PAGE 3 ALL FINISHED! "Checkered Past" Rusty Impala vignette
    January 2007
Posted by the doog on Wednesday, April 21, 2010 7:29 PM
......aaaaaaaaaaand here's another update! Big Smile
I have completed the car itself; now all that's left to do si to construct the simple dio base.
From here, I will show how to complete the weathering and snow cover on the model. First, here are the products I have used for completion of the weathering. From top left--MIG Pigment Fixer; MIG pigments P024 Light Rust and P230 Old Rust; 502 Abteilung (MIG's oil weathering line) #060 Light Rust Brown; #070 Dark Rust, 020 Faded Dark Yellow (which is really a light orange); and standard Raw Umber and Burnt Sienna Deep oil paint.
I start by applying a varied combination of oil colors in the exposed dark rusted area, and then I pull them down to make streaks. Use a variety of the colors, and put dark colors first, and lighter colors on top, because new rust is lighter.
When I had good coverage and was satisfied with the results of the streaks and drips, I used a brush to apply MIG's weathering pigments right onto the still-wet pigments, which actually help them to adhere to the model.
Notice the texture that the pigments lend to the rust. To seal them in permanently, I use MIG Pigment Fixer. Just use a brush to drop the stuff rightonto the pigmented areas. Capillary action will spread the liquid into the pigments, fixing them fast.
I also used a larger brush to "bounce" on rust spot from oil. A larger brush also helps make different dimensions of streaks as well.
Next, in order to get more layers of variety in the finish, I took some craft store white acylic paint and dabbed on some pure white in areas.
Results so far:
 I cleaned up the front fender a little with that white paint. The wheels were given a wash of tan oil paint, and a light wash of rust colored oil in the hubs...
ADDING THE "SNOW CAPS"
Now it's time to add the "snow". For this I use a paper-mache type of product called Celluclay. First, I add both WHite Craft glue (1), and acrylic paint (2) to the powdery product. I add a little bit of water to it, stirring always, just enough to wet the whole mess. Many people who claim to have problems with this product do so because they don't add glue and add too much water. Celluclay will shrink as it dries; the ore water, the more it will shrink. To counter this, I scoop out the bulk of it onto the sleeve of an old T-shirt, (3) and squeeze the excess water, glue, and paint out. (4).
I then scoop out the clay with a cocktail stick and start to apply it to the appropriate areas.(1). I wet my fingers with water (2) to help shape it, and also use a wetted paintbrush to carefully shape the edge. The water on the brush will both shape the perimeter as well as cleaning the window from any glue-haze.
\The three areas have been completed. After this step, I let the model sit overnight to let the celluclay cure and dry. In the morning, I put it inside of my real vehicle, on the dashboard n the sun with the windows up, in order to speed the drying/curing process.
 Next, after making sure that the celluclay was hard, I painted it with white acrylic paint, and then use white Aleene's Craft Glue, which is a really think craft glue similar to Elmer's to carefully cover the celluclay parts.
Next, using Woodland Scenics' snow powder, I carefully shake out a covering of "snow" onto the wet glue. I do ONE SECTION at a time! This glue dries too fast to let it sit around.
 I applied a copious amount, and tamped it down with my fingers
I let it sit for about 10 minutes, and then turned the car over to get rid of the excess, and here's the result!
Now comes making the base, which is being varnished and sealed at the moment. Stay tuned, and thanks for any comments or critiques! Comments are appreciated and welcomed!
    April 2008
Posted by smeagol the vile on Wednesday, April 21, 2010 7:46 PM
Your builds never cease to amaze me.  Some to the things you do would never had occurred to me otherwise, like the carpet, or the snow.
Yes
    February 2009
Posted by scratchmod on Wednesday, April 21, 2010 8:15 PM
Hey Karl
Nice to see you back to rusting up some cars. Would be better if it were armor, but as long as it's rusty I'll be looking. The crackle medium is pretty good stuff, glad it worked with great effect. Can be tricky to always get the same result. You seemed to have nailed buddy.
Cool work with the snow, looks too real. Yes
Gotta love the oils and pigments. awesome work on that car.
