requiring more additional flat coats to tame it. You just don't need to do that on acrylic coats. I've also seen some problems associated with it that I would just rather not risk. |
Good morning Doog,
I couldn't agreee more that the Future debate is hugely debated and does, in the end, come down to personal preferences.
At the risk of speaking out of turn, however, I will express my advocacy for using Future (or other type sealant) especially over acrylic bases. Acyrlic paints by their vary nature are pourus vs. enamals and will eagerly soak up any topical layer what is applied. Now, that can be used to good effect if those are the results you are looking for, but I find that it is very easy to "loose control" ending up with an overly dark presentation. Once the acrylic has been "stained" there really is no turning back.
If, however, you have a protectant seal, ie Future, then I feel as though I have a lot more flexibility, or a safety net if you will, to make adjustments. While still damp a wash can be manipulated to remove excess. Futher, by the very nature of a "slippery" surface, techniques such as pin washes will be much more effective due to the lessened flowing resitance vis-a-vis over acrylics only.
Addionally, the glossy surface provides the perfect platform (if not required) for the successful application of decals to prevent silvering.
As for the "sooo high gloss" aspect, yes in the beginning you do have a very shinny model. But, it has been my experience that the results of the subsequent weathering steps (especially the use of artists oils) that nearly all, if not all of the glossyness is matted. If not, then I have found a light misting of Model Masters Flat Clear does the trick.
In the end, however, it is personal preference. It is particularly during the painting and finishing steps that our "individuality" is allowed to flourish. Happily, there is no right nor wrong way, only the way which best suits the individual modeler.
thanks,
Rick
