Just a side distraction to keep the *** flowing.
I started by scratch building some details, either missing, or just because I wanted to.
Those trim wheels are way to far up and back but I'm leaving as much of the original kit as possible just because I feel like it. So they stay where they are.
The kit supplied instrument decal took a few swipes of liquid cement before they laid down. They don't fit the panel so be careful in your planning when you get to this point. You'll need to cut them up and place them in four parts.
The belts are made out of painter's tape and bits of styrene for the buckles.
I made myself a scribing tool. I sacrificed a dull No.11 blade and then sharpened it back up with a stone.
It works perfectly :)
The spinner decal took some serious working-over with 7 applications of liquid cement to get them to settle down. I left it over night and still had to do a bit of sanding to get rid of the stuff that wouldn't settle.
After some painting and a gloss cote it worked out fine.
The parts still fit together really well. I've only had to use some putty just to blend things together.
A cote of dull and the spinner is finished until weathering.
Seams are in good order.
Spinner looks good on her.
And this is where I'm at with this one.
Thanks for peeking at it. :)
Toshi! If you can find this kit, you will love it. It goes together really well. :)