Rob
www.scratchmod.com
    July 2006
Posted by redleg12 on Wednesday, April 21, 2010 8:26 PM
OK.....I'm itchy being over here Smile Dots....but had to see what you are up to....Very nice work...the usaual king of weathering look.....I see the references to BMF and I keep thinking you are talking about me Whistling
I think you have found one of your true callings in rust. It looks fantastic....some of the armor weathering translated well.
Now when you are through with being Mr Sanford,
 we will keep a spot warm for you back over in armor.....its time to build something that clanks and can go BOOM in the night!! Wink
Great job as always
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    June 2008
Posted by jtrace214 on Wednesday, April 21, 2010 9:53 PM
Karl,don't know how you do it....(Yes I do you showed us lol) but each build tops the last. Very impressive build,and thanks for the tut.
John
the pic to the left is my weekend condo lol
    January 2007
Posted by the doog on Thursday, April 22, 2010 9:14 AM
Thanks, smeagol! That makes me happy to hear--that you get ideas from my builds. That's the whole point and reward for me! I appreciate your comments!
Rob--I was hoping you'd look in on the car! I thought that the cracked paint was probably something you'd have come across--it could be very useful in future projects! Thanks for the nice words!
Mike, thanks for coming over to the neighborhood and for your funny comments!! Wink I should be back to Armor before the summer some time....you keep things organized over there til I get back! I appreciate your comments!
Thanks too, John, for your very generous compliment!
Stay tuned, guys, to see the completed project with the dio base! Smile
    July 2003
Posted by zokissima on Thursday, April 22, 2010 7:28 PM
Absolutely beautiful result!!!
    October 2008
Posted by oddmanrush on Sunday, April 25, 2010 3:42 PM
Karl, Incredible work, so life like, extraordinary. I appreciate the tutorial for this project. I just picked up Revell's '41 Chevy pickup and I was hoping to use your build as inspiration. Won't be for a while though as I've got some other kits in line first. But seeing this, I'm very excited to get going on it. Again, great work.
Jon
Jon
My Blog: The Combat Workshop
    January 2007
Posted by the doog on Sunday, April 25, 2010 6:54 PM
Thanks, both--Zokissima and Jon! I appreciate you both looking in and taking the minute it takes to comment!
Jon, good luck on your build--please post some pics of it if you get it started! Big Smile
    November 2008
Posted by PaintsWithBrush on Monday, April 26, 2010 10:40 AM
Another fine bit of work of an all too common subject. Just breaks my heart to seen on old warrior cast aside like that.
Your build could be described as a memorial to the fallen.
Regards, PWB.
A 100% rider on a 70% bike will always defeat a 70% rider on a 100% bike. (Kenny Roberts)
Posted by Jim Barton on Tuesday, April 27, 2010 3:49 PM
Fantastic job!YesYes
By the way, I was reading the January, 2008 Fine Scale Modeler today and saw your article "Deconstruction Construction." Another great build!
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    January 2007
Posted by the doog on Wednesday, April 28, 2010 7:49 PM
Thanks, Roger and Jim!
"A memorial to the fallen"--that's a cool alternate title! Big Smile Thanks, bud!
Jim, you can see that I like these old wrecks! All I have to do now is to get some more "Rust bunnies" for this dio, lol! I appreciate your comments, and compliments!
THANKS, GUYS!!
    January 2007
Posted by the doog on Thursday, April 29, 2010 10:10 PM
Hey all! Here's the last update!
Well, here's the base tutorial. The diorama is complete!
First of all, MAKE SURE that you varnish and WATER-SEAL your base plaque! I use MINWAX "Indoor/Outdoor HELMSMAN Spar Urethane Clear Satin" spray-on sealer. Two heavy coats does thetrick perfectly. If you don't seal your wood, you will get warpage from the wet celluclay! I started by mixing up some celluclay with some white craft glue and some brown craft store paint for both added adhesion and color..I masked the edges of my plaque with masking tape and applied an even layer of celluclay over the plaque. When I pull up he tape, I get a nice, neat edge that can be smoothed with some water on your finger.
Here's the stuff I used for the base foliage---WOODLAND SCENICS' "Harvest Gold" static grass powder, real leaves, Joefix Studios "fall leaves", and real, sifted dirt taken from a construction site, where it's been pounded fine, and there is no "Live" organic material in it that might start sprouting! I mix them all up into a nice, fine mixture...
