Thank you both for join the conversation.
@ CapnMac82
Yes, they are the jackstay.
I did my home work and after I build them I finally discovered what they are supposed to to and why they are there.
I'm learning alot on the way, whitc is fine, I just hope not to do too many mistakes meanwhile.
The debate around the lifts is still partially open, but I'm quite sure that the main yard are supported by the lifts, they are clearly visible here:
https://live.staticflickr.com/7306/8732718837_4bf58c7458_b.jpg
or here:
https://regenaxe.files.wordpress.com/2017/11/cutty-sark-main-mast-and-ensign.jpg
CapnMac82
Course and topsail yards ought have double jackstays on them, if memory serves, too.
I will check on longridge, thank you for the advices!
Sigep Ziggy
I would love to know how you painted your deck and masts the wood color. I have stripped all my previous paint from my Cutty's decks and masts and would like to copy your style and repaint them.
There was a brief explanation on te previous page, I copy and paste it here:
I paint the deck with a uniform clear brown acrylic color, and I shaded it with oil paint, applied as a filter.
At this stage the color was too warm for my taste, so I applied a higly diluted layer of acrylic brown (deck tan if memory serves me well) to make it less saturated and uniform.
Lastly, with a soft dark pencil, I brought back all the fine details.
and I add some more details hoping to be helpfull:
the brown color is usually tamiya xf52, xf59 or similar, depending on the needs. Note that they are matte colors.
The oil wash is usually a burnt umber. Dilution is the key, make some test and you will be able to control the final result.
Just be carefull: I thinned them with Humbrol thinner but it is still prety aggressive on the acrilics. It qold be better to coate them woth a matte varnish, but in the end I was able to avoid this steb just by beeng extra carefull when wiping out the oil excess.
I hope the process is understandable even with my bad english.
If more explanation are needed, you will be welcome!
