What's a good partner to a Badger 175 Crescendo?
    August 2005
Posted by eizzle on Wednesday, May 17, 2006 8:08 PM
It won't clog it Ed. The only thing thats going to clog it is getting melted plastic on the end of the needle, but that can be solved by a quick bath for the tip in the Tenax bottle. If/when you get it, you will be suprised, cause the way it works, but you are supposed to stick the tube in the glue and let it suck it up, now I figured that it would run out, or that I would have glue all over me from the tube being in the bottle, but the stuff doesn't run out, and it evaporates FAST! Good luck at the casinos, and if you hit it big, don't forget your buddies Big Smile [:D]
Oh, and... Shy [8)] your welcome Wink [;)]
Colin
 Homer Simpson for president!!!
    July 2004
Posted by tho9900 on Wednesday, May 17, 2006 8:11 PM
jinx....  (double no take backs! Wink [;)])
    December 2004
Posted by Hippy-Ed on Wednesday, May 17, 2006 8:39 PM
Very informative  link TomThumbs Up [tup] I've never used the TNF or Tenex but, from all I've heard, it's the Bomb. I will see what I can do on getting it in Reno while I'm there. Gonna be a quick trip up & back as I'm going up to drive a car back with of all things...A Cat in a cageBlack Eye [B)]The Hotel don't allow cats but, does have a Dog Kennel thoShock [:O]
Thanks for the run down Tom on thisBig Smile [:D]
If you lose your sense of humor, you've lost everything
    December 2004
Posted by Hippy-Ed on Wednesday, May 17, 2006 8:42 PM
Whistling [:-^]
    July 2004
Posted by tho9900 on Wednesday, May 17, 2006 8:57 PM
Eddie - if nothing else, try a bottle of Ambroids pro-weld.. about $3.95 here.. works much the same way except you brush it on with a brush already supplied in the bottle.  Not near as hot but will weld the pieces together.  either solvent will allow you to go an inch or so at a time along a seam allowing you time to line it up before you glue... Tenax is better with the drawback of being a bit hotter and needing the glass applicator... Ambroids is not as hot but sometimes you won't get the seam penetration that Tenax would... both work.. both have good points and bad... both are head and tails above tube cement and some of the other liquid cements...  these are actually plastic weld agents...
    May 2004
Posted by mikeiw on Thursday, May 18, 2006 2:59 AM
From airbrushes to Touch'n'Flow applicators in one easy lesson! Shock [:O]
I could say Sign - Off Topic!! [#offtopic] but what the heck? Wink [;)]
jwb
    February 2006
Posted by jwb on Thursday, May 18, 2006 6:34 AM
"What's a good partner to a Badger....."
Maybe a ferret, or a chinchilla?
Laugh [(-D]
Sorry, couldn't help myself.....
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
Posted by MikeV on Thursday, May 18, 2006 7:44 AM
Laugh [(-D]
Wise guy huh?
jwb
    February 2006
Posted by jwb on Thursday, May 18, 2006 8:45 AM
 MikeV wrote:
Wise guy huh?
While I am most certainly a guy, I cannot in good conscious make any claims to being wise. Wise-acre, perhaps! LOL
Smile,Wink, & Grin [swg]
Jon Bius
    December 2004
Posted by Hippy-Ed on Thursday, May 18, 2006 9:46 AM
Don't ya just love itWink [;)]
    May 2004
Posted by mikeiw on Thursday, May 18, 2006 11:14 AM
Can't beat a stunning display of advanced silliness to break up the monotony of the day, can you? Big Smile [:D]
Watching a Badger 155 Anthem on evil-bay right now... would that compliment my 175, or be a bit more like duplication?
    December 2004
Posted by Hippy-Ed on Thursday, May 18, 2006 12:29 PM
From what I've read here, the 155 is a bit like the 175. I don't recall which thread  but, I'll look for it & add it here.
Here's the thresd
http://www.finescale.com/FSM/CS/forums/618542/ShowPost.aspx
    July 2004
Posted by tho9900 on Thursday, May 18, 2006 1:21 PM
I owned both the 155 and 175, and while the 155 is better somewhat at fine detail, it would be close enough to make me think you would be better off with the 175 and a gravity fed as mentioned.. there is a big enough difference in the two (175 vs. gravity fed) to make it worth your while...
