Lindberg 1/95 Nantucket Lightship FINAL?? 6-03
    January 2008
Posted by DerOberst on Monday, May 11, 2009 10:56 PM
 EPinniger wrote:
I built Frog's kit of the British "South Goodwin" lightship (in about the same scale) earlier this year (http://www.shipmodels.info/mws_forum/viewtopic.php?f=60&t=39427). I've now bought the Lindberg Nantucket lightship too (most of the Lindberg reissues are now available here in the UK) and plan to build it in a year or so.
Wow!  Your work is terrific!  Great work on a rather ungainly subject.
Good luck on your Nantucket build!
    January 2008
Posted by DerOberst on Monday, May 11, 2009 11:00 PM
 hazegry wrote:
this is great I love light ships. I have a question though do you think this would be ale to adaptable to RC? if so I am going to have to look into it. you have done a great job its gonna look super!
This is ready for RC right out of the box.   Push it out into the pond, drop anchor, wait 90 days.  Voila!  Lighthship in action!!
Seriously, it has a big sturdy hull and a large single prop.  So am sure you could make that work. And if you got creative, I am sure you could rig the lights to at least glow!
    May 2009
Posted by hazegry on Tuesday, May 12, 2009 11:43 AM
That will work actually my rc club is doing more and more indoor demos and this will be perfect for the pool. I dont plan on zipping it around the pool just floating around and maybe I can get the anchors to work have it go out drop anchor and then start the lights up.
    May 2009
Posted by hazegry on Saturday, May 16, 2009 11:19 AM
wife just ordered this kit for me she heard me talking to a friend about it and ordered it yep shes a keeper.
    January 2008
Posted by DerOberst on Sunday, May 17, 2009 7:25 PM
Wow! That is awesome.  Be sure to post some pictures.
(Of the model, not the wife...)
    January 2008
Posted by DerOberst on Monday, May 25, 2009 9:54 PM
Time for an updated set of pictures and a request for help.
I need to figure out what to do with the searchlight looking gizmos on the bridge.
The large one I drilled out, painted silver, and filled with clear.   It looks slightly yellow and somewhat transparent.
I have no idea what the rest of the gear is, so I have no idea how to paint it.  Help!
The model is close to done.  I have to glue down the deckhouses and masts, touch up some painting goofs, and then do the rigging. The rigging you see is just an experiment.  I added attachment points for the wires on the masts.
I have done some weathering, but the flash washes it out a bit.
Comments and suggestions appreciated.
And help me decide what to do with the signal gear!
    June 2008
Posted by Spotty on Tuesday, May 26, 2009 6:08 AM
I LOVE what you've done. Great fun!
    May 2006
Posted by thunder1 on Tuesday, May 26, 2009 9:51 AM
 In answer to your question(s)...the two smaller electric "lamps" were used as spot lights and had vanes mounted on them so they could be utilized as signal lamps, i.e. flashing lights to communicate with other vessels. As to your last photo, going from left to right on the bridge roof(flying bridge) the equipment is spot/signal lamp, compass binnacle, large search light, engine order telegraph, spot/signal light. For some reason your model is missing the ship's wheel which was mounted behind the binnacle. Perhaps the new release doesn't provide one...I'm going by the original PYRO instructions from 1955. Also the bell mounted on the pilot house(bridge) would never be painted, so a little brass paint would fix that...and that thing that looks like a hocky stick molded into the bridge front is a fog nozzle, attached to a fire hose used to apply water in case of fire, it shoul be painted red...and your running light boards should be painted black as white paint would be too reflective and cause the red/green lights to exhibit the wrong type of illumination on the real ship.   As to the painting of the items on the flying bridge, white is appropriate, however the face of the engine order telegraph should be painted black, as it was glass on the real ship with all the attendent lettering on it's face. Of course in this scale it would be a tough thing to achieve...Big Smile [:D] As to the signaling...I'm guessing you refer to the signal flag halyards...they would be attached to the masts' antenna spar, two to each side. The halyards(rope) would be tied off to the safety railings on the flying bridge. When I served on the NANTUCKET we only utilized the halyards to run up our radio call sign flags leaving and arriving home port...
the only difference between the NANTUCKET lightship and the county jail is the fact the jail can't sink....
