USS Langley: Breakthrough
    March 2022
Posted by missileman2000 on Monday, August 8, 2022 1:23 PM
DUSTER
Don
Not sure how close you are to one of their stores but Harbor Freight  has a 9 piece punch set:
  PITTSBURGH  Hollow Punch Set, 9 Pc.Punch holes with precision ground flutes and cutting edges $999
and a more pricie
LIFETIME CARBIDE Punch And Die Set, 9 Pc. $3499
 both sets include a 3/8 punch
Just a thought to help ease the process a bit.
Yep, I have a Harbor Freight about 20 minutes away.  I'll take a run over there tomorrow and see if I can pick up a set.
Thanks for the tip.
    August 2007
Posted by DUSTER on Tuesday, August 9, 2022 11:36 AM
yer welcome     hope it helps out
Steve
    March 2009
Posted by surfsup on Wednesday, August 10, 2022 3:13 AM
You are doing a suyper Job Don. As for working with P/E, I have been using it for over 20 Years and I still make mistakes, some minor andd some major. You just keep learning with the stuff.....Cheers mark
If i was your wife, i'd poison your tea! If Iwas your husband, I would drink it! WINSTON CHURCHILL
    March 2022
Posted by missileman2000 on Friday, August 12, 2022 7:26 PM
Here are the first two level bombers (Martin BM-2).These are a nightmare!  The landing gear is terrible.  Sometimes it breaks with the first bend.  It just doesn't want to stay in place when it is bent.  It has taken four days to get these two planes finished.  I have learned some tricks- two jigs, a PE bending jig fastened to the top of the block, and an assembly jig for holding the rest of the plane steady while I install the top wing.
 BTW, wingspan is about one inch.
    January 2021
Posted by PFJN2 on Friday, August 12, 2022 7:33 PM
Oh my Surprise
They look great
    August 2021
Posted by lurch on Saturday, August 13, 2022 3:34 AM
Those look fantastic.
    October 2019
Posted by Tanker-Builder on Saturday, August 13, 2022 8:53 AM
WOW !!!!!!!!
    March 2009
Posted by surfsup on Sunday, August 14, 2022 2:15 AM
Beautiful work on the Aircraft.....Cheers Mark
    August 2007
Posted by DUSTER on Tuesday, August 16, 2022 1:25 AM
 fantastic work. I'm just glad it's you not me, I'd had small piles of smi-identifiable bits laying about.
Steve
    July 2013
Posted by steve5 on Tuesday, August 16, 2022 5:42 PM
for a nightmare , you've turned them into a dream .
    March 2022
Posted by missileman2000 on Wednesday, August 17, 2022 7:07 PM
I finished the bombers!  Here they are on the flight deck (not glued in place).  I just need to put the kit props on four of them, will have one with engine turning decal.
Also, I mentioned earlier that one of the torpedo bomers was so bad I had it in maintanence on the hanger deck.
BTW, I found, before I drove to the store, that I had a set of the punches.  Tried them on the two sheets of plastic I have- A brittle sheet cracked, a softer sheet distorted badly.  I guess I will go back to cutting them with scissors.
    August 2021
Posted by lurch on Wednesday, August 17, 2022 7:29 PM
That looks fantastic. You have done a great job on that.
    March 2022
Posted by missileman2000 on Monday, September 19, 2022 2:48 PM
I finally finished the last aircraft (at least for now, until I break ones putting them on the deck.
I have begun gluing them to the deck.
    August 2007
Posted by DUSTER on Tuesday, September 20, 2022 9:04 AM
looks very good
Steve
    March 2022
Posted by missileman2000 on Saturday, September 24, 2022 8:13 AM
I am declaring it finished- on the way to Nordiccon in a couple of minutes.  Still have some PE crew left, but ran out of time.  I can add them later.
Photos some time this weekend.
