"Death in the Courtyard" *finished, more pics, page 15*
    October 2004
Posted by sfcmac on Sunday, September 7, 2008 7:25 PM
 I like what I'm seeing. Is that the clear sprue as the water stream? That water spouting thing is something I have seen 100 times and never paid attention to. As far as repilicating the effect that is probably as good an idea as any. You have 2 streams one farther than the other due to pressure. It seems to be coming out as fast as a turned on garden hose with regards to the shape of the arch. Just thinking the closed barrel lid would make more of a chugging effect. Is it a rain barrel? Lotsa thought you could put into such a scene.
The figures are looking absolutely fantastic! The Germans equipment , rifle and the whole works is really convincing and the poses of the G.I.s very tense. Tells a great story.  I'm checking out that wagon as well.
    June 2008
Posted by Hans von Hammer on Sunday, September 7, 2008 9:18 PM
The barrel reminded me of this one:
"Go tell th' boys to line up, Joe. We got fruit juice fer breakfast..."
Posted by Anonymous on Monday, September 8, 2008 7:10 AM
Perfect, Von Hammer---I now have my ref pic for the water !!!
Posted by Anonymous on Monday, September 8, 2008 9:29 AM
 zokissima wrote:
I love your attention to the little details. This one is looking to be a winner, and not to mention an inspiration in composition.
See if you can use heat to warp the stream of water a bit, especially near the end, where it would hit the ground.
Appreciate your looking and the positive feedback...I, too, think that the composition and story on this one will be very cool if it all comes together as I hope...Good idea on the water streams...once the barrel is set in place and the groundwork poured, I do plan on having some sort of a splashing effect where the stream meets the ground---maybe even try to melt some clear sprue for the effect...
    February 2005
Posted by Kevleerey on Monday, September 8, 2008 12:39 PM
Everything looks really good so far. The only thing I might change is, the water seems to be somewhat pressurized. The water would probably only stream like that for a few seconds before running down the side of the barrel. Not having ever seen this happen personally though, I wouldn't know. It would probably also look good if you "painted" the sprue sections with some resin or something to rough them up a little too, as a bullet hole in wood would probably have rough edges. I don't know if an exit wound would make much blood, and this probably wouldn't work well, but what if the pooled water were close enough to the dead guy to mix with the blood? might be kind of a neat effect, though I don't know how feasible/realistic it would be. Can't wait to see the rest of your figs, though, the dead guy is great! By the way, will there be bullet holes/craters in the brick wall? Sorry, I have too much free time between classes today...
--------Kevin
    June 2008
Posted by Hans von Hammer on Monday, September 8, 2008 2:52 PM
A 30.06 bullet hole in a piece of wood is just a hole...  It's the back-side that's damaged...
Another reason I hate Hollywood.. All their "bullets" blow stuff back at the shooter (from the firing of the squibs)...
It would look like blood... Besides, dead guys don't bleed... They leak... Once the heart stops, there's no real bleeding, more of an "ooze" from gravity if there's a lower exit wound.  Otherwise it pools in the body...
    October 2004
Posted by sfcmac on Monday, September 8, 2008 3:06 PM
 I was trying to think on the splashes too? Always very scary when I think.  Way Way back I read an article somewhere about replicating aircraft canopies. Basically coat the other one with vasoline and apply layers of clear nail polish over it drying in between layers. They turned out pretty crappy but the results remided me of a water splash? May be a cheap but effective way to get an effect. Melting sprue may be tough.
    February 2008
Posted by Sherman_Modeler on Monday, September 8, 2008 5:48 PM
The water streams are really cool looking and will look great...I am guessing that the shots came from the "allied" side....that being the case, perhaps you could give the streams a little less arch, because the time it would take to "sneak" around the wagon, the streams would have lost considerable pressure...just athought.
