Sealing wooden bases
    January 2008
Posted by somenewguy on Saturday, January 19, 2008 6:28 AM
What do I use to seal wooden bases from warping and what not? And is there any other preparation I need to know about for wooden bases? Cheers!
At the end of the day one's work may be completed but one's education never!
    January 2007
Posted by the doog on Saturday, January 19, 2008 9:27 AM
You can use a good water sealer, like Thompson's Outdoor Water Sealer, and just for good measure and extra insurance, hit it with a heavy coat of acrylic sealer after it has thouroughly dried.
Or, use shellack, and then seal that with an acrylic sealer. I've been pretty successful with both of these methods!
    April 2004
Posted by vespa boy on Saturday, January 19, 2008 9:52 AM
Warping is aonly a major iussue when you use a single plank of wood. If you use plywood its not really an issue as each layer has the grain running at 90 degrees to the layer above and below.
If you are going to coat the wood with a varnish type material, do it all over, top bottom and sides. The idea is to limit the penetration of humidity into the wood.
http://public.fotki.com/nkhandekar
This ain't no Mudd Club, or C.B.G.B.,
I ain't got time for that now
    January 2008
Posted by somenewguy on Saturday, January 19, 2008 7:44 PM
Thanks fellas!
Posted by senojrn on Monday, January 21, 2008 11:49 AM
I stain my wood bases with Minwax Wood Finish in the spray can, usually 1-3 coats.  Then finish it up with Minwax Polycrylic Sealer in the spray can, again 1-2 coats.  Had no problemswith that method! Smile [:)]