Mike M. Lightship sailor
    January 2008
Posted by DerOberst on Tuesday, May 26, 2009 10:58 AM
Mike,
Thanks for the input.  I will have to digest this in detail, but a few off-the cuff responses:
The wheel is still on the sprue waiting for paint.  I was keeping it off until I painted the other gizmos so I could still get to them.  I was planning to paint the wheel as varnished wood.  Is that correct? Or was it steel painted some color?
I was planning to paint the bell, just have not gotten there.
I have not painted the 'hockey stick' yet because I was not sure what color (red!) and because I was debating making a new one.  I don't really like the on that is on there and might make a scratch built one.
As for the rest, I will get busy making changes!!! Thanks again for the input.
    May 2006
Posted by thunder1 on Tuesday, May 26, 2009 1:53 PM
Peter
 The ship's wheel on the NANTUCKET were of brass construction, as was the pedestal. On the flying bridge the wheel was not painted(the wheel pedestal was painted white) but was usually kept protected with a canvas cover to minimize the dulling of the brass. Still the Atlantic sea envoirment would give the brass wheel a  green "patina" and depending on the ship's skipper, the flying bridge wheel was polished on a weekly basis, weather permitting. The wheel in the pilot house was polished daily, it gave the man on watch something to do... If you make a fog nozzle from brass wire(or stretched sprue) it would enhance the models appearence rather than just a "blob" on the bulkhead. Well, you're really going to town on this kit, I'll be interested to see how it turns out.
    June 2006
Posted by Grem56 on Tuesday, May 26, 2009 2:05 PM
That really is a beautiful build. A bit too clean Big Smile [:D] Must be all those "Coasties" doing overtime Smile,Wink, & Grin [swg].
Julian Smile [:)]
illegal immigrants have always been a problem in the United States. Ask any Indian.....................
Italeri S-100: http://cs.finescale.com/FSMCS/forums/t/112607.aspx?PageIndex=1
Isu-152: http://cs.finescale.com/FSMCS/forums/t/116521.aspx?PageIndex=1
    January 2008
Posted by DerOberst on Tuesday, May 26, 2009 4:17 PM
Julian Smile [:)]
Funny that you think it is too 'clean'.  The pictures don't really show how dirty this model is.  Remember, I am a tank guy, so when I do weathering....
The life boats look like a rugby team was rescued from a muddy pitch.  The deck has been washed with enough black-wash to make it look like a coal freighter. The hull has rust and oil coming out of the scuppers.  The sides are scraped up like she was raising and lowering the boats in a Force 5 gale.
Nantucket Mike would have a heart attack if he saw it.
The photos wash it out a bit.
Take a close look at this image.  It shows the weathering a bit better.  Look at the stack and the ventilators -- you can see the wash clearly there.
It also shows where I added a brass plate to attach the boat davit tackle.  I was not happy with the 'magic' attachment appearance of either end of the ropes and tackle. I added plates to the boat and at "cap" to the davit itself.  The caps are merely to hide the poor fit of the block to the davit.  It now looks better, methinks.  (the plate is left over PE, and the cap is wine bottle foil bent and painted.)
And you can almost see where I drilled out the pipe at the back of the stack.
Oh, one more thing.  The supports that the boat is resting on are made from evergreen I-beams and plate.  I would like to claim that I was improving on the kit stanchions, but the truth is that I lost the real ones along the way and had to make new ones.  Oops.  No one will ever know!
    January 2008
Posted by DerOberst on Tuesday, May 26, 2009 4:45 PM
Ok, Mike, I dressed up the telegraph.
And I painted around the running lights black, but I hate the way it looks.
    March 2007
Posted by bondoman on Tuesday, May 26, 2009 7:05 PM
Hi Der, neat model in every way. Your flying bridge made me think; the telegraph should probably point fore/aft motion of the lever. Just seems wrong sideways. Here's a pic from another ship, the Relief, and in the wheelhouse, but it is probably the same idea.
A great project.
    January 2008
Posted by DerOberst on Tuesday, May 26, 2009 8:45 PM
Bondo, thanks for the tip.  I was thinking the same thing...Whistling [:-^]
I have rotated the telegraph and am in the process of adding louvres to the signal lamps.
I am also making a cover for the wheel.. so far I have my doubts about how it is progressing, but I will post the results for comments.
