Update April 14th, "Achtung! Mach schnell"
    August 2007
Posted by doc-hm3 on Wednesday, April 1, 2009 5:24 PM
 I have been working on this my first "DIO" relentlesly for quite a while now. Trying to get the groundwork just right has been no small task. I have practiced laying different kinds of grass and weeds and brush and bushes and trees, and I think I have come up with the final result. Here are some pic's for your critique.
        Thanks for looking, doc
All gave some and some gave all.
    July 2003
Posted by Dwight Ta-ala on Wednesday, April 1, 2009 5:59 PM
Very peaceful and solemn scene. Great job!
    February 2009
Posted by Inka Holmes on Wednesday, April 1, 2009 6:06 PM
Nice work mate.I love the Life rune:)
www.modelarmour.com http://www.modelarmour.com/gallery/data/500/Sig01.jpg
    December 2003
Posted by psstoff995 on Wednesday, April 1, 2009 8:04 PM
WOW!! I was wondering how this was going... this looks amazing Big Smile [:D]
Thumbs Up [tup]Thumbs Up [tup]
What materials did you use? I love the tree
-Chris
US Army Infantryman
    February 2008
Posted by stick man on Saturday, April 4, 2009 11:56 AM
Wow! great work Thumbs Up [tup]Thumbs Up [tup]!
How did you make the tree?
Smile [:)]
I'm 15 and I model I sk8board and I drum what could be better.
    August 2007
Posted by doc-hm3 on Saturday, April 4, 2009 4:04 PM
  Dwight, Thanks for the comments. Inka, I thought about my first two grave markers, and believe it would have taken way too long to make them and then just where eould they have found the materials to make them. After surfing the net for more grave markers, I found the marker that you used was the one most used in the field, that is if the crew could find the time to even make one. Thanks for your comments. Chris & Orion, Thanks for the interest in the tree. I made it out of floral wire (very easy to bend). You have to determine how tall a tree that you want, say 10", you then cut around 16 pieces of wire 30" long. Now fold the wire in half over on themselves, you will now have 32 strands of wire 15" long. at the bottom make a loop about 3" long by placing the fold/loop in a vice and twist the loose ends to the length that you want the first branch to start. Take 4 strands and start twisting them to form the first branch, you can also add extra wire in the twisted branch/trunk to make smaller branches. Now continue up the main trunk and make another and then another until you are finished. Remember to trim each branch so that the tree will taper as you build to the top of your tree.
  Cut the bottom loop in the middle and form the root system by twisting the wires again. You can bury the roots under your base to give your tree good support like a real tree.
  To cover the wire skeleton I used tile grout, the powder type that you mix. Use an old paintbrush (maybe 1/2")to apply it to your tree. First hold the tree upside down and apply the grout to the underside, then turn it upright and apply from the top going down. aif you want you had better carve the bark into it before the grout hardens too much. Now allow it to dry.
  Now paint your tree with either oils or acrylics. Alow to dry.
  I used "Scenic Expess' " super trees by following their instuctions, then gluing them to the tree branches. I then used "Woodland Scenic's" glue to spray onto the tree branches (mask the main lower trunk)and then I sprinkled "Woodland Scenic's" fine turf onto the tree. start with less than more, you can always add more. After it dries for a few minutes turn the tree upside down and lightly shake to get the excess off. If you like you can add more, again use restraint.
  Ater this all dries you will want to paint/airbrush your tree. Darker shades for the inner shaded part of the tree and lighter differing shades for the outside of the tree.
  There you have a rather short tutitorial on how to make trees.
        Good Luck, doc
    August 2007
Posted by doc-hm3 on Friday, April 10, 2009 8:03 PM
 The crew of this Recon 234/4 was forced into an engagement, and one of the men was fatally wounded. The driver made good thier egress and traveling at 40-50kph and lost thier adversaries.
