waynec GREG, SPOTS thanks. i hit the LHS and picked up some VALLEJO airbrush cleaner and a PEGASUS 1/72 soviet BA-6 6x6 armored car (2 in kit and i am building a 1/35 BA-10).
GREG, SPOTS thanks.
what a concept, i read the instructions on the cleaner and it says use full strength for cleaning but dilute it 50% with water for flushing between colors.
Никто не Забыт (No one is Forgotten)Ничто не Забыто (Nothing is Forgotten)
Yep, that's what I do with the Iwata cleaner. I'd forgotten the Vallejo works the same way.
I have a squirty bottle from Hobby Lobby for the diluted mix. Rather handy if you're using a gravity feed a/b.
here it is in winter camo. the basecoat is VALLEJO AV panzer yellow airbrushed over an enamel primer. it sat for a week and today i put the silly putty and painted. the silly putty didn't want to stick and 1/72 is more delicate to handle than 1/35. i airbrushed it with VALLEJO ivory (NOT AV).that took a lot of thinner and 30psi but, other than right rear fender no run problems. lots of passes but i wasn't concerned if it didn't cover well. i sat it aside, cleaned the airbrush and then removed the silly putty so it sat for maybe 5 minutes after painting before removing the silly putty.
have some touching up to do and decals before final weathering. may try my hand at a small snow base.
