Kit Obsession? Locked
    April 2015
Kit Obsession?
Posted by Mark Lookabaugh on Saturday, June 6, 2015 3:31 PM
So this is weird.  While I'm working on a particularly fun kit, I'll get freaked out that I messed up some small detail, and worry about how to fix it.  Then I end up buying another copy of the kit for spare parts, but usually not needing them, because it wasn't as bad as I thought.   Or I'll think "Wow this kit is so awesome that it will be a classic someday" and I'll want another copy to either build again years from now or make (in my head) incredible amounts of money off selling it later.
The end result is that I end up buying two copies of every non-trivial kit I work on.  Do I need a 12-step program?
Please help.  :D
    July 2010
Posted by roony on Monday, June 8, 2015 10:31 AM
You do not need help.  This is completely normal behaviour.  You should however buy at least three or four of each kit in case they do become collector items.  And may want build another in the future.               P.S.  Enlarge the garage and put up shelving units.
    November 2008
Posted by plasticjunkie on Monday, June 8, 2015 11:47 AM
I have seen "discontinued" or "OOP" models go on eBay for an arm and a leg, only to be re-released by the manufacturer a couple of years later or re-boxed under a new label at lower prices.
As far as making a mistake in a build, often times unless you point out the issue, you will be the only one knowing the about the mistake and no one will be the wiser.
 GIFMaker.org_jy_Ayj_O
Posted by Bish on Monday, June 8, 2015 11:57 AM
Not sure you need a programme. I can't say I have ever bought a kit because of either of those things. If I make a mistake I will either live with it or fix it by scratchbuilding.
As for buying a kit because it might be worth money, well don't get me stared on that.
    February 2007
Posted by mitsdude on Tuesday, June 9, 2015 1:04 AM
If I get to a point where I have messed up a kit so bad I need to buy another I'm sick enough of it I don't wanna see it again.
    January 2006
Posted by Wirraway on Tuesday, June 9, 2015 2:21 AM
I doubt I will ever buy a kit again on the grounds that it might become "collectable"  I got burned on the Revell 1/32 Bf-110 (re-popped)  1/32 Bristol Beaufighter (re-popped)  1/32 De Havilland Mosquito (re-popped)  You get the picture  (Mind you, I could be tempted if I ever see the 1/24 Mosquito again)
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
    October 2008
Posted by P mitch on Tuesday, June 9, 2015 6:25 AM
Wirraway
The 1/24 Mosquito is coming back later this year but in a different variant!
www.airfix.com/.../de-havilland-mosquito-fbvi.html
It will be a lot less than people are trying to get on Ebay
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    March 2012
Posted by mustang1989 on Tuesday, June 9, 2015 7:27 AM
If I do an OOB build I will only buy one kit. If I'm doing any custom work or "opening one up" for display I always buy a minimum of two....and sometimes I've been known to buy three. As far as buying for collector purposes.........forget it. For me that's a loosing proposition for the reasons already stated. I buy to build.
 Forum | Modelers Social Club Forum (proboards.com)
Posted by Bish on Tuesday, June 9, 2015 11:15 AM
ASanders
I don't know. Seems like if you have the funds to buy a new kit to get a part you messed up more power to you.
As for kits as investment. Seems like those Wingnut kits are a good place to start. Some of the releases have sold out and their prices have begun going up on secondhand market. It will be funny when they rerelease them and guys are complaining about buying them on ebay at 300% markup.
I don't actually think its that funny when genuine builder's have to buy highly inflated prices for a kit they want all because of collectors who have no interest in the kits or those who just want to make a fast buck. I have seen the same thing with books which when released were around £16 and now go for the 10's, 100's and even on the odd occasion the 1,000's.
    July 2004
Posted by stikpusher on Tuesday, June 9, 2015 12:14 PM
I'm with you there Bish on the guys who buy up kits as speculators, so to speak. On eBay awhile back there were a couple of kits that I wanted but it seemed like one guy had the market nailed on each type. They would buy that kit type every time and then list it for a much higher constant price. Fortunately for me, one was re issued by Revell, and the other I was able to acquire via auctions at AMPS. Doom on you both eBay gougers- Yoda's counsel of patience pays off!
