Nagato CAD line fix.
    November 2004
Posted by gsharris on Thursday, August 21, 2008 6:58 AM
JMart thanks for the warning.
Scott Harris
    March 2007
Posted by searat12 on Thursday, August 21, 2008 12:36 PM
...Then i reckon it won't help muh broken pigs much neither!
    September 2005
Posted by warshipguy on Friday, August 22, 2008 10:16 AM
GSharris,
I simply mask of the particular line that I am working with, fill the line with Porc-a-Fix using a microbrush (I am trying to limit exposure to the rest of the hull), allow each coat to dry before filling the line again (and again, and again, ad infinitum) until the recessed line becomes a raised line. Then, I sand it using fine grit sand paper until flush with the hull.  I have noticed some shrinkage between fills, but it is a minor issue.
For those who would rather use putty, I found a better solution to Squadron putty.  Try "Mighty Putty" found in the "Sold on TV" section of stores like Wal-Mart.  It is actually a putty/epoxy mix that is easy to handle, dries quickly, and sands easily.  It is far less messy than other putties and can be rolled safely and finely to fill any defect.  It also dries in the shade of gray that Nagato is molded in.
I hope this helps!
Bill Morrison
    March 2007
Posted by searat12 on Friday, August 22, 2008 1:11 PM
So far, it sounds like the 'White-Out' method appears to be the easiest and cheapest.......
    September 2005
Posted by warshipguy on Saturday, January 10, 2009 2:17 PM
I was discussing this problem at my local hobby shop and another customer showed me the easiest method yet . . . Testor's Contour Putty!  I have never really noticed this product before, always using Squadron Green and White putties.  For those as unfamiliar with this product as I was, it comes in the same type of tube as plastic cement with the same dispenser.  Just draw a line inside the CAD line with the putty, wipe away any excess, gently sand as necessary, and it is filled.  In fact, he had just bought the Mutsu while we were talking, so he gave us a quick demonstration.  It works!
Bill Morrison
    March 2007
Posted by JMart on Thursday, January 22, 2009 6:18 PM
great tip Bill... was also thinking about cutting the putty with some acetone-containing nail polish, that was you can wipe the excess with a cotton swap Qtip,leaving very little sanding at the end.
    September 2005
Posted by warshipguy on Friday, January 23, 2009 11:42 AM
Great idea, JMart!
Bill Morrison
    March 2007
Posted by searat12 on Friday, January 23, 2009 2:42 PM
Wouldn't the acetone melt the plastic?
    April 2005
Posted by ddp59 on Friday, January 23, 2009 3:54 PM
if left on then yes.
    September 2005
Posted by warshipguy on Saturday, January 24, 2009 6:55 PM
I have used acetone-based nail polish remover for decades as a paint remover and as a super-glue debonder.  I have never had a problem with melting plastic.  However, I do remove it fairly quickly.
Bill Morrison
    March 2007
Posted by searat12 on Saturday, January 24, 2009 8:38 PM
Hmmmm.... The 'whiteout' version sounds less dangerous...
    September 2005
Posted by warshipguy on Saturday, January 24, 2009 8:45 PM
Less dangerous than using Testor's Contour Putty designed for plastic models?
Bill Morrison
    March 2007
Posted by searat12 on Saturday, January 24, 2009 8:47 PM
Less dangerous than smearing acetone all over the hull and watching all the detail melt away....
    September 2005
Posted by warshipguy on Saturday, January 24, 2009 10:26 PM
Eric,
That is why I have switched to Testor's Contour Putty.  It is designed for use with plastic models, and it comes from the tube in a thin line that fills each CAD line to perfection.  It is so very easy to use.
Bill Morrison
    March 2007
Posted by JMart on Monday, January 26, 2009 6:15 PM
The amount of acetone in nail polish remover will not melt the plastic. Aircraft modellers have been using this technique for years to fill out/smooth fuselage center seams:
http://www.aircraftresourcecenter.com/tnt1/001-100/TNT029_Filler_WO_Sanding/tnt029.htm
http://www.swannysmodels.com/Seams.html
works with squadron white or green putty. Will NOT work with the Mr Surfacer line of products
Dont knock it if you have not tried it....
    March 2007
Posted by searat12 on Monday, January 26, 2009 7:27 PM
Not knocking it, just don't want to risk it on a $250 model if there are less inherently dangerous options.......
