US, P-51D-20-NA, 44-72218, Big Beautiful Doll, Lt. Col. John D. Landers, 78 FG, 84 FS
    November 2015
Posted by ArmouredSprue on Monday, November 9, 2015 8:52 PM
Hi all!
For my next project I have chosen the excellent new tooling Airfix P-51D in 1/72nd scale (A01004).
I'll try to make the personal airplane for Lt.Col. John D. Landers, the P-51D-20-NA, 44-72218, Big Beautiful Doll, , 78 FG, 84 FS which I consider as one of the most colorful Mustangs on WWII.
Will be using this decals from Eagles Decals
The Mustang Wings...
One of the most important features of the Mustang was a wing designed using laminar flow airfoils which were developed co-operatively by North American Aviation and the National Advisory Committee for Aeronautics (NACA). These airfoils generated very low drag at high speeds.During the development of the NA-73X, a wind tunnel test of two wings, one using NACA 5-digit airfoils and the other using the new NAA/NACA 45–100 airfoils, was performed in the University of Washington Kirsten Wind Tunnel. The results of this test showed the superiority of the wing designed with the NAA/NACA 45–100 airfoils.
P-51D on the Inglewood assembly line
In the photo above we can notice that all panel lines on the upper wings have been carefully filled, smoothed and primed before application of (on natural metal Mustangs) final coats of high speed silver lacquer. Even small flaws on the surface of P-51 wings could cut performance.
Another photo from the book P-51 Mustang in Action (Squadron - Aircraft No. 45) showing the Dallas production line, we can see that the main wing panels are painted in primer, prior to being sprayed silver. All P-51Ds were painted in this manner.
This is a characteristic mostly overlooked in Mustangs scale models and I decided to replicate it.
Firstly I searched for a schematic showing which panels should be filled, after looking on several modelling forums, I came across the below schematic:
The photo below also helps to confirm this schematic, note how smooth is the wing surface.
So I started filling the panel lines according to the schematic above.
The original kit part with all the panel lines
Panel lines filled using melted sprue
In the photo above you can see the panel lines filled with my own putty recipe, which is just melted plastic sprues. I use Tamyia Extra Thin Glue to melt sprue parts, just cut small pieces of sprue and cover it with Tamiya Extra Thin Glue and let it aside for a couple of days, add more sprue parts or glue until achieving the desired consistency. I apply it to the model using a toothpick and let it dry/cure for at least overnight before sanding with 400/600 and 1200 grit wet sandpaper.
Here the final result after sanding it all flush.
I've built the interior. Airfix did a good job and it is well detailed. The panel is a decal but for this scale I think is more than enough.
 The fit is just perfect. Everything just click into position.
I've done the interior of the landing gear covers, I've tried to replicate a panel shade difference that is very noticeable in Mustangs, so after painting it gloss silver and weathering it with Tamyia Panel Accent, I mask the panel and applied a flat clear coat. You can see the difference in shade on live, but not in the photo.
I've used an Eduard painted PE set for USAF WWII. It rally adds a lot to the cockpit.
The radio still needs to get wired. The floor is the characteristic timber, in front of the stick control you can see the top of the wings and it is painted Yellow Chrome (Tamiya XF-4) the timber floor is Vallejo old timber.
I decided to paint the cooling exhaust area in aluminium since my references pointed this way.
Exhaust air intake. Note the aluminium colour and also the reinforcement bar in the middle.
Time to put wings and fuselage together. No dramas here and they fit perfectly requiring almost no putty. I've sanded with wet sandpaper grit 600, 800, 1000 and 1200, and than re-done all lost panel lines.
I add some wiring to the radio set. Not much reference here, so I took some educated guess...
I also mask the canopy and windshield using Tamiya tape.
Painting time!
I started by airbrushing a nice, smooth and bright black paint using Tamiya X-1 with a few drops of Future.
Followed by Tamiya Titanium Silver X32.
I'm trying something a little different to achieve a more natural metal finish. So my plan is to use Medium graphite finely ground.
After rubbing the graphite I did apply a coat of Future to protect and prevent any finger print to ruin my model.
I also airbrushed the anti-glare olive drab, in this case I used 8:XF62+2:XF49 and also mask the areas to paint the wings with the Aluminium Lacquer
The original formula for the aluminium lacquer was a mix of lacquer (or resin) and aluminium powder, so I mixed 1:H8 Gunze Silver + 1:XF53 Tamiya Neutral Grey
When I started to place the decals I've noticed that the checkered wing tips decals didn't have the white so I needed to paint it. The mummy is do I've used Plumber Teflon tape to mask the model before airbrushing Tamiya XF-2 White with a few drops of Future.
All decals in place and a coat of Future applied overall.
These Eagle Cals decals are the best decals I've ever used very easy to use and react good to Micro Sol/Set.
Airfix provides a lot of stencils with their decal sheet and that's was the most tedious part, but it's worth the effort.
After a final coat of Future and letting it to dry for 2 days, I have started the weathering process.
If you have seen my previous models you've seen that I like then worn out and (ab)used, so that's what I got so far:
Starboard wing showing all grease and smudge especially on the gun panels
The kit have the holes for the identification lights under the port wing, but no clear part is provided.
So I decided to fix it. First I've painted the base with X32 Titanium Silver
Next I use marker pens to paint the lights (Red, Green and Amber)
 I then made small discs of clear plastic using a punch and die set. I glued them using future (aka Pledge).
And here is the final result.
