Group Build "Star Trek Free For All" Early 2006
    September 2005
Posted by Fish-Head Aric on Tuesday, December 13, 2005 10:15 AM
As to the lighting of other areas of the model, the pack I bought with the glazing paint has red, orange, yellow, green, blue, purple, and two white (fogged) colors, so will be using these to give the shades of colored translucence where ever a light will work.
The photo of the lit nacelle dome above is not doing the right justice to the actual appearance.  The glow is more diffused, and there is not such a bright core look as it seems to show there.  But will mess with that when I get it all together.
Yah, I too have been very busy and not able to give this ship the attention it begs yet, beyond coating the insides of the model for light resistance from within.  I tried rattle-can painting the parts but >gawd< that was an overspray nightmare!  Only the top half of the saucer section came out smoothe!  Rest of it got the rag-wipe treatment!  eeww what a mess.  Back to ground zero on paint.  Am seriously weighing buying an airbrush, but don't want to cough up a lung to do it, so don't have any idea what is reasonable and good without breaking the bank.
~Aric Fisher aric_001@hotmail.com
Posted by Anonymous on Tuesday, December 13, 2005 6:10 PM
If you're looking for a good cheap airbrush I'd suggest a testors aztek you can get one at wal-mart and you should be able to get the compressor there too, the nozzles for the airbrush you can either get at your hobby shop or on their website.
    September 2005
Posted by Fish-Head Aric on Tuesday, December 13, 2005 6:43 PM
What model of Aztek?  I saw one at the LHS that was about $125.  It was a dual-action sort, and had a Testors air compressor for $90.  Being unfamiliar except through what I have read in my model railroading days, there is a concern that the air compressor will give a pulsing effect and not a straight stream.  Is that true?  And please, again, for airbrushes I want something that isn't trash, and will spray a good coat with some flexibility.  What is reasonable to invest in without going broke?
Posted by SNOOPY on Wednesday, December 14, 2005 12:28 PM
I am in the build process of the Daedalus (I was unable to start in the last group build) but I am having problems trying to get the prpoer part made.  I have included a link to photobucket of the sketch of the part. http://i4.photobucket.com/albums/y134/SDL/dad-1.jpg  Any ideas on how to make this part would be helpful.
Scott
    November 2003
Posted by MartianGundamModeler on Wednesday, December 14, 2005 12:53 PM
Hmmm, maybe cut the bottom of a plastic container or cup.
This build will give me the oportunity to do my AMT Refit Enterprise kit bash. I have two. One will be a Nex Gen upgrad constitution and the other a movie era custom. I'll have to decide on which. I also have litte NX enterprise waiting to be bult. That aztec pattern gives me the willies just thinking about it!LOL
"Some men look at things the way they are and ask ' Why?'. I dream of things that never were and ask "Why not?".--Robert Kennedy taken from George Bernard Shaw's "Back To Methuselah" (Thanks to TomZ2) http://martiangundammodels.50megs.com/index.html
Posted by Woody on Wednesday, December 14, 2005 6:42 PM
Scott
Well Scott I'll tell you what I would do. I would cut discs of styrene out and glue them together in a stack.
I would then drill a hole dead center in the stack that will except a bolt that sticks out about an inch. I would then put a nut on the bolt and snug it up. Chuck the bolt in a drill or drill press and grab a dremel with a small course sanding drum attached. As the disc assembly rotates I would remove the waste or high spots until I have the profile I want. Does this make sense?
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by SNOOPY on Thursday, December 15, 2005 6:48 AM
Thanks Woody!  That is something I did not think about of course now I have to see if I can get the Waldron or Specialty hole puncher set.  I tried making discs by cutting out octagonal shapes and doing the drilling of the center and chucking up into a rotory tool and use a file to make it into a circle/disc.  It works okay but your suggestion will probably work better since the laminates will be thicker than my .020 thick disc I was trying to make.  Any suggestion now on how I places the discs so that they are concentric (center being the same on each size disc)?
Is not this the way you made the saucer section on your last build or was there more to it?  I would have tried one with a saucer section but have not gotten past the "I cannot make that shape unless I have expensive fancy equipment" feeling.
One last thing.  How did you get my sketch to actually show up instead of showing the URL link?