As far as buying multiples of any one particular kit. I do that here and there with the intent of building each one differently from the other. Kit option, conversion, etc. I have bought every kit in my stash with the intent of building it. BUT.... only time will tell if that happens.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Don Stauffer on Tuesday, June 9, 2015 12:14 PM
Once you can scratch build a model you will not have as much anxiety, since you will have confidence that you can reproduce parts from a kit.  Major items like fuselage or wing are hard, but even those can be done.  Try some major conversions to ease your way into scratchbuilding.
    March 2012
Posted by mustang1989 on Tuesday, June 9, 2015 12:29 PM
Don Stauffer
Are you talking casting parts in resin?
    April 2006
Posted by waynec on Tuesday, June 9, 2015 9:41 PM
MARK you don't need a 12 step program, you need a friend who likes to build similar things to what you build.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, June 11, 2015 8:44 AM
My biggest obsession since returning to this hobby after 20 plus years away is finding Hasegawa's 1/72 scale SU-33 Flanker D Ace Combat Yellow Limited Edition. No way I'm paying $100 plus for this kit. LOL!
hasegawausa.com/.../hsgs5212.html
Keeping my eye out on these ones too:
hasegawausa.com/.../hsgs5227.html
hasegawausa.com/.../hsgs5226.html
hasegawausa.com/.../hsgs5225.html
hasegawausa.com/.../hsgs7391.html
    July 2014
Posted by modelcrazy on Thursday, June 11, 2015 9:11 AM
I only buy one of each kit, not because I think I'm good enough not to mess up......please! It's because there are so many more kits out there that I want. I will usually build only one of something and move on. If I mess one up that badly, it goes into the pale of shame, gets relegated to the spare parts box, turns into a crash diorama, or is given to the grandkids for a more horrendous end.
As far as saving a kit as a collector, I tried that with the Accurate Miniatures A-36 and P-51B once. I used to live down the street from Squadron in Carrolton Texas years ago, and would stop by and purchase kits right off the shelf so to speak. Well this brand new company called Accurate Miniatures came out with the A-36 and P-51B and had a pretty gold sticker saying "First Production Run". Well the wheels were turning boy. That was what 30 so years ago? Well I sold them a year and a half ago, before getting back into the hobby on eBay for half of what I bought them for. I wish I had them now, along with the 1/32 Tamiya F-4, and a Tamiya 1/350 King George IV and it's PE set. Those I may buy again.
I'm going to go cry now.
Steve
Steve
    September 2012
Posted by GMorrison on Thursday, June 11, 2015 1:08 PM
Well if it makes any one feel better, I've been to a number of peoples homes to buy kits, where they had them stacked to the ceilings in every room. Usually their wife won't even say hi.
    April 2013
Posted by FlyItLikeYouStoleIt on Thursday, June 11, 2015 1:40 PM
Let's stop *** footin around here. Yes, you have a problem. Yes, you need help. That's why we're ALL here. This is our support group. We don't all have the exact same issues or handle our problem in the same ways but we can all offer some kind of support, help and/or understanding. This is an addiction. The forums here should be called "Fine Scale Modelers Anonymous".
As for buying another of the same kit for replacement parts ? . . .  Hell no! You know, you could just contact customer support for nearly any manufacturer and tell 'em those parts were missing or molded horribly, even with really old models. The kits that give me the most frustration are the ones I am never touching again. Hell I even cringe at the sight of the box art from those.
My main problem is that I'm never really done with a model. Every model I've ever built finds it's way back to the bench some time or another, sometimes for just a little touch-up, other times for a complete rebuild or paint job.
Bill.
On the bench:  Lindberg 1/32 scale 1934 Ford Coupe and a few rescue projects.
In queue:  Tamiya 1/35 Quad Tractor or a scratch build project.
Posted by Bish on Thursday, June 11, 2015 3:18 PM
ASanders
Bish
ASanders
It's a simple case of supply and demand really. That's how the world works. If I don't like the asking pricefor an OOP kit then I don't buy it. But I can't really get mad at someone for having the disposable income and insight to stock up on kits.
Supply and demand is just another way of saying profiteering. I hear that excuse for a number of things, usually by those who want to squeeze every last penny out of others.
That might be how the world works, but it don't make it right and it don't stop me thinking its pretty nasty way to operate.
    March 2012
Posted by mustang1989 on Thursday, June 11, 2015 4:53 PM
FlyItLikeYouStoleIt
You should try that trick with MPC. Those guys have that system all figured out. You've got to supply the original receipt , no copies, to send in when requesting replacement parts. Indifferent Something tells me that word is gonna make its way around to the other manufacturers.......
