Jim - Jack pretty much summed it up. If you try out Vallejo use their "thinner", Model Air is pre-thinned for airbrushing but their thinner is actually a retarded and adhesion agent all in one. It's about $4 for a bottle but I've used one as much as a year before it was running out, and Vallejo is ALL I use if I can help it. You'd have to order it from coloradominiatures.com or spruebrothers.com because although color of Eagles has the Vallejo made paint they don't carry the "thinner"...
MM Acryl is good if you can find it locally, I still recommend trying the Vallejo though. MM can be thinned with their own thinner, or Tamiya acrylic thinner. You can't thin Vallejo with either of those. vallejo is a water based versus solvent based acrylic. It "curdles: when you put anything like the MM or Tamiya thinner in it.
On retarders, Liquitex and golden both make a retarder that works well with Vallejo, just a drop will do it! They also both make airbrush mediums that are flow aids and look and work suspiciously like the Vallejo "thinner"... Jack got me thinking in an email on the subject so I am testing out the theory and will post what I think on their airbrush mediums instead of Vallejo branded stuff. Back to the retarder, whatever brand of acrylic you settle with the retarded will work.. so it won't hurt to get some. Some needle lube or glycerin from the pharmacy (I found it at Walgreens in the cospetic section) work well for it. It helps precent the acrylic from sticking to the tip as well as making it a little smoother int he action when you pull back on the trigger.
There is still a small amount of tip dry with Vallejo, less with their thinner... all I do is when the spray pattern starts changing I just give it a quick spurt with the trigger pulled back pretty far and it clears it. I also try to keep a qtip with water on it nearby for stubborn spots...
Good luck to you and don't be afraid to ask questions!! There's actually more than a few here who either use Vallejo full time or at least use it so there'll be plenty of people to answer!
-edit-
you can pick up the Goldens and Liquitex products at somewhere like Hobby Lobby or Michaels where the tube acrylics are...
