The best glue
    July 2008
Posted by Railfan 233 on Tuesday, August 10, 2010 4:54 PM
I basically apply the Testors cement by placing the two parts together, and touching the brush to the joint/seam.   By doing that, the model does some of the work for you, because the seam has what is called "Capilary action" that allows a liquid to easily flow along the joint for a little bit. Just touch the brush to the seam about every inch or so, and that sould do it.
I've been using the methood ever since I started using Testor's liquid cement, and it has worked every time.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpgRed, White, and YOU! group build of 2010
    August 2010
Posted by tomgeotech on Tuesday, August 10, 2010 6:07 PM
Well I was doing a web search for Tenax 7R and alot of sites and blogs were saying it has been discontinued, although I see that some places were still selling (maybe existing stock).
In addition, I found it interesting that the Testors website does not have the Model Masters Liquid Cement as an available product.
    March 2008
Posted by Killjoy on Tuesday, August 10, 2010 6:54 PM
I bought this stuff at a local plastics supply company.  Stuff works reall well, behaves exactly like tenax 7, and costs a ton less.
http://www.eplastics.com/Plastic/Plexiglass_Glue/PLEXIGLASS-GLUE-ADHESIVE-IPS4-4OZ
Chris
A veteran is someone who, at one point in their life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including my life."
    April 2010
Posted by Ripcord on Tuesday, August 10, 2010 8:00 PM
I'll try it. Thanks! =)