Another improvement is the hydraulic line for the landing gear breaks. I've used sewing tread stiffened with PVA glue (white glue), and also glued in place with PVA glue.
An interesting detail is the flap indicator painted on the port side flap, it was used for pilot's quick reference.
To be continued.....
Tags: Airfix 1/72
Paulo Castro
SAPMA - Adelaide SA
    June 2014
Posted by BrandonK on Tuesday, November 10, 2015 9:21 AM
I agree, the Doll is a beautiful -51D. I did her in the 1/48 Revell and painted all the decals, and that was a huge pain. You have done really nice work here and on a small scale. Looking forward to the reveal.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    August 2015
Posted by Cat Daddy on Tuesday, November 10, 2015 11:36 AM
Wow. Beautiful work. Thank you for this. I have the Revell 1:48 version and when I get to it, I'll be referring to this for inspiration and assistance.
    July 2014
Posted by modelcrazy on Tuesday, November 10, 2015 11:51 AM
Great job! I had to go back to the introduction to double check the kit was 1/72. I would have sworn you were working on a 1/48.
Steve
Steve
    November 2015
Posted by ArmouredSprue on Tuesday, November 10, 2015 3:48 PM
Thanks all for your comments!
I have finished this build today, I'll take the photos this evening!
Cheers mates
Paulo
Paulo Castro
SAPMA - Adelaide SA
Posted by 7474 on Tuesday, November 10, 2015 10:09 PM
Looking good, can't wait to see it finished.
    March 2015
Posted by Toshi on Wednesday, November 11, 2015 6:40 AM
Very nicely done!  The post shading looks excellent especially with the graphite.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    May 2006
Posted by Shipwreck on Wednesday, November 11, 2015 7:13 AM
Paulo that is excellent work on both the model and the presentation. You have photos that I have never seen before. One suggestion I would like to make is for you to look at the period fuselage panel lines and compare the to your model. Is this what you want?
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    November 2015
Posted by ArmouredSprue on Wednesday, November 11, 2015 3:38 PM
Shipwreck
Hi mate
I haven't done any post shading in this model, the panel lines are more definided because this kits (as most of the Airfix ones) has a huge gap between the panel lines, so for this matter I'm happy with I have achieved.
Thanks for you comment!
Cheers
Paulo Castro
SAPMA - Adelaide SA
    November 2015
Posted by ArmouredSprue on Wednesday, November 11, 2015 3:41 PM
Here are the finished model photos, hope you like and I'm glad to hear your comments and critics.
Kit: Airfix A01004 1/72, Decal by Eagle Cal
For work in progress of this kit, click here
Paulo Castro
SAPMA - Adelaide SA
Posted by Gamera on Wednesday, November 11, 2015 4:04 PM
Wow, she turned out beautiful!!! I tried puttying the wing panel lines like that a few years ago but didn't really like the results, I wish mine had turned out as well as yours. Yes
    February 2012
Posted by lawdog114 on Wednesday, November 11, 2015 7:14 PM
Hard to believe thats 1/72nd scale. That is stunning. Thanks for sharing your work with us.
    June 2003
Posted by allan on Wednesday, November 11, 2015 7:30 PM
Stunning! Very beautifully done.
No bucks, no Buck Rogers
    October 2013
Posted by infofrog on Wednesday, November 11, 2015 7:49 PM
What q beautiful build
geat job
rick
    January 2015
Posted by M. Brindos on Wednesday, November 11, 2015 8:35 PM
When I can't tell that it's not 1/72, I know I'm looking at a VERY well done build.
VERY well done!!  :D
- Mike Brindos "Lost Boy"
    November 2015
Posted by ArmouredSprue on Thursday, November 12, 2015 1:18 AM
Thanks all for your comments. This kit was a pleasure to build and I'm a big fan of Airfix new tooling releases. This model for example, is head to head with the Tamiya, but is way cheaper and comes with the option to make drop or normal flaps, this only is a game changer. Fit and details are very good. The only thing I would pick on is the large panel lines, if they were a little less wide and deep would be perfect.
Cheers
Paulo
Paulo Castro
SAPMA - Adelaide SA
    June 2014
Posted by BrandonK on Thursday, November 12, 2015 9:11 AM
Stunning, yes !! Very nice work and the weathering is fantastic. Great work.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    November 2015
Posted by ArmouredSprue on Thursday, November 12, 2015 3:02 PM
BrandonK
BK
Thanks mate
Paulo Castro
SAPMA - Adelaide SA
    November 2008
Posted by plasticjunkie on Friday, November 13, 2015 10:27 AM
Stunning work indeed, specially in a smaller scale. The puttied wings on NMF Mustangs are often overlooked by modellers. Well done sir. Beer
 GIFMaker.org_jy_Ayj_O
    November 2015
Posted by ArmouredSprue on Friday, November 13, 2015 2:34 PM
Thanks!
Paulo Castro
SAPMA - Adelaide SA
    April 2005
Posted by wing_nut on Friday, November 13, 2015 2:46 PM
Stunning. I had no idea it was 1/72 scale until i saw it in a post.
Marc
    September 2012
Posted by GMorrison on Friday, November 13, 2015 2:57 PM
Bow Down
    October 2015
Posted by aks_801 on Friday, November 13, 2015 3:12 PM
Very inspiring build, well done!
alan in Houston, TX
Been dazed and confused for so long it's not true.
    November 2015
Posted by ArmouredSprue on Sunday, November 15, 2015 5:28 PM
Cheers mates!
Much appreciated
Paulo Castro
SAPMA - Adelaide SA
