Bodge wrote: |
Saying that i thought they were the right tracks anyway,Maybe this needs pointing out to Tamiya,i will have to do some research into track types 4 tiger twos and have a look. Any one got any ideas |
There were 4 types of tracks for the Tiger II.
The very early style Gg 24/800/300. The tread link is identical to the one on your model in that it had 2 tread surfaces with raised cheverons. The connecting link was made up of a large center link with three smaller links next to it, one on the inside and two on the outside of the track, this type of track used a 18 tooth drive sprocket. It was also used on some Jagdtiger, the jagdtiger in Bovington is fitted with them.
The next type is Gg 26/800/300. This is the more common type of track and the one you would see in most Tiger II kits. The tread link is the same but the connecting link is now in one piece and not four as it was before, this track uses a 9 tooth drive sprocket. This type of track is mounted on the Tiger II with production turret and zimmerit at Bovington.
The next type is Kgs 73/800/152. These are the late style single link tracks much like the Tiger I and Panther tracks, where all links are identical with one tread surface each. These are not seen on production vehicles until March 1945, however there are a few vehicles that had them installed during the battle of the bulge, and atleast 2 vehicle with the so-called "Porsche" turrets also had them fitte, probably as a test. The Tiger II with the Porsche turret at Bovington is fitted with these tracks, how ever these have been fitted to the vehicle by the museum after the war, originally it had the Gg 24/800/300 tracks.
The last type is ofcourse the transport tracks, which is a narrower version of the early Gg 24/800/300 tracks, made up of a narrow tread link and only using the large center piece of the connecting link, omitting the 3 smaller cennecting links.
As your model is a Porsche turret it could have been fitted with either the Gg 24/800/300 or the Gg 26/800/300 tracks. Your model doesn't have the armored cover over the snorkel on the rear deck, it has a two piece gun tube and it has 5 bolts in the rear most side skirts this means it does not represent a very early Porsche turret and thus the Gg 26/800/300 tracks would be correct for this model, and that is exactly what is pressent on your model.