I put this down over a good slathering of white glue....I threw in some "logs" and sticks..
I used a piece of paper to press down the mixture into the glue...
I sealed the mixture in with a light coat of Dullcoat. After this has dried, I put the car down, and take some thread and delineate the borders of where the snow will fall, as per the photograph. I trapped the thread under the masking tape protecting the base edges.
I used my airbrush to lay down some flat white where the snow would be. The car is NOT attached yet at this point! It is shown here only for reference. I do this with the paint because when I put down the snow powder, the powder is not realistically dense enough once it falls into the lacquer spray that I will use to stick it to the base. It will look anemic and thin without the paint's help!
Now, I mask the base where I don't want any snow to be ...and after I hit it with a good coating of Dullcoat  I layer on a good coating of Woodland Scenics' Snow powder.
Using a pick to poke holes into the base, I secured various twigs and a leafy product from Joefix Studios called "Zeeschuim" as weeds, as well as some stuff from AC Moore's floral section. I've also placed some Joefix leaves and various real twigs.
And it's done! WAHOOO!!!
Again, the real car...
and the model.....
That's it for now--thanks for everyone who followed this thread, and who rated it 5 stars! I SINCERELY APPRECIATE THE SUPPORT!! On to the next project--no, I don't know yet what that will be! Confused....Big Smile
    May 2005
Posted by Bgrigg on Thursday, April 29, 2010 10:23 PM
Karl, the base looks terrific and this is easily one of your best builds I've seen.
I present you with this Hammer, for you have NAILED that build!
So long folks!
    September 2007
Posted by SuppressionFire on Friday, April 30, 2010 5:18 AM
Can't hang that vignette on the wall....
ITS OFF THE HOOK!
Bow DownBow DownBow DownBow DownBow Down
I see many IPMS Gold awards in your future... Clear some room on the trophy shelf for a few 'Best of show' awards as well!
Your immaculate eye for detail, techniques and execution of said skills are second to none. Thanks Doog for the excellent WIP's and tutorials.YesToast
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    April 2008
Posted by smeagol the vile on Friday, April 30, 2010 1:18 PM
Hey Karl, I love those leaves you use, they always look great, I remember oohing and aahing at your lair of the rust bunnies, they really make the dios.
Can I put in my 2 cents about the base, every time I have made a base using celluclay (haven't done much, but I like the outcome) to get a better ground texture what I do is mix some pebbles/gravel into the celluclay so when I put it down they either come through as small stones or give the ground a bit of more realistic texture.
dunno if that helps or a good idea, but I thought id throw it out there
    October 2008
Posted by oddmanrush on Friday, April 30, 2010 1:28 PM
Karl, in the words of Ed Olczyk, this is "tremendously tremendous"! Love your work!
Jon
    August 2006
Posted by ogrejohn on Friday, April 30, 2010 4:10 PM
Excellent work Doog!
    January 2007
Posted by the doog on Friday, April 30, 2010 9:05 PM
Thanks, Bill! I appreciate the "Hammer", lol! It looks just like one of our old album covers!
Thanks too, Jason! Your generous praise is much appreciated! I"m glad that you have learned and been inspired by my WIPs!
Smeagol--thanks too.Yeah, I love those leaves too! They're actually dyed birch tree seeds--I've got to get some from the forests around here; they're "Out of stock" at the place I get 'em! As far as the Celluclay, I sometimes put small stones in the clay, but I usually as that in the second layer--the"dirt" cover. I use the Celluclay as a literal "base" and then put a ground covering over that, whether it be grass, forest litter, or dirt and stone. If I want a big rock in there, I DO put that in the actual "base" clay. Thanks for the input--I"m sure it will give others who read this thread ideas as well!
Thank you, Oddmanrush! I am grateful for your comments!
Thanks, too, John! Big Smile
    May 2006
Posted by Dr. Faust on Friday, April 30, 2010 9:22 PM
Thanks Karl for taking the time to post this wonderful WIP from start to finish.
I enjoyed it and learned ALOT.
