WIP Tamiya 1/12 scale Ferrari 312T (Updated April 29)
    May 2013
Posted by Greg on Sunday, March 21, 2021 2:56 PM
I'm very fond of the Tamiya 1/12 formula series  models.
You're doing a great work, as usual. Fun to watch, thanks for the WIP.
Yes
    March 2015
Posted by JohnnyK on Friday, March 26, 2021 11:16 AM
The weather has been wet and cold, which means no garden work. However, I now have some time for modeling work.
The kit does not include seatbelts, so I orderered an aftermarket set of belts. Included are cloth belts and PE buckles. The weird thing about the instructions is that they do not indicate how long to cut the belts. So I used the belts in my 1/12 scale Lotus as a guide.
The final result looks nice. However................................
OH NO!!!!! I had the seat upside down when I installed the belts. Oops
Luckly, the belts are held in place with double stick tape. It was not too difficult to correct my mistake.
    March 2021
Posted by carmad1957 on Saturday, March 27, 2021 6:29 PM
Goodness gracious Johnny K, just don't know quite what to say! No doubt I'll be watching this one come to life! Not only is that some exceptional work so far, but a true inspiration for yours truly!
2 kudos for Johnny!Bow Down
    March 2015
Posted by JohnnyK on Monday, March 29, 2021 1:08 PM
The ignition module with associated wiring has been installed and the fuel filter and hoses have also been installed. Note the clamps on the ends of the fuel hoses.
    March 2015
Posted by JohnnyK on Wednesday, April 14, 2021 1:34 PM
The weather is too crummy for gardening, so I'm back to modeling.
The fuel supply hoses and oil hoses have been installed. This thing has more hoses than Home Depot.
The rear suspension is complete. The only thing remaining to be finished are the front suspension, body panels and decals.
    March 2015
Posted by JohnnyK on Wednesday, April 14, 2021 2:42 PM
Detail of rear suspension.
    March 2015
Posted by JohnnyK on Friday, April 16, 2021 2:12 PM
UPDATE APRIL 16
Time to assemble the front suspension and steering. The front suspension and steering are composed of 51 parts. It takes a while to assemble the suspension and steering because certain parts need to be preassembled and the glue needs to cure overnight before they can be included in the overall assembly.
Regarding the steering system, it is important that the flat spot on the steering shaft (red arrow) be in the up position and that the rack be centered on the pinion (green arrow) while the steering system is assembled. Otherwise the steering wheel will be offset when the front wheels are straight ahead.
I painted a white dot at the center of the rack and on the pinion when the steering wheel is in the proper position. This helped to keep the rack and pinion centered during assembly.
This is the final assembly. Be careful that you don't reverse the bulkhead. The instructions are not very clear.
The front suspension is fully assembled but something looks wrong. The wheel hub and brake rotor are crooked!!!
The mounting pins (green Arrows) on the hub are offset, which means that there is a right side hub and a left side hub. I assembled them in  reverse.
Fortunately, the hubs snap into the suspension arms so it is easy to correct the problem.
The chassis, engine and suspensions are finished. Time to move onto the body panels.
    March 2015
Posted by JohnnyK on Monday, April 19, 2021 1:00 PM
The body panels were painted Tamiya Italian Red.
First I did a dry fit of the body panels starting with the side body panels.
Next I placed the top body panels (green arrows) onto the tub. These panels were bowed with the ends being higher that the middle.
I used paint bottles to flatten the top body panel while the glue cured.
Unfortunetly the top body panel is warped (twisted). There are some fit issues (green arrows). This panel is designed to be removable, so there isn't much that I can do to fix these fit issues.
    October 2019
Posted by Tanker-Builder on Monday, April 19, 2021 2:02 PM
Hi;
 Yes, there is! Being real careful dip it in very hot almost boiling, water and straighten it out. If once doesn't do it dip it again pressing it in the right direction to get it straight! let it cool naturally!
    January 2020
Posted by wpwar11 on Monday, April 19, 2021 3:33 PM
What type of glue are you using to glue the body parts?  I always struggle to glue painted parts.
    March 2015
Posted by JohnnyK on Monday, April 19, 2021 6:52 PM
Tanker-Builder
Hi;
That's a good suggestion. I have tried that in the past. I have also tried using a hair dryer. Usually, either of those techniques works just fine, However, sometimes they don't work and the plastic part is ruined. This kit is about 30 years old and replacement parts are no longer available. I think I'll play it safe this time.
    March 2015
Posted by JohnnyK on Monday, April 19, 2021 7:17 PM
wpwar11
I am sure that almost everyone will agree with me, I never glue painted parts together. I always scrape or sand the paint off of the plastic prior to painting. The same thing goes with chromed parts.
The body's side panels are made up out of two pieces. These two pieces are pretty big when compared to the knife blade.
I decided to reinforce the joint with metal pins. I drilled holes in the mating surfaces of each part. I glued metal pins made of cut wire into the holes of one part with CA glue. Note that the paint was scraped from the mating surfaces.
After the CA glue set, I coated the plastic mateing surfaces with a thin coat of Testore glue (red label). I let the glue get gooey, coated the pins with CA glue and pressed the parts together. The result is a super strong joint.
    March 2015
Posted by JohnnyK on Tuesday, April 20, 2021 12:54 PM
UPDATE APRIL 20
The decals that came with this kit are unusable. They are yellow from age. I tried to use the Sun to bleach the decals, but that didn't really work. Plus, the decals disintagrate when placed in water. I bought a set of replacement decals  on line. I'll put this kit on-hold until the decals arrive. .
    March 2015
Posted by JohnnyK on Saturday, April 24, 2021 2:10 PM
Update  April 24
The old decals that came with the kit were unusable, so I purchased a set of decals from www.bestbalsakits.com. Very nice decals, however, they are a little thick.
Now this is an annoyance. The decals in the instruction sheet are identified with letters, the decals themselves are identified by numbers.
I'm about half done with the decals. The colors are very dense and there is no color bleedthrough. The carrier film is crystal clear. As I mentioned, the decals are thick which is nice because the pinstriping decals do not tear.
    April 2005
Posted by BigJim on Saturday, April 24, 2021 6:26 PM
That link is very vague. Can you be a little more helpful in what set of decals you ordered?
    March 2015
Posted by JohnnyK on Sunday, April 25, 2021 10:26 AM
Go here to purchase that exact set of decals:
https://www.ebay.com/itm/233884884793?hash=item3674a01f39:g:YskAAOSwxqBgG-~~
    October 2019
Posted by Tanker-Builder on Sunday, April 25, 2021 5:29 PM
Well;
 Hot Diggety Dog! That's gonna be one Purty set of Machinery on Wheels sir!
    April 2005
Posted by BigJim on Sunday, April 25, 2021 8:42 PM
JohnnyK
Thank you Johnny!
    March 2015
Posted by JohnnyK on Thursday, April 29, 2021 3:54 PM
Update April 29
This build is starting to become a real pain. The model is heavy and clumsy. So far I have broken off both oil coolers (yellow arrows) with my thumbs when lifting the model off of my bench. The rear wing bracket (blue arrow) is heavy and is attached to the engine by two short pins.  There was no way to clamp the bracket in place, so I placed the model in a cabinet drawer to place the model in a vertical position while the glue cured.
    March 2021
Posted by carmad1957 on Wednesday, May 5, 2021 7:18 AM
A real pleasure watching this work of art come along! Your work so far is spectacular, will definitely be following as you go. Thanks for sharing the WIP