    May 2004
Posted by mikeiw on Thursday, May 18, 2006 1:23 PM
Thanks Ed & Thom - saved me wasting a few quid on one Wink [;)]
a quid = £1 = $1.89058
    December 2004
Posted by Hippy-Ed on Thursday, May 18, 2006 1:51 PM
NP mikeiwBig Smile [:D]  Keep us posted on what you decide to get. Tom can probably give ya the scoop on some gravity fed A/Bs Thumbs Up [tup]
    May 2004
Posted by mikeiw on Thursday, May 18, 2006 2:04 PM
Tried to get hold of a Thayer & Chandler 'brush, as the omni 4000 was supposed to be a goodie, but they seem a bit hard to find over here in the good 'ole U of K... Disapprove [V]
    July 2004
Posted by tho9900 on Thursday, May 18, 2006 4:40 PM
I'd try to see what is avaialable (along with spare parts) locally to you... if not that, then what is available by mail order from your side of the pond..  the Harder and Steenbeck Evolution line is supposedly one of the top brushes on your side and it ships from www.obeeliks.com in Belgium I believe....
This one looked good if you browse through there, pretty much the equiv of the 100LG with fine and medium tips.
Harder & Steenbeck Airbrush Evolution Silverline 0.2 + 0.4 mm But first I'd check locally..  you don't want to wait 3 weeks for a replacement needle to arrive all the way from the US.
not sure what the Euro to pound conversion is but it might be a bit pricey for ya... in that case ordering a brush and a few spare needles and tips from a local source or even www.dixieart.com might be a better outlook.  I have friends in AU who say it is cheaper than buying the brush locally even with international shipping....
    December 2004
Posted by Hippy-Ed on Thursday, May 18, 2006 6:01 PM
I just ordered from Dixieart Friday night and I got an email from UPS saying ot's been shipped out.  My regulator will be here the 24th. It left Jackson,MS at 4:30amBig Smile [:D]
    July 2004
Posted by tho9900 on Thursday, May 18, 2006 8:20 PM
ok I did some digging for ya and found out the Badger 100LG is 99.99 pounds at www.Hannants.co.uk, at www.dixieart.com it is 36 pounds (equivalent) plus about $20 for shipping (10 pounds? cost)  I think you are subject to VAT tax so I couldn't figure that in but it looks to come in around the same price or a little less than the H&S Evolution if you ordered it from the states.
The H&S is 110.00 Euros which without shipping comes to 74 pounds... the Badger 100LG from dixieart comes in approximately at about 57 pounds or so without the extra needle and tip combo including shipping, but not figuring in VAT...
I guess it boils down to when ya want to receive your new brush... if its worth a few extra shekels (just to introduce one more currency type haha) then H&S.. if you are not wanting to spend a ton, then dixieart and wait a few weeks, although the savings is not significant as in compared to hannants... I'd stay away from the 100LG at hannants... a bit on the high side which is par for hobby shops here too!
But if you get either the H&S Evolution or 100LG spare parts are available in the UK for both...
    December 2004
Posted by Hippy-Ed on Thursday, May 18, 2006 10:34 PM
What's a few yen between friendsBig Smile [:D] I think I'd go with the dixieart and wait it out. Of course, that's just meSmile,Wink, & Grin [swg]
    May 2004
Posted by mikeiw on Friday, May 19, 2006 6:30 AM
Tom / Ed, yet more nuggets of useful info... I wish more of the threads were like this one. Big Smile [:D]
I'll check it out over the weekend.  If I ordered from outside the European Union, any import might be subject to Import Duy, of it's over a certain value, or gets picked up & rattled by HM Customs & Excise when it enters the country.  On small priced items that shouldn't be a problem, but the Post Office charge an exorbitant sum for collecting the duty, which in proportion to the cost of the item AND the duty bumps the price up a LOT... Disapprove [V]
    December 2004
Posted by Hippy-Ed on Friday, May 19, 2006 7:52 AM
Now that's interesting... I didn't know about there being an additional charge on something if it's over a certain amountShock [:O] Bet Robin Hood is rolling over in his graveDead [xx(]
    December 2004
Posted by Hippy-Ed on Friday, May 19, 2006 9:04 AM
Fellas, I'm off to Reno shortlyTongue [:P] I've got my hobby list made out as wellBig Smile [:D] I'll look for the Tenax or Ambroids while I'm there. I like going into High Sierra Models in Reno as the owner is pretty cool & helpful. Not to mention there's quite a variety of kits & such... If I hit it big up there, ya know where I'll be leaving my moneyWhistling [:-^]