    July 2004
Posted by stikpusher on Thursday, June 11, 2015 6:09 PM
Wow, that's a rather insulting statement. I would hardly consider scale models a resource. Resources are necessities for one thing or another to keep life, industries, or a society functioning. This hobby certainly is not a necessity. And I don't think that the world owes anybody anything. It's just annoying as sin, when some individual corners the market on an item in this hobby and intentionally drives up the prices on that item. That is manipulation. On a grand scale, or with certain commodities, it is often illegal. Since this is only a hobby and no one but us really cares, it is not. It is simply profiteering by manipulation. It is nice to see when a company re issues a kit and that individual loses out on their marketing scheme.
       - Plankton
LSM
    April 2015
Posted by Mark Lookabaugh on Thursday, June 11, 2015 6:54 PM
Thanks everyone for your thoughtful replies.   I learned more than a few things.  Much appreciated.  :)
    July 2004
Posted by stikpusher on Thursday, June 11, 2015 7:16 PM
Who said anything about demanding a higher grade vehicle? I personally dont care about what car you drive or do not drive. I only concern myself with what I drive because it provides needed transportation to work, for errands etc.. And I do tire of that statement that you are making regarding that. My gripe is about certain individuals who artificially drive up the price of an item in this hobby at a certain location. I have the patience and good fortune of location to look for what I want elsewhere at a more reasonable price. Not everybody on this site here has that luxury.  It's an annoyance, nothing more.
You appear to presume a lot about myself and Bish, whom you do not know, and appear to be lumping us in some category like we a couple of "occupy" or redistribution of wealth types with your condescending statements. I dont know you either, as you are one of the new folks here. But I can tell that you're gonna make lots of friends here and likely be a contributing positive asset to the forums.
Oh yeah, last time I checked, the air containing the oxygen that we breath daily is free and not a paid for commodity.
       - Plankton
LSM
    September 2005
Posted by Sprue-ce Goose on Thursday, June 11, 2015 7:22 PM
Fortunately, some folks prefer Honda or Subaru.
The way kits disappear so quickly from the market these days, I am not be surprised if some buy more than one of each kit.
    July 2004
Posted by stikpusher on Thursday, June 11, 2015 7:32 PM
Sprue-ce Goose
Toast
       - Plankton
LSM
    July 2014
Posted by modelcrazy on Thursday, June 11, 2015 8:36 PM
Mark,
Sorry about this. It sometimes happens to the most innocent of posts. These threads can go off the rails until someone re rails it or the modulators shut it down.
Now back to the original subject, I agree with Bill, we should be called "Fine Scale Modelers Anonymous", so no you don't need a 12 step program.
Steve
Steve
    March 2012
Posted by mustang1989 on Thursday, June 11, 2015 8:50 PM
Good Lord.
    July 2004
Posted by stikpusher on Thursday, June 11, 2015 10:17 PM
AS, your comments are delivered in a rather personal and condescending manner. I suspect this is not the first time this has happened with you online. And it's not exactly very wise to ASSUME someone's outlook on things based upon remarks made regarding a single pastime and one aspect of that pastime. As far as needing a lesson on how the world works, I don't think that myself, or most of the folks here need that. I know that I have been around long enough to get a handle on how the place operates. Life is not easy or fair in any way, shape, or form. Except perhaps in the occasional place where all there follow certain rules, and those that do not, have the penalties of said rule violations enforced upon them.
MC, Mustang, Mark, and any others that I may have put off with my comments above, sorry 'bout that says I.  I just could not move on without saying my piece on the issue of something that I took exception with. I'll leave it at that.Wink
We can now get back to our discussion of the need for therapy or not in this shared obsession of ours.Whistling
Do you count your stash or sheep when trying to fall asleep?Confused
       - Plankton
LSM
    July 2014
Posted by modelcrazy on Thursday, June 11, 2015 10:41 PM
We now return control of your television set to you. Until next week at the same time, when the control voice will take you to – The Outer Limits.
Steve
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, June 11, 2015 11:23 PM
Here we go again.....
Moderator
    September 2011
Posted by Tim Kidwell on Friday, June 12, 2015 7:47 AM
Hi guys,
OK, this started out as fun, but then someone took it too far, attacked some other members, and that isn't allowed here. Measures have been taken to rectify that. I'm gonna close this one down just to let the heat dissipate.
Tim
Timothy Kidwell
tkidwell@firecrown.com
Editor
Scale Model Brands
Firecrown Media
