Sails
    December 2012
Posted by rwiederrich on Friday, January 3, 2020 7:46 AM
Another " target="">
    December 2006
Posted by crackers on Friday, January 3, 2020 11:58 AM
Beautiful work. I love it. But, please explain more details of how you applied your sails, and what matertials these sails are made of. Plastic ? cloth ? or silkspan ?  I prefer silkspan, because, the matertial is more to scale and easy to work.
Happy modeling      Crackers    Stick out tongue
Anthony V. Santos
    December 2012
Posted by rwiederrich on Monday, January 6, 2020 8:23 AM
Anthony...the sails are made from simple copier paper.  I first draw out the scale panel lines on the paper(both sides)...then I copy the paper(both sides).  I make about 20 sheets..so I have pleanty of material to use.
Then I simply draw the sail plan out on the paper sheet(adding slight length to the sail to allow for billowing) and cut out the sail with a hobby knife.
Then I add the clew point hardare(small copper eyes glled to the sail clue point to attack the clue blocks to)..add the belly banding as necessary(by cutting strips of paper and glueing them in place.  Once all the details of the sail are added I paint the sail in a typical sail color(I've alternated this to give character to the sails).....adding just enough to slightly mask out the panel lines.
As the sail dries I form the sail by rolling with a wood dowel and by using a cake makers fondant/gum paste forming tool. (Simply a dowel with a metal ball on the end..you roll around the sail edge to form its contour.
Next...I glue the sail to the yard...making sure the sail is high and forward on the yard to aid in giving the sail the proper elevation when developing the proper billow as the sail leaves the yard and is pulled forward by the wind.
All my sails were added to their yards while mounted on the masts....the entire mast and its yards was built off model.
Rob
    December 2006
Posted by crackers on Monday, January 6, 2020 12:41 PM
Thank you for your indepth answer to my question. I really appreciate your answer on how to make sails. My procedure was to first cut out a scap paper sail template to see that it fits the spar arrangement. When satisfied, the template is used to trace out the actual sail on silkspan material, which is then soaked in a diluted solution of light acrylic brown paint. The wet silkspan sail is then lightly scotch taped to a rubber ball  for a billowing effect. When the sail is dried, clues are glued in place along with the proper blocks, then attached to the yard.
My question to you, is how you provide foot ropes to the yard. My method is to soak black thread in glue, strain out the glue, the. hang the thread for drying. Once the thread is dried and stiff, ends are tied to the yard, while the lower ends are glued to together. Perhaps, you have a better alternative for foot ropes.
Happy modeling     Crackers    Surprise
Anthony V. Santos
    October 2019
Posted by Tanker-Builder on Monday, January 6, 2020 1:48 PM
Hi Ya'll;
       I forgot this. To get a sail" Bellied" ie.Full of air. I do this, I have a light fixture globe that I keep waxed. I drop the Silkspan on it and Squirt water on it.( At this point the sail is oversized.) It dries to the curve. Then I mount it and the Belly changes according to the yard and rigging tightness.
    December 2012
Posted by rwiederrich on Monday, January 6, 2020 4:05 PM
Well footropes are done several ways...dependant on scale and how *crisp* I want the set-up to look.  I have made them with nylon thread that was stiff enough to hold its form...prior to adding the stirrups.
But all the foot ropes on my clipper Great Republic were made with wire.  I glued the sagging foot rope to the yard then added the stirrups.  I then painted the entire foot rope assembly black.   They look very clean and retain their nice droop without twisting and flexing of string...type ropes.
Rob
Posted by Don Stauffer on Tuesday, January 7, 2020 9:26 AM
rwiederrich
Rob
I also use wire.  In the old days when hobby electronics was popular, I found a supply of very fine (forget the gauge) cotton-insulated coil wire.  It had a nice fabric texture that looked a lot like rope, especially when painted with thin paint.  Alas I cannot find it anymore.  It was only really good in larger scales, and now I just paint the wire with flat paint like you do.
