Nathan T
Interesting build Fly. I really like your clean paint work. I'm curious about the micro mesh job. I've tried that in the past in hopes of skipping the initial gloss coat, but as I sand the model down with the micromesh pads I seem to nick corners and raised areas and it sands through the paint and I always have touch ups to do. Trailing edges seem to be the worst. Maybe I'm being too aggressive?
When I start with the 4000 grit cloths I tend to use really light pressure. The only places that I need to touch up (because of the polishing) are the spots where I pressed down a bit too hard... and most of those spots were around some raised panels or corners kind of like what you're saying. But there were only 2 or 3 spots that needed to be repainted.
So I guess its just a matter of using a light touch.
I'm working on an airliner now and I've been painting the wings black (for Alclad II Airframe Aluminum) using Tamiya TS-14. During the first coat or two I was polishing down to the primer a little bit. But after the third coat I was just getting a nice glossy black finish. So the number of coats makes a difference.