    September 2007
Posted by Mobious on Monday, September 8, 2008 6:26 PM
 Hello MR,
 Was thinking about splashin water. Would it be possible to use a heavy gel medium, something artist use to add thickness/texture paint. The heavy stuff is nearly as thick as peanut butter and comes in either a gloss, semi-gloss, or matte finnish. Think Ol Shep used it for water in a couple of his dio's. Or maybe a combination of the stretched clear sprue and heavy gel.
 Really like the dio so far,Thumbs Up [tup]Thumbs Up [tup]
 Best Regards,
"It's a problem of applied physics" Roy Brown
    October 2007
Posted by panzerguy on Monday, September 8, 2008 8:12 PM
   Manny coming along nice. I'm really looking foward to seeing the GIs painted up.
   Try one min two part epoxy resin for the water splashes. A little bit around were the sprue hits the ground and tease it with a tooth pick. I've not tried this but I've been told it works for bullet's hitting water and the splashes you'll need wont be near as high.
   Also the affect of a high powered rifle round hitting a sealed wooden barrel of water, first the round would go right through and if the barrel was topped off the lid probably would have at least broken its seal if not split. So the water streaming that fast would be plausible imo
"Happiness is a belt fed weapon"
    June 2008
Posted by Hans von Hammer on Monday, September 8, 2008 8:25 PM
I doubt thare would be a through & through with a barrel of water...  Contrary to popular belief, water has a tendency to shatter bullets..
    October 2007
Posted by panzerguy on Monday, September 8, 2008 9:46 PM
  Sorry to dissagree Hans But I've shot 55 gal drum's, both plastic and metal ,full of water and jacketed  rounds have gone clean through.
    June 2008
Posted by Hans von Hammer on Monday, September 8, 2008 9:55 PM
Heh.. Only one way to settle it, Panzerguy... I'll grab m' k-98 and head out to the bro-in-law's tomorrow...  He's got a pretty good junkpile back in the woods with good berm and I got a thousand rounds of FMJ 7.62 NATO... Think I can spare a couple dozen clips fer science...Big Smile [:D]
Even if I'm wrong, I get to shoot...
    October 2004
Posted by sfcmac on Monday, September 8, 2008 10:01 PM
 Had to go test this one out! Tried a couple of old kegs full of water! Open top and closed. The non- jacketed stuff  didn't go through but probably cuz it splattered so bad on impact. 22 cal. Jacketed stuff went through but not straight. Came out but no real pattern. Up down side all over. AS far as the water you can get away with just about anything captureing a moment in time. Does all kinds of stuff has a mind of its's own.
 Now when the Sheriff shows up to investigate gun-fire. Just tell him your doing research for Death in a Court Yard. Manstein's revenge  needs to know and will settle the dispute between PanzerGuy and Hans von Hammer!
Yeah that'll work! Whistling [:-^]
    June 2008
Posted by Hans von Hammer on Monday, September 8, 2008 10:05 PM
Sadly, I gotta wait... I live over a ta-ta bar in Campustown at ISU, so random gunfire at night would bring more attention than I care to get from more LEAs than I care to deal with...
    October 2004
Posted by sfcmac on Monday, September 8, 2008 10:22 PM
Hey go for it! The story will work! If you can't trust an Ex -Army Recruiter who can you trust?
    June 2008
Posted by Hans von Hammer on Monday, September 8, 2008 10:32 PM
Did a two-year stint as a recruiter... I KNOW the answer to that...Big Smile [:D]
Posted by Anonymous on Monday, September 8, 2008 11:23 PM
LOL...you guys are killing me !!!! Only in this Forum would a couple of guys go out and research balistics for my newest dio ! Hey, but it was intersting stuff: so far it sounds like I have free reign on artistic license unless Von Hammer comes up w/ different results...lol...Laugh [(-D]...I was sorta surprised to hear how easily rounds traveled through that much water and went "through and through"...in scale terms I's say that barrel is about 2-3 scale feet wide at the center??? That's a lot of H2O...
    February 2008
Posted by stick man on Monday, September 8, 2008 11:56 PM
I don't know about that.... because in the dio it a German who got hit so would'nt you need an allied wepon you'll have to ask Manny what kind of weapon did the shooting LOLLaugh [(-D]
Great work on the dio Manny the water from the berole is prety cool.