Posted by Woody on Thursday, December 15, 2005 12:35 PM
Ooops, Double post. Blush [:I]
Posted by Woody on Thursday, December 15, 2005 12:36 PM
First off to have the discs concentric I would start by making a dimple in my sheet plastic with the tip of a very sharp #11 blade. Place one point of a pair of drafting dividers in the dimple and use the other point to scribe the desired circle. After you have the discs cut out use the center dimple to guide your drill for the center hole.
I used this technique to make the Avengers saucer section.
I copied your drawing to my hard drive and opened it with paint to modify your picture. I then hosted it on my account and reposted it using that URL. The modifications I made to your picture didn't show up very good. Sorry bout that.
Posted by SNOOPY on Thursday, December 15, 2005 5:24 PM
Woody - Thanks for the tips.  I think my build will go a little smoother now.
    September 2005
Posted by Fish-Head Aric on Friday, December 16, 2005 1:17 PM
Woody, is that the current Light Cruiser project?  I love your work!
Posted by Woody on Friday, December 16, 2005 5:02 PM
Thanks. Big Smile [:D] No that was a project I put on a back burner because somebody else offered it as a kit. It is the Avenger Class from Masao's website. It's also the vessel in my sig. Wink [;)] I will finish it when I stop feeling so disappointed about somebody beating me to the punch.
This is the light cruiser I'm going to be doing.
Posted by Anonymous on Friday, December 16, 2005 8:24 PM
Any chance yours is in a different scale?
Posted by Woody on Friday, December 16, 2005 8:52 PM
Everything I do is in 1/1000 scale. It's the perfect scale for me. It doesn't take up too much self space but the models are big enough to lavish detail on.
Posted by Anonymous on Friday, December 16, 2005 9:52 PM
I meant is it in a different scale than the kit that is being produced, maybe the interest in scale will respark your ambition
Posted by Woody on Friday, December 16, 2005 11:24 PM
As fate would have it the other kit is also 1/1000.Smile [:)]
Posted by Anonymous on Saturday, December 17, 2005 1:01 PM
you sure it's not 1/1001? honestly I looked at that kit on the starshipmodeler site and it's kinda sloppy, the windows look a tad bit unrealistic  and the warp engines in every view they look a little warped, I think yours was looking better, but that's my two cents
Posted by Woody on Saturday, December 17, 2005 1:11 PM
Thanks for the kind words. I tried to keep very close to Masao's design. I think the other kit is just based on his design.
    December 2014
Posted by bigjimslade on Tuesday, December 20, 2005 10:03 AM
I'd avoid an Aztek. Worst painting implement I've ever bought. You can get a Paache or Badger double action at a reasonable price. Throw in an air compressor from Sears or Home Depot. $100-$200.
Posted by SNOOPY on Tuesday, December 20, 2005 11:56 AM
I heard that Aztek brushes aren't very good but then again a couple of people have praised them.  I use a Badger double-action and I get great results.  The compressor i have is from Micro-Mark.  Not very expensive and cheaper than the Home Depot ones.  Everyone I have talked to about airbrushing says for beginners or someone with a limited budget, Paasche or Badge is the way to go.  If you go to the Painting Forum here in FSM Forums do a search on Aztek Airbrushes or just airbrushes and you will get a lot of information.  My 2 cents [2c]
    November 2003
Posted by MartianGundamModeler on Tuesday, December 20, 2005 12:15 PM
COUNT ME IN BOYS!  This has given me the opportunity to build my movie era Constitution Class refit/upgrade to Next Generation/DS9/Voyager standards. Here is my work so far...
First I have modified the deflector by cutting it out and replacing it with a soft drink bottle cap creating an Enterprise-B type deflector. The innner lineing will be painted alumminum like on the B...
http://i27.photobucket.com/albums/c191/MartianGundamModeler/deflectorbottlecap.jpg
http://i27.photobucket.com/albums/c191/MartianGundamModeler/deflectorassembled.jpg
I have also removed the bridge, sanded and filled the holes and cut out a hole for the new submerged bridge...
http://i27.photobucket.com/albums/c191/MartianGundamModeler/saucertop.jpg
The warp nacel pylons have been flipped and lowered to the mid line and the prior holes smoothe and filled along with most of the surface tiles. I am going for that Intrepid Class smooth grey skin....
