icer22x:
That AC-500 only has a 2.5L tank on it. That's ALMOST a gallon. I have zero experience with air depletion when using an airbrush, but say I get my Badger 105, how long would it take to deplete a 2.5L tank of air while just holding down the trigger? I'm trying to see if I should get a cheaper tank-less compressor and just buy a bigger tank for it.
Here are some numbers from a Revell Master Class unit, which is a re-branded Sparmax unit with the same spec as the AC-500. These numbers will be similar for most compressors with the same HP rating & tank size.
The variable here will be the airbrush & nozzle size used, as one manufacturers 0.? nozzle set will not have the same flow as another's 0.? one. These figures come from a H&S airbrush with the 0.2 & 0.4mm nozzle sets - for what it's worth I would imagine that the 105 would be somewhere between the two (all figures for 20psi output);
25 Seconds to fill from empty,
55 Seconds to restart with 0.2mm nozzle set,
15 Seconds to restart with 0.4mm nozzle set,
8 seconds from restart to full (no flow),
2 Min. 35 Seconds to drain tank to 20psi with 0.2mm nozzle set,
45 Seconds to drain tank to 20psi on 0.4mm nozzle set,
18 Seconds from 20psi to refill (no flow).
These figures can only be used as an approximation, as your airbrush, nozzle size & usage will have a fair impact on performance, these figure were also worked with the compressor gages, which although accurate enough for their intended use, are not perfect. As a rough idea, I do mainly 1/72 large aircraft & spend most of my time working with an 0.2mm nozzle set at 20psi. Also remember that for any given job or session that you will only be using the airbrush for a percentage of that time, between start/stop, moving parts, paint changes & fiddling I would say that I am only on the trigger 50% of the time on average
On the question of noise, this compressor isn't by any means silent, but it is not noisy. I keep mine in a kitchen type cupboard, & it's pretty quiet in the room it's being used in & cant be hear anywhere else in the house.