Smile [:)]
I'm 15 and I model I sk8board and I drum what could be better.
    June 2008
Posted by Hans von Hammer on Tuesday, September 9, 2008 12:33 AM
Smile [:)]
My Mauser is an Israeli-modified K-98.  It's chambered for 7.62 NATO/.308 Winchester... So I'm firing "Allied" ammo through an "Axis" rifle... .30-06 of WW2 is the same size bullet as the .308, it was just a longer cartridge...
Posted by Anonymous on Tuesday, September 9, 2008 11:00 AM
Smile [:)]
Thanks for looking in...the shots in this case came either from an M1 carbine, an M1 Garand or a Thompson 45...I'm guesing though that the bullets in the German were from the point man carrying the carbine, and if you'll look closely, he's reaching for a fresh clip to reload...As far as all of the stray shots (some will later be added to the wooden fence and small building)---they came from the three types listed above...
    June 2006
Posted by SteveM on Tuesday, September 9, 2008 2:15 PM
Yeah, the water effect is kick-aische
Steve
Steve M.
On the workbench: ginormous Kharkov dio
    January 2007
Posted by the doog on Friday, September 12, 2008 8:49 AM
Outstanding job on the water streams, Manny.
Here's my take on it.
With recognition of the "physics" of the whole issue, and with respect and deference to the smarter-than-I people here arguing that point, I think that the "spouting water" effect conveys precisely what you want the viewer to take away from the scene. This is a perfect example of "Artistry" in action!
How many times in Holllywood movies do you see something where you know that the laws of Physics are being egregiously broken, but you still say "WOW! That's COOL!!", and you "get" what the director is trying to say? Like the latest Indiana Jones movie--the whole thing was an abuse of Physics! LOL!
Visually, it's like putting a huge pair of shoes on a guy to show that he's clumsy just by looking at him.
I would say don't change a thing--the artistry implicit here makes it perfect for the scene. People looking at that spouting water are gonna say "Oh COOL! Look at where the bullets hit the water barrel!" They're not going to argue the physics of the thing. Smile,Wink, & Grin [swg]
    June 2008
Posted by Hans von Hammer on Friday, September 12, 2008 12:25 PM
Steel on target, doog...
    January 2008
Posted by Bodge on Friday, September 12, 2008 2:12 PM
The whole thing is blo*dy auwfull because i didnt do it ,LOL. i like everything about this one so far. the casuaty is painted well the layout is very good and the barrel is     well  Spot on! Just a simple thing like that and its made the scene so much more interesting. Its ideas like that that are worth thier weight in gold in my oppinion.Well done.
I might have to pinch that idea in the future Manny but dont worry i will pay you royaltiesSmile,Wink, & Grin [swg]
Posted by Anonymous on Friday, September 12, 2008 8:28 PM
Thanks, doog...only you could have articulated that as well as you did...I appreciate the props and your looking in...hope to have the US figgies on by this weekend or early next week...
Posted by Buddho on Friday, September 12, 2008 9:39 PM
When you do a dio...you create art, Eric....I love the leaking barrel! Bow [bow]
Posted by Anonymous on Saturday, September 13, 2008 12:28 AM
Wow...thanks, Steve, Bodge and Buddho---coming from artists of your caliber I am flattered...I think that the barrel, once it is set in place and I refine the leaks and create the splashes and pools on the ground, it will even look more realistic...I hope to have this one wrapped up within 2 weeks...GI figgies coming soon.  Thanks for looking in!
    February 2005
Posted by Kevleerey on Sunday, September 14, 2008 12:03 AM
Hi,
  I didn't mean it didn't look good or anything, I think it looks great. The barrel will look really good the way you are making it, I just wondered whether that was something you thought of. At least maybe it gave some of us a reason to go shooting...
---Kevin
    December 2006
Posted by Jester75 on Sunday, September 14, 2008 1:05 PM
Bow [bow]
What more can I say?
Eric