http://i27.photobucket.com/albums/c191/MartianGundamModeler/profilestarboardc.jpg
http://i27.photobucket.com/albums/c191/MartianGundamModeler/portprofilephotorp.jpg
http://i27.photobucket.com/albums/c191/MartianGundamModeler/portprofilefront.jpg
http://i27.photobucket.com/albums/c191/MartianGundamModeler/secondaryfronttop.jpg
http://i27.photobucket.com/albums/c191/MartianGundamModeler/secondaryhullbelly.jpg
http://i27.photobucket.com/albums/c191/MartianGundamModeler/secondaryheadon.jpg
Posted by Anonymous on Tuesday, December 20, 2005 1:58 PM
Interesting interim concept. Nice use of a bottle cap! Keep the progress pics comin'.
    November 2003
Posted by MartianGundamModeler on Tuesday, December 20, 2005 2:53 PM
Thanks. She still has her Wrath of Khan batttle damage on her as you can see. Most of it has been removed some I will keep. She is a Constitution class that was used as a test bed for Defiant and Intrepid class systems.  I have prerun the wires for lighting you can see some of the wires hanging out of the pylons. i had to crak open 20 year old glue and seal them back. I haven't figured out how I am going to make the phaser strips though. It's hard to get anything to curve around the surface of the saucer. Any ideas?
Posted by Anonymous on Tuesday, December 20, 2005 6:48 PM
Phaser strips are a tuffy in bigger scales. In 2500 I just heat up some strip styrene, bent them and sanded them over. You might try a circle cutter at two diferrent radii, making a arch strip, then put notches in some half round in order to bend that to the same arch. Or e-mail Chris Lynch over at Ravenstar and ask him how he does his.
    November 2003
Posted by MartianGundamModeler on Wednesday, December 21, 2005 11:30 AM
Forgive my ignorance but what's Ravenstar? I may try using an Enterprise C style phaser strip i.e. three small curved strips instead of one large "D" style strip. I might can cut them from a container top. I'll just have to experiment some more...lol
Posted by Anonymous on Wednesday, December 21, 2005 5:48 PM
Ravenstar Studios: http://www.ravenstarstudios.com/ Chris has alot of nice designs and is a great guy to boot. The phaser strips on the TNG Odin class have some nice strips, I'm sure he'd help ya out. I'd seriously try to find one of those circle cutters.
Om another note I upsized my Lyran plans so that the ship would scale out at 11", roughly same length as PL E. Next is to draw it on styrene. If I can get far enough on the Lyran, I may follow up with the Kzinti right away.
Posted by Woody on Wednesday, December 21, 2005 6:08 PM
If I was going to do phaser strips I think I would apply RTV mold to the phaser strip on a model. After the RTV set you could then "paint" resin into the female mold you have created. After sanding to the right thickness, a dip in hot water would allow you to gently bend to shape. You might also try half round styrene stock to replicate the strips.
    November 2003
Posted by MartianGundamModeler on Thursday, December 22, 2005 11:51 AM
Molding is a great idea but I have virtually no experience in molding . I have never seen half rounded styrene stock, but i will look for it. I also forgot to add that I shirtened the neck about a half inch as well. Any ideas on replasing the kit photorp launchers. I have tried to scratch some from sheet styrene and styrene "u" shaped strip bit it's hard going. I will probly have to use a single tube like the galaxie class.
Posted by Anonymous on Thursday, December 22, 2005 6:17 PM
Ok, this looks like it could be fun, so I am gonna give it a shot, Im gonna just use the model I have already started on about 2 weeks ago, I am using the PL 1/1000 Conny model, with a few added parts and a whole new scratch built neck, the pylons have been moved to lay flat on the 2nd haul.....any way here a few photos.......
let me know what ya think so far...
http://www.imageuploading.com/ims/pic.php?u=7745kWfyH&i=50074
http://www.imageuploading.com/ims/pic.php?u=7745kWfyH&i=50075
http://www.imageuploading.com/ims/pic.php?u=7745kWfyH&i=50076
Still havent come up with a good name for it class and name wise.....any ideas?
Posted by Anonymous on Thursday, December 22, 2005 7:47 PM
Another very interesting variant design, nice work so far(and welcome aboard). Sorry no class names hitting me at the moment.
Bought some pieces and glue at the local railroad shop, I'll be laying the keel, so to speek, for the Lyran Tiger tomorrow. I'll take pics as I go.