    March 2007
Posted by bondoman on Tuesday, May 26, 2009 9:33 PM
A good way to model canvas is to soak kleenex in a dilute white glue and drape it on. Takes a litle practice, but not much. Paint afterwards.
    March 2004
Posted by subfixer on Tuesday, May 26, 2009 11:38 PM
We have a lightship museum in our local area. I'm sorry this is late but here is a link to some pictures that might interest you: http://www.portsnavalmuseums.com/lightshiparchive.html
I'm from the government and I'm here to help.
    January 2008
Posted by DerOberst on Wednesday, May 27, 2009 6:33 AM
Ok, I have made a few changes to the bridge:
The telegraph is painted and re-oriented
The signal lamps are silver face with louvres attached
The wheel is covered with canvas and installed.
The running light are painted black and back again, still need some touch up.
The bell is brass (but not weathered, it will look more like the large fog bell in the bow)
The fire fog nozzle has been removed and replaced.
As always, comments and suggestions welcome!!
    January 2008
Posted by DerOberst on Sunday, May 31, 2009 11:09 PM
UPDATE:  Almost there, but there is a setback!
I have fixed all the major structures in place, and finished most of the touch up painting. I dry brushed the Spar with a naples yellow oil paint, and dry brushed the hull with a mix of cadmium red and white.  I am trying to induce some sun faded look to everything.  Then I dry brushed white back over the deck houses to tone down the weathering and make the highlights pop.
A detailed post with pictures will follow, but....
I LOST A PART!!!
There are only 9 of the gizmos that secure the rigging to the deck. So I am short one and will have to fabricate it.   OOPS!Banged Head [banghead]
Enjoy some update photos.  Ignore the loose fishing lines dangling. I am waiting for the CA to dry prior to trimming.
Comments and suggestions welcome!!
    June 2009
Posted by mastrsn on Tuesday, June 2, 2009 11:09 AM
Your Nantucket is looking GREAT! My Dad turned me on to this model when it was put out by Pyro. The Linberg kits are pressed from the Pyro molds, but through the years, they have turning out less than good quality kits. I have spent a while on Ebay and have bought at least a dozen of these kits- both Pyro and Lindberg!
An overseas 'N' scale railroad company called Priester puts out some really excellent <sp?> sailors, all decked out in life perservers, both Officers and Enlisted, that will really compliment your model. I have even used some 'N' scale lights with strobe effects in the masts to simulate the lights. I used hollow plastic and rebuilt the masts so the wires would slide down inside the hull.
I am new to this forum, and haven't figured out how to submit pictures yet, but I have a website that has a lot of info...
http://lightshipmodeler.iwarp.com
It has been a while since I have done any maintenence, but maybe this project of yours will get me back into fixing it since the crash.
Keep up the good work!
Bob
Oh, by the way- The fly bridge is a carbon copy of the bridge inside the Pilot House. It was used to navigate the ship easier.
    January 2008
Posted by DerOberst on Tuesday, June 2, 2009 3:59 PM
Bob,
Thanks.
I have just about finished.  A quick spray of dull coat and it should be a wrap.  Oh, wait. I still have to add the flags.
And I think the flag poles that came with the kit look wildly out of scale.
I might have to build new ones.
I will post some finished pictures when I am done.
    January 2008
Posted by DerOberst on Wednesday, June 3, 2009 11:44 PM
Well, I think she is just about done.
Here are some nearly final photos.   I will mess with the flags and some other details (the stern light needs fixing!) I have to remove some dust that got blown on during the dull coat application.
Comments, suggestions, and criticism welcome!  Enjoy.
    June 2009
Posted by mastrsn on Friday, June 5, 2009 4:08 PM
Where did you get the Buff color?
    January 2008
Posted by DerOberst on Friday, June 5, 2009 4:34 PM
The buff color is called SPAR.
and it is available from Snyder and Short at http://www.shipcamouflage.com/
According to the experts that chimed in earlier in this thread, it is the only correct paint to use!
It sprayed nicely from an airbrush, and brushed well.
(and the color you see on the final model has been washed with engine grey and drybrushed with a yellow.  The out-of-the-can look for the paint is visible in some pictures from earlier in the thread.)