 They found a quiet farm field by a creekbed where they deicded to lay thier friend to his final resting place under the shade of a tree. Ever watchful is the Sgt.Maj. scanning the horizon for enemy movement. As the driver is placing the last few stones on thier friends grave, the Sgt. glasses an enemy column to the east, and calls out "Achtung! Mach Schnell" as the gunner rams home a round into the chamber of the Pak40 with a very pissed off look on his face.As the driver turns his head towards the sound of the Sgt's. voice, just for a moment he wonders, When will this all end.
  Here are a few more pic's that I shot this evening.Huxy, here's the empty shovel clamps/rack
  As always, your comments are valued. doc
    February 2005
Posted by russamys on Friday, April 10, 2009 8:27 PM
You know, when I first looked at your diorama, I didn't think it made sense - the crew looking like they are engaging a target while someone is tending to a grave.  But once I read your narrative of the event, it all made sense.  Great job!
Russ
    January 2007
Posted by the doog on Saturday, April 11, 2009 9:04 AM
Great effort here, doc!
All the elements look nicely finished, and the composition is great--that's the one thing lacking in so many dio's, but you've got it spot on, here.
The only small critique I would offer is to sprad a little more dirt around that gravesite--digging a hole invariably puts more dirt around your hole than you have portrayed there. I'd just sprinkle some dry, loose dirt over the area where the soldier is kneeling. Let it lie in between the blades of grass,like where he would have transfered it from the pile there to the actual grave.
Posted by Anonymous on Saturday, April 11, 2009 10:06 AM
Very nice...one thing that I did notice though that their were no markings on the vehicle...I have never seen an armored car or halftrack w/o at least license plates...this vehicle would have most probably also had national crosses, as well...good groundwork!
    August 2007
Posted by doc-hm3 on Saturday, April 11, 2009 6:04 PM
 Doog, I appreciate the comments and help. I will add some more dirt where you specified.
 Manny, I also appreciate your comments. Addressing the markings and plate numbers, I have read, and now I do not remember where that in the last months of the war a good number of tanks and especially recon vehicles wore no markings whatsoever as is portrayed in my instruction sheet for the number two painting/decal option for my 234/4 Thanks for the help, I do value your opinion.
   p.s. She did take best of show at a local show today.
        Thanks, doc
Posted by Anonymous on Saturday, April 11, 2009 6:32 PM
Good job!  Congrats !!!!
    December 2003
Posted by psstoff995 on Sunday, April 12, 2009 11:16 AM
The plaque looks right at home with your dio! Congrats!
-Chris
US Army Infantryman
    January 2007
Posted by the doog on Sunday, April 12, 2009 8:45 PM
Congrats, doc! That's gotta feel good! Thumbs Up [tup]Make a Toast [#toast]
    August 2007
Posted by doc-hm3 on Monday, April 13, 2009 9:27 PM
Manny, Chris & Doog, Thanks for the encouragement! Doog, updated pic's for the grave coming soon. It's been a chore to type these last two weeks with a pinched nerve in my shoulder & tendenitis in the elbow.  It has hurt like the dickens to finish the "DIO", but there is a rather large competition in Kansas City, Mo. (Lees Summit) this coming Sat. 4/18 that I have been working toward for the last 8 months. So I just tried to work through the pain. I am going with some other friends for the fun of it, with no expectations.
        Thanks, doc
    August 2007
Posted by doc-hm3 on Tuesday, April 14, 2009 6:29 AM
  Doog, Here's the update on the grave pic's, These were taken indoors late last night, bad lighting.
    February 2005
Posted by Kevleerey on Thursday, April 16, 2009 10:29 AM
Really? Where at? I didn't know they had competitions or shows around here. Where do you live, by the way? I live near Kingsville. (near Pleasant Hill, about 50 Mi. SE of KC)
------Kevin
    July 2004
Posted by stikpusher on Thursday, April 16, 2009 11:07 AM
actually the life (or birth) rune points up, as seen in the center of the "peace" symbol, when pointing down like in the diorama, that signifies death.