    December 2006
Posted by crackers on Tuesday, January 7, 2020 2:39 PM
I guess sails for a model is really a personal decision. I prefer to work with silkspan, a tissue like material that is strong and difficult to tear, as is seen on my model of the British revenue cutter DILIGENCE. BlueJacket Ship Crafters of Searsport, ME sells sheets of silkspan at  $2.75 each.
Happy modeling   Crackers    Angel
Anthony V. Santos
    December 2012
Posted by rwiederrich on Wednesday, January 8, 2020 8:11 AM
I think Silkspan is a wonderful material......however, I feel there is far too much work involved in the technique to use it convincingly.  It needs to be painted or starched to form it and to mask its translucency.  I have seen wonderful sails created with it,,,but for me it's too labor intensive.
Here is an image of the wire foot ropes and the wire lifts for each yard on the Mizzen of my scratch built Great Republic.  wire works wonderfully and it goes were you place it.
My sails are all plain copy paper.
Rob " target="">
    October 2019
Posted by Tanker-Builder on Wednesday, January 8, 2020 11:14 AM
Hmmm;
     When you say " Plain Copy Paper" I have to wonder. You do know that it comes in different Weights. From almost like Parchment all the way to almost Cardstock.
    December 2006
Posted by crackers on Wednesday, January 8, 2020 11:37 AM
Wow, Rob ! fantastic model you have created. Your suggestion for wire on the foot ropes is something I really have to consider. My question is, how do you attach the ends of the wire foot ropes to the part the seamen stand on ? Do you glue them ? Solder them on ?
Happy modeling  Crackers   Sad
Anthony V. Santos
    December 2012
Posted by rwiederrich on Wednesday, January 8, 2020 12:51 PM
Well to qualify my statement...I mean..plain (8.5 X 11 in, .92 bright) white recycled copier paper..one uses in an office.
Rob
    December 2012
Posted by rwiederrich on Wednesday, January 8, 2020 1:05 PM
Let me help.....
Crackers...the foot rope IS made from wire. One can drill a small hole on the underneath side of the yard and glue in the wire..so it hangs naturaly(Both sides).  Then tie off some thread at the proper distance on the yard and then bring them down (Letting them hang) and cut them to length and simply apply a drop of glue to it and the wire.  Once died, you simply paint the entire foot rope and stirup assembly.  Done deal.   You can also tie the stirup off on the wire foot rope and then cut it and then glue it.....but why waste the time and energy?
It also depends on the scale you are working in as well, as to how much effort you want to apply to the foot ropes.
BIG NOTE: Most builders foget to keep these foot ropes in scale.  The length of the stirup should place the foot rope at a general distance from the yard to allow a scale person to lean over the yard.  Far too many builders make the stirups too long...making the foot ropes Waaay to lengthy...and a scale person would hardly be able to stand on it and do proper work over the edge of the sail draped yard.  Keep this in mind.
Rob
    December 2006
Posted by crackers on Wednesday, January 8, 2020 2:44 PM
 Thanks Rob for your suggestion on the foot ropes. Very good information you provided.
Happy modeling   Crackers     Smile
Anthony V. Santos
    December 2012
Posted by rwiederrich on Wednesday, January 8, 2020 3:14 PM
I finished up my scratch built Great Republic....and put her in her case. " target="">
Rob
    September 2012
Posted by GMorrison on Thursday, March 26, 2020 7:42 PM
I love your fireplace room and I want to live in it.
All it needs is a parrot.
"Pieces of eight, pieces of eight!"
Bill
    December 2012
Posted by rwiederrich on Friday, March 27, 2020 12:27 PM
Thanks Bill...the Library is one of my favorite rooms in the house.  We enjoy a cup of coffee and a good read every day there....so nestalgic and comfy.....
Rob
    September 2012
Posted by GMorrison on Friday, March 27, 2020 5:03 PM
I was very kindly given a big stack of ship modeling books by another forum member and good friend of mine.
Some of the older models have absolutely beautiful cloth sails. While not super "to scale", they just have a certain lovely quality.
