My first plane, Revell 1/48 P47 SQ.201 WWII Fuerza Aerea Mexicana
    March 2013
Posted by garzonh on Monday, April 6, 2015 5:43 PM
Hi to all!!
Well, after building only armor for the past years, I was always wanting to build a P47, from Mexico Squadron 201 during WWII who fought at the Philippines. Geeked
Since it is my firts plane, I did not want to buy an expensive $200 USD kit, nor any aftermarket kits, e.g., seat, cabin, engine, etc. I only bought an Aztec model decals from 201 SQ.
The kit did had a LOT of fitting issues, misalignments and not clear instructions on where to put things, being my firts plane I had to sometimes wonder how to glue and secure parts. Huh?
is this the same case with other kits?? Surprise
The build was fast due to the very small number of parts, it is much easier than a tank with small suspension and track link parts BUT it is more difficult to keep parts aligned being the nature of the tolerances of a plane. Also, any damage you made to a tank, is always a battle damage, but with planes this is not possible, like a missing tail... Surprise
I painted with Alclads, and also it is very difficult to use them, I had some orange skin texture in some parts, painted two tone aluminum for variation.
Finally decals, which also I had some problems with Mexican colros in the tail, so, I decided to paint them,
being armor guy, I do not like things "clean" I gave it some sooth pigmentings, dark wash, and chipping on some areas.
The cockpit looks good for me, I wanted to build a better seating, but...naahh... not for this one. I do made my first scrathcbuilt of the seat bealts. Made with fasteners and harness of a 1/35 fuel tank of an IS3. Left other parts unpainted to make it look as bronze.
All in all, I like how it turned out, I want to donate it to my local state army museum... Wink
Im making a wooden base  with the plane seating in the airfield, with the tail seating on a grass.
What do you think?...now..I think Im hooked with planes....or maybe a choper... Huh?
See you!
    September 2012
Posted by GMorrison on Monday, April 6, 2015 6:02 PM
Very nice job, Garzonh.
(This guys builds fantastic armor).
One glitch- the national insignia on the right side is upside down.
I like it a lot. We'll be doing another Latin American Group Build soon.
    March 2013
Posted by garzonh on Monday, April 6, 2015 6:11 PM
HI Gmorrison!
Thanks a lot!!!
Not sure what you mean by upside down??..looks the same as all photo references.
Yes, maybe I will participate...will it be planes also?
    March 2013
Posted by garzonh on Monday, April 6, 2015 6:14 PM
OOOOOHHH...now I see it.
You mean the star...yes.. newbie mistake.
    September 2012
Posted by GMorrison on Monday, April 6, 2015 7:14 PM
    January 2015
Posted by GreenStyrene48 on Monday, April 6, 2015 7:38 PM
Looks really nice! I'm about to try out alclad too. I've been priming and sanding over and over.
Posted by Gamera on Tuesday, April 7, 2015 7:39 AM
She looks fantastic- you should build more aircraft!
Btw; If you have a spare national insignia on the sheet you could you just apply it over the one already there to fix the problem.
    March 2013
Posted by garzonh on Tuesday, April 7, 2015 7:58 AM
Thanks Gamera!
Yep, I will fix it...hmmm...If I use decal solving solution I might be able to remove it, and then apply the one the kit had. I used the ones from the aftermarket.
Thanks for your advice.
Sure. I will build more aircraft. Maybe a P51, I want to use my Alclad paint again...
    September 2012
Posted by GMorrison on Tuesday, April 7, 2015 10:39 AM
A risk you run is having the original show through the new one.
You could easily put a black circle on the star, then the circular part of the new one over it, should be a piece of cake for you.
    March 2012
Posted by mustang1989 on Tuesday, April 7, 2015 11:03 AM
Looks good garzon!! Man I feel your pain on the insignia bud. I put the wrong decal on the wing of my Corsair build not too long ago and after a couple of attempts to remove it (I will admit that I didn't try all that hard as the Revell Corsair is a BIG POS kit and I had a lot of issues with it and didn't want to risk the only thing that did go right which was the paint!) I shot paint over the decal and applied the correct one over it. (I will admit that the kit instructions actually show the decal placement incorrectly!!!)
  Again, that's a good lookin' build there.............especially for your first one! Wink
Hope to see more like this out of you man.
 Forum | Modelers Social Club Forum (proboards.com)
Posted by Gamera on Tuesday, April 7, 2015 11:27 AM
Yeah, if you want to try to remove the decal it should work if you didn't put a coat of varnish over it. As you said just soak it in decal setting solution until an edge lifts and then very carefully work a soft brush under it and slowly and carefully work it free.