 Beautiful Diorama Doc!Make a Toast [#toast] A very well deserved award!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2007
Posted by the doog on Thursday, April 16, 2009 12:54 PM
doc, that dirt pile and the surrounding dirt there really look muc better! Great addition! Big Smile [:D]
    August 2007
Posted by doc-hm3 on Thursday, April 16, 2009 4:21 PM
 Kevin, Here's the info. "IPMS WEST CENTRAL MISSOURI" Holy Spirit Catholic Church 1800 SW M-150 Hwy. Lee's Summit, Mo.
2009
IPMS ShowMe State Modelers
Model Fest
Date: Saturday, April 18, 2009
Location: Holy Spirit Catholic Church, 1800 S.W. M-150 Hwy, Lee's Summit, Missouri 64082
Contest:
Anyone is welcome to attend and enter. You need not be a member of IPMS-USA, however, if you plan on entering a model in the contest it will be judged under IPMS-USA rules which includes the NO SWEEPS RULE. These rules can be accessed on the IPMS-USA website. Click on this link to view the contest rules for this model contest
Contest registration is from 9AM to 12 Noon. Model entry fees are as follows: Adult (18 and older) entry fee is $12.00 for for the first three models, $1 for each additional model. Junior (17 and under) entry fee is $7.00 for unlimited number of models.
There is no charge for visitors who are not entering the contest.
Contest Chair - Marty Nevshemal - 816.916.8613
Head Judge - Ron Reynolds
Awards Coordinator - Ron Reynolds
Trophy Sponsorship Chairman - Brian Aldridge
If you are interested in Sponsoring a category let Brian know ($20 & $30)
Thank you for all the sponsorship to date - over $300
Vendor Coordinator - Larry Hawkins
Registration Coordinator - Rich Lucero
Raffle Coordinator - Norm Trigg
Categories:
We will have in excess of 35 categories, 1st, 2nd and 3rd Place plaques, Letter sized Honorable Mention Certificate, suitable for framing. Both plaque awards and Honorable Mention are in full color. Dick Clay Memorial Trophy (See separate page for the DCM Trophy information).-->
Raffle:
Tickets offer a chance for a great model kit at a very lost cost. Raffle tickets are $1 each, or six for $5.
Vendors:
We have a limited number of tables available, on a first come first serve basis. The first 2 tables will be $20.00 each. The third table is free. Additional tables (4th and up) are $10.00 each. Chairs come with the tables as required. Contact Larry Hawkins , or you can use our online registration form. We are eager to work with you. Call or email us soon and make your reservation. Larry's phone is 816-294-3981. CRM Hobbies (www.crmhobbies.com)
Sprue Brothers Models (www.spruebrothers.com)
Wings N Treads (www.wingsntreads.com)
Robert Brown (Seamless Suckers)
Fred Amos
Frank Holsburg
Ron Reynolds
Tim Dike (www.modelwarships.com) -->
Sponsors:
We are also seeking sponsorship of trophy packages. The "BEST OF" trophy packages are $30.00. The "PLACE (1st, 2nd, 3rd)" trophy packages are $20.00. We welcome any club, individual, or business to sponsor the awards. Please contact the Trophy Sponsorship Chairman Brian Aldridge or call 816.718.0257
We at the WCMO-ShowMe State Modelers look forward to seeing you on April 18th for a fun day of modeling comradeship and competition.
Marty Nevshemal
President of WCMO-SMSM
Click here to Download Flyer
-->Click here to Download Categories List
Click here to Download Contest Rules
Click here to Download Contest Flyer
        doc
    January 2008
Posted by Bodge on Friday, April 17, 2009 5:42 PM
A really nice Dio , i like it a lot, and congatts on award  well deserved.
    August 2007
Posted by doc-hm3 on Friday, April 24, 2009 5:08 PM
  Stikpusher, thanks for the comments. Doog, I appreciate your keen eye for detail and willingness to help. Bodge, Thanks for looking, and your comments.
        doc
Posted by senojrn on Friday, April 24, 2009 10:55 PM
Doc, it was great to see your work up-close and in-person at the KC show!  That was a pretty good show--lots of entries, lots of people and a lot of good competition in nearly all categories.  Again, VERY NICE WORK!
