dot filters?
    April 2008
dot filters?
Posted by humper491 on Wednesday, April 25, 2012 12:35 AM
looking for the basics of dot-filtering. model master enamels for base colors, and normally i use acrylics for weathering. do i need touse oil for this? never used oil, but all suggestions are appreciated...
Humper Beam
Posted by Tojo72 on Wednesday, April 25, 2012 6:46 AM
I was going to post a link,but there are so many of them.
Use the Search Our Community,feature toward the bottom of the forum page.There are many,many posts on the subject.Enter Oil Dot Filters.
You will find some good tutorials
    January 2007
Posted by the doog on Wednesday, April 25, 2012 9:05 PM
humper491
You can use enamels, but oils dry quicker--but if you're using either over enamels, you're going to have to seal the paint first. You should NOT do this with acrylics--the pigments in them are generally too large to effectively do it correctly. I do my Dot-stuff over Tamiya acrylics, always.
Here's my Oil Dot technique, explained in clear photos. Good luck!
The Doog's toot
    April 2008
Posted by humper491 on Wednesday, April 25, 2012 9:22 PM
that was fantastic! thanks so much, i think i can give it a try
Humper Beam
    January 2007
Posted by the doog on Thursday, April 26, 2012 10:35 AM
I hope it helps you--that's what this forum is all about!
Good luck with your filtering, and post some photos up on the Armor forums. The guys will be able to help you out if I can't get online because of my busy schedule!
    April 2012
Posted by Gnelson on Friday, April 27, 2012 7:05 AM
Hopefully you are done humper. As there are many tutorials available in the forum.