    September 2006
Posted by the Baron on Tuesday, April 7, 2015 11:37 AM
Your NMF is beautiful, well done!
I have this kit in my stash, because I was curious to see how it's engineered, compared to the pre-merger Monogram P-47D kits.
    January 2015
Posted by GreenStyrene48 on Tuesday, April 7, 2015 2:21 PM
The only weird engineering things are that the inner gear doors and landing gear legs are integral to the wheel well parts. Must have gotten in the way during painting. That and the instructions show the gun tubes backwards! I see lots of these that make that error. Garzonh got it right.
    April 2014
Posted by B_one fixer on Tuesday, April 7, 2015 6:22 PM
Looks great ! I did the same build and squadron in 1/32 scale a few months back.
    March 2013
Posted by garzonh on Tuesday, April 7, 2015 6:32 PM
Gmorrison, thanks for your words of encouragament and appreciation the are very valuable to me..Embarrassed
mustang1989, yep, I guess everyboy had done an error here and there, specially on your first of everything, first paiting, decaling, weathering..this was just an unexcusable error by me... Super Angry  Yep, bad instructions are also part of making mistakes, not too clear and too detailed. Thanks for you comments, coming from someone so experienced with aircraft it does mean a lot to me. Bow Down
Gamera, yep, tahankfully I did not added any varnish or even glued the decals with micro scale setting solution, so it went away easily. Yes
theBaron, well, I must sadi its a cheap kit and it shows, I had lot of fitting issues, and the wheels are very fragile, lot of flash not very sharp lines, so all in all, is a cheap, fast, fun kit to build. But not for a huge impression or detailing.
Greenstryene48, thanks, I did looked at several photos of actual planes, in order to understand where things are placed, attached, specially, cockpit interior and others...again thanks to lack of clear instructions. Thanks for the comments. Yes
So, fixed the decal, here it is...in a not so nice picture.
    February 2012
Posted by lawdog114 on Tuesday, April 7, 2015 8:07 PM
First aircraft?  Wow, very humbling. Its hard to do an NMF which is all the more impressive...Nice to see an N built for a change.
Joe
    September 2012
Posted by GMorrison on Tuesday, April 7, 2015 9:41 PM
So what's next?
    June 2013
Posted by bvallot on Wednesday, April 8, 2015 11:53 AM
Well garzonh:  For a Revell kit...you turned this into a pretty nice P-47!!  Can't beat Alclads line of paint for a NMF.  I love that stuff and you did a real nice job with painting and weathering.
For your wooden base, I might suggest you get a placard made listing who flew the plane and possibly something notable but brief for it.  Maybe at least even mentioning the type of plane and the air group it flew with as well.
On the bench:
Tamiya F4U-1  Kenneth Walsh
    March 2013
Posted by garzonh on Wednesday, April 8, 2015 6:08 PM
lawdog114
Joe
Yep, its my first and as said not the last one for sure.
Now this becomes a problem on what to buy at the local store, previously i only had to choose tanks...
Thanks for your comments, Big Smile
    March 2013
Posted by garzonh on Wednesday, April 8, 2015 6:09 PM
GMorrison
So what's next?
Not sure..hmmmmm.....Huh?.. I want to build a Mustang or a Sabre in NFM....but I maybe doing a chopper...decisions decisions..
    September 2012
Posted by GMorrison on Wednesday, April 8, 2015 6:13 PM
The venerable old Monogram Sabre is a classic and a fine kit. If you can find "The Huff", that was our friend Hans' uncle's plane.
    March 2013
Posted by garzonh on Wednesday, April 8, 2015 6:19 PM
BVALLOT, yep, I already had something in mind... Geeked
I wanted to set in stationed in the airfield...so I added my pavement, some turf and ..... since my plane is not perfectly clean... Embarrassed why should the tarmac??...so I jus throw everything I had...pigments, dust, oil and diesel marks, some grass growing through pavement cracks, etc...still looks boring...hmmm...I wanted to add some figures, but Im just not good at them and dont have time...I have a local IPMS exhibition/contest in one week...so...maybe just add some leafs and a plaque.
Here are the photos:
Without the plane with a birght light to show up details.
See you around. Yes
    March 2013
Posted by garzonh on Wednesday, April 8, 2015 6:21 PM
Thanks Gmorrison I will surely consider.
    September 2012
Posted by GMorrison on Wednesday, April 8, 2015 6:23 PM
Well I hope you do well!
One interesting thing about Jugs, I have some photos.
When they taxied out for take off, the crew chief often lay on the wing hanging on to a gun barrel and signaled turns with his arm, because the pilot could not see over the cowl.