    June 2006
Posted by Grem56 on Friday, June 5, 2009 11:49 PM
A very nice build ! You have done the real deal proud.
Julian
    January 2008
Posted by DerOberst on Tuesday, June 9, 2009 12:29 PM
Thanks, Julian.
I appreciate the comment!
Posted by Dream Modeler on Saturday, November 21, 2009 5:21 PM
Hi.
Just come across this thread." Dogger" as refered to by Tankerbuilder is actually in the North Sea between England (North) and Belgium/ Holland. Scotland is a bit further North but I have not checked the actual relationship by lat and longitude !
A map is shown at http://en.wikipedia.org/wiki/Dogger_Bank
Will dig a bit more on Lightships located there in the past.
cheers
Jericlin
Posted by Dream Modeler on Saturday, November 21, 2009 5:58 PM
So far only come up with this :- http://www.jlunderwater.co.uk/old_site/photoix/lv83/index.htm
Interesting with a sketch of the wreck but no colour scheme !
    March 2010
Posted by ouicb on Sunday, March 7, 2010 12:14 PM
Ahoy All!
I am new to this forum but i have been modeling going on forty years or so...I have a 1955 Pyro 1/95 scale Nantucket lightship kit serial number 238. i have added the pyro electric ship engine kit to go with it...I have a spare engine kit and another pyro kit that has the RELIEF lighship cutout decals that i want to build...my question is this: is the 1955 Pyro kit too valuable to assemble? It came with some things that i haven't seen in other Pyro kits of this great lightship, such as the crew figures, spool of thread, and anchor chain...the two halves look like they were glued at the factory and the black bottom paint also looks to be factory painted... also, the box has a woodgrain divider inside and another one painted duck egg blue...When i bought this several years ago the owner sent a letter explaining that their parents bought this for them in the 1950's but the owner never got around to building it.
At any rate i am going to build one of these kits plus i have two more lindberg lightship kits for spare parts...I have a lot of articles and pics i have collected over the years of lightships and also have the Russian version of the South Goodwin lightship that i haven't built...i am working on a 1/700 scale scratchbuilt "Frying Pan" lightship that is in the drydock at he moment.
 i appreciate all the research and info posted here, it should grease the skids for my assembly!
chris
    May 2006
Posted by thunder1 on Tuesday, March 9, 2010 9:25 AM
Chris
 I have an unbuilt  NANTUCKET kit from 1956 and note the following:  the kit has a cellophane bag of figures, chain and black thread. The box is unremarkable(no divider cardboard) but the cover box art is dramatic, depicting the lightship at night in dirty weather. The plastic is molded in three colors, red, buff and light gray. What makes this version different from the later releases is the letters spelling "NANTUCKET" are molded in the side of each hull piece. The late 1960's version was molded in colors but with out the molded lettering. The box cover in that issue is a color painting of the lightship in calm seas.
Later versions(Lindberg) had the kit molded in white plastic with a color photograph of a  pitiful build, I don't know who builds  Lindberg's kits for the box cover,  my young grandson could do a much better job. The direction sheet had the NANTUCKET letters printed on them so the builder was required to cut them from the sheet and glue them to the hull, what a crappy way to letter the model!
As to the bottom of your model being painted....I have an unbuilt 1955 model of the Pyro HARRIET LANE. The hull is factory assembled and the bottom is factory painted a gold color. The box has blue cardboard dividers seperating  the hull, deck and other parts. As to the value of the kit...if you are a collector save the kit as an example of 1950's tech. It's monetary worth is debatable in this down economy, Evilbay seems to be a buyers market for OOP kits these days. It may sell for as much as $100 IF you find a buyer that REALLY wants to add it to their collection. Since the Lindberg NANTUCKET kit is currently available, I doubt if you'd get big money for your version of  it.
The SOUTH GOODWIN lightship dates back to 1970, I believe UPC(or Frog) offered the model at the time. I recall building the GOODWIN in 1971, along with the NANTUCKET. As a young coastguardsman, I built every kit that had some coast guard theme associated with it.  When I was stationed on the NANTUCKET I even built a copy of Billings Model's German "ELBE" lightship. We had few amenities on that ship so I was always looking for a model to build to pass away the long weeks on station. . weather permitting.
Regards
Mike M.