Thanks again,
Dr
Just build it (and post pics when youre done)
    April 2008
Posted by smeagol the vile on Friday, April 30, 2010 11:30 PM
Let me ask you this karl, if you use a large rock (I did and had issues though it still looks good) how do you go about texturing the ground without getting any coloring on the rock, or do you do ALL the static grass and ground work before hand in one of those tubs?
    January 2007
Posted by the doog on Saturday, May 1, 2010 9:10 AM
Smeagol,
Since I use white glue (Like "Elmer's") to secure the groundwork AFTER the celluclay, I would just "paint" the glue around the rock and that would take care of any issues. To paint around it, I would just be careful with the airbrush. However, if you need to spray Dull coat to stick powder, you could mask the rock with Silly Putty--just stick it on and pull it off.
As far as the groundwork, I generally mix all the elements in a tub--that mimics the way that it all gets mixed together in real life. Once I put it down, I look at it after it has dried, and then add individual elements--grass, extra leaves, twigs, branches, etc. where I think it needs it.
    April 2004
Posted by vespa boy on Saturday, May 1, 2010 10:59 AM
Karl, you really captured the feel of the real car beautifully. I especially like the piled snow. It gives the dio a specific time of year and also helps explain the condition of the car. The birch seeds work really well. (I also use them mixed with other garden litter for groundwork.) You tell the story of the car in a quiet, understated way. I think this is your best yet imho.
http://public.fotki.com/nkhandekar
This ain't no Mudd Club, or C.B.G.B.,
I ain't got time for that now
    April 2008
Posted by smeagol the vile on Saturday, May 1, 2010 6:45 PM
Hmmmm, when I used the rock in the base I made I had stuck the rock into the celluclay before it dried.  Gave it a really nice look of actuially having been there for quite a while.  Do you spray the diffrent groundworks in the tub with your AB to color them, or leave them as is?
    January 2007
Posted by the doog on Saturday, May 1, 2010 10:10 PM
Steven. sometimes I'll spray the groundwork when it's on the base, but if I sprayed it in the tub, it would blow all over the place! Surprise
Those "leaves" are already pre-colored, so they give a nice variety as is
    January 2007
Posted by the doog on Saturday, May 1, 2010 10:12 PM
Dr. Faust
Thanks again,
Dr
Thank you, Dr Faust! (Sorry I missed your post in replying!) I'm happy that you've learned a little from it--now let's see your own junker! Big Smile
    January 2007
Posted by the doog on Saturday, May 1, 2010 10:15 PM
vespa boy
Thanks, too, Narayan! That's some high praise indeed,
I'm happy that you think it's a worthy effort,. and I thank you for the kind words!
Those "leaves" really do give the whole build some "atmosphere", don't they? So far, I've used them in every "junker" scene. And I just ordered some more bunnies! I think that a "Snowshoe hare" would look cool in this one! Stick out tongue
    July 2006
Posted by redleg12 on Sunday, May 2, 2010 6:33 AM
Karl - As usual your ground work is tremendous....nice work....love the look
See you when your clanking again!!
Rounds Complete!!
    May 2006
Posted by Dr. Faust on Monday, May 3, 2010 3:00 PM
[View:/themes/fsm/utility/Photobucket:550:0]
the doog
 Dr. Faust:
Thanks again,
Dr
Cool, The only junkers i'm working on presently are my dirt bike restros. An 1979 cr125 and a 1981 cr250 lol
Like my bro said "they are just big models"
I'ts keeping me busy.
Ride On!
the last one is my race bike  2001 CR250
sorry for the hijack
Dr[View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0]
    January 2007
Posted by the doog on Monday, May 3, 2010 4:36 PM
Thanks alot, Mike! I hope to be back over in the field before the end of the summer! Smile
Dr Faust--WOW, those are some old horses! Very cool stuff!
I once rode a Suzuki PE (?) that was quite the ride. I ride an old '97 Suzuki RMX250--I've got two identical ones, with FMF pipes, and all the standard mods--Boyeson reed, Wiseco piston, etc. Also got some trick parts from a Czech company that sponsored me for some years. Here's my current racing one, on the line at a Hare Scrambles in New York...
Hey, isn't that CR one of those with the brutally stiff aluminum frames? Didja have to revalve the suspension? Mine is redone for the woods--really plush.
