Update on dio "Walk with me Lord"
    November 2007
Posted by Recon1 on Friday, March 26, 2010 3:38 PM
The last update showed battle damage to the aircraft, now it has the blood stained canopy and pilot, but still lacks the twisted nose gear and the prop blur on the port engine.
By countyhunter at 2010-03-25
The base is a large piece of  plywood cut for a cyclorama not a diorama. Using scrap styrofoam as a base for the sand dunes. These will be covered later with paper mache.
Made some palm trees, maybe they will look better with leaves. Placed them in relationship with the P-38 and other BG debris, barrels, netting etc.
Next temporarly mounted the aircraft to get a look at how I'd botched things up.
Pardon the background of the tool bench, Please all comments,criticism and hints are very welcome.
Posted by berny13 on Sunday, March 28, 2010 7:52 AM
I think I see what you are trying to achieve.  One thing that really sticks out are the bad seams on the aircraft which needs to be cleaned up.  That is the first thing one will notice.  How do you plan on mounting the aircraft to the base?
Berny
 Phormer Phantom Phixer
On the bench
    November 2007
Posted by Recon1 on Monday, March 29, 2010 5:51 PM
Can't get the pics to load but I've bent a piece of spring steel up inside the landing gear and bent it at a angle to just get the port side wingtip above the ground. Yes I agree the model is trash which exactly what it was. Out of the junk pile that I use for experiments. Thanks Don
Posted by senojrn on Friday, April 2, 2010 10:45 AM
Just a suggestion, maybe feather the starboard props (turn them into the wind--90 degrees from usual) to show that engine/prop has stopped.  Just a thought, looking forward to more pics!  =0)
    November 2007
Posted by Recon1 on Sunday, April 11, 2010 9:06 PM
Got the prop feathered and here's a pic of the mounting of the plane to the base.
By countyhunter at 2010-04-10
    December 2003
Posted by psstoff995 on Friday, April 16, 2010 10:57 AM
Very cool concept looking forward to more- I like that seconds before full impact look
-Chris
US Army Infantryman
    March 2008
Posted by modelchasm on Sunday, April 18, 2010 4:20 PM
I think I get the quick jist of the idea, but I sure would like to hear more of what you want/ what you have planned ....
I don't think the plane looks like complete trash, but then again its not done yet either ..... Just another work in progress .....
Lookin forward to more ....
"If you're not scratching, you're not trying!"  -Scott
    November 2007
Posted by Recon1 on Sunday, April 18, 2010 9:26 PM
The P38 was built then about a year later completely torn apart to experiment with various ideas, it was rebuilt after I came up with a dio or better yet a cyc. The story is wounded pilot trying to land a crippled ship with no usable nose gear and jammed starboard gear plus a hung up bomb. Pacific Island, palms and usual crates, camo, sand bags barrels etc. Behind the entire set will be an almost semi-circle of sky with clouds. Hope to have the dunes and maybe the palms before the weekend. Thanks to every body for looking. Don
