1/72 Academy P-40E - COMPLETE
    March 2012
Posted by mustang1989 on Tuesday, July 26, 2016 7:24 AM
Hey Mike.  I hate to hear about the paint blues brother. For future reference brake fluid on a moistened rag will get all the paint out and cleans up with water. Love the build and the progress man. Take care, Joe
 Forum | Modelers Social Club Forum (proboards.com)
    January 2015
Posted by M. Brindos on Tuesday, July 26, 2016 8:50 AM
Seriously?! Does it just wipe off, or do you have to soak it for a while first? This could have saved me a lot of time lol. Although my scibing is turning out quite well....  dangit.
- Mike Brindos "Lost Boy"
    March 2012
Posted by mustang1989 on Tuesday, July 26, 2016 10:36 AM
It takes a little rubbing but yes , especially if it's acrylic-it wipes off ...or it has for me.
    January 2015
Posted by M. Brindos on Tuesday, July 26, 2016 5:22 PM
Noted for later use.
That would've definitely helped out here. After a primer spray last night however, I can say that my rescribing adventure is working out quite well. Besides, I think I need the practice. I've got a couple of Monovell kits that I plan on adding some scribing to and I'm not fully confident in my abilities yet. The Stuka doesn't look bad, but I got a little too heavy handed with a couple of those panel lines and it shows.
So this build is up next for completion in my que. I just hope I can tame those overly thick Academy decals as well as I did on the SPaD.  ...without repainting them lol.
    March 2012
Posted by mustang1989 on Tuesday, July 26, 2016 6:07 PM
I'm sure you'll do great with the cals Mike. Yes
    January 2015
Posted by M. Brindos on Thursday, July 28, 2016 1:43 PM
Thanks, Mustang. At the moment they are the furthest from my mind. I really wish I had started with the brake fluid paint removal. This build is getting a little messy with the rescibing and sanding proceedures. Plus its been around 85+ degrees around here which makes some of the paints I use stay a bit tacky. This hasn't been fun and I wish I had an "Undo" feature with this build.
Right now I'm on the edge of just trashing this one and moving on to another. I'm still on the side of the fence for continuing, but its close. Things at least are starting to look a little better with this one.
Checking and rechecking. Sanding, and sanding a little more. This build has gotten UGLY.
I'm still thinking I can get her back into shape, but I've made a lot of errors and correcting them is painstaking work.  :P
    January 2015
Posted by M. Brindos on Friday, July 29, 2016 1:08 AM
    March 2012
Posted by mustang1989 on Friday, July 29, 2016 10:08 AM
Dude that's lookin' really good Mike!
    January 2015
Posted by M. Brindos on Friday, July 29, 2016 10:55 AM
Thanks, Mustang! The Sky Grey and the Flat Earth were masked and air brushed, but the rest of it so far has been hand painting. Its rolling along pretty good now.
This mornings progress has been applied to the prop and spinner. Again, this was done by hand, and a steady hand it has taken lol.
All Vallejo so far. Black, White, Sky Blue, and Yellow with a touch of Hull Red to give it the darkish tone it should have.
Of course there will be some touch-ups along the way, but so far, so good.
I'm finally past the point where I was before. The deja vu feeling has passed lol.
    March 2015
Posted by Toshi on Friday, July 29, 2016 11:03 AM
Wow, what a steady hand!!!!!  I've never seen this done before.  I thought spinners were done by masking.  What great technique!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    January 2015
Posted by M. Brindos on Friday, July 29, 2016 11:10 AM
Normally it would be easier to use a mask, but I had trouble with the spinner masking on the Stuka and just decided to fall back on my classic skill set lol.
You have no idea how many times I had to correct that line lol. Fortunately there is a demarkation line running around the spinner so all I had to do was carefully follow the line.
The nerve wracking part was then painting the prop blades black without getting it on the spinner  :/  I should have done the black first.
    January 2015
Posted by M. Brindos on Sunday, July 31, 2016 12:42 AM
Decals are now on. They've given me a little trouble, but not much. They seem to go on just fine with a little persuasion lol.
I'm saving the stencils for later since at least one of them has to go over one of the national insignias.
    March 2015
Posted by Toshi on Sunday, July 31, 2016 5:57 AM
Looks fantastic!  Can't wait to see the final reveal.
Toshi
    January 2015
Posted by M. Brindos on Sunday, July 31, 2016 3:52 PM
Sorry, Toshi. You'll have to wait a good while before that happens. I'm putting this one away before I bin it for good. I need to remove all of the paint and start over again. The layers and build-up of paint is just too much and is causing problems all over the place.
I'm so frustrated that I'm putting the brakes on this. I'll wait till I have the patience to redo all of this. Glad I didn't put the stencils on it yet. I still have two more paint schemes I can go with later.
So this one is getting put away. I've had enough.
    January 2015
Posted by M. Brindos on Wednesday, October 5, 2016 8:37 PM
Well you've waited long enough I suppose. Aside from a few very small details to tidy up later, such as an antenna wire, this one is pretty much finished. I had some troubles removing the masking tape as it had been sealed under a LOT of layers of paint. That made things difficult around the clear pieces. All except for the windscreen which I just added last and hand painted the frames in.
I found a roundabout way to get the link info. So here it goes lol.
I started by repairing the base paint scheme. All of that paint settled down after sitting for so long. So I figured I get on with it today. I decided to weather it heavily as I was watching some documentaries about the RAAF and these planes fought from the dirt and got roughed up pretty well. So that's what I went for.
It looks a lot better in the collection now that its not derelict anymore.
I'll fix an antennae wire and gloss the wing lights later. For today, I'm spent lol.
Thanks for looking! Have a great night.  :)
    August 2016
Posted by WannabeFarmboy on Wednesday, October 5, 2016 10:53 PM
Amazing work! I haven't seen many 1/72 scale kits with this much detail. Looks great!
Posted by Bish on Thursday, October 6, 2016 12:42 AM
Nice looking build Mike, nicley finished.
WannabeFarmboy
Then you have not been looking very hard Wink
    June 2014
Posted by BrandonK on Thursday, October 6, 2016 9:43 AM
Nicely done, Sir. Very nice indeed. Too small for my eyes and shaky hands, but you rocked this one.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    April 2016
Posted by Hodakamax on Thursday, October 6, 2016 10:11 AM
Lookin' good Mike. You never fail to amaze me particularly on those teeny ones!
Max
    January 2015
Posted by M. Brindos on Thursday, October 6, 2016 10:12 AM
Bish
WannabeFarmboy
LOL, indeed! LOL
I did put a lot of detail into the cockpit, but the rest of it is just kit parts. Mustang's build makes this one look like second rate crud, lol.
Farmboy, Brandon, thanks guys! After I gave up on this one months ago I didn't think I would ever find the will to finish it. It was just ruined in my eyes. Too many mistakes layered over each other with the paint job.
Yesterday morning I finally just figured, "what the heck. It can't get any worse."
So I just started where I left off. After some internal debate on wether or not to just slapit together, or actually put a little effort into it I decided to just go for it and weather it as I knew it should be. The underside is still too clean for the constant dirt runways these craft flew from, but I'm not woried about it.
Maybe I'll fix that later, or maybe I won't.
Lessons have definitely been learned with this one. For instance, when I was weathering the paint I use what I thought was white oil paint. It didn't want to spread out and blend correctly and it was confusing. Turns out it was White Watercolor Paint. Once I figured that out I was able to blend it with a damp paintbrush and all was well. In fact it worked in a way I didn't expect. Much like a wash. Something I will remember for another build at another time for sure.  :)
So its now sitting next to my Hellcat with a giant, looming Stuka sitting menacingly beside it lol.
Thanks for the kudos fellas. This may not be my best work, but it at least turned out worth showing lol.
    November 2003
Posted by tempestjohnny on Thursday, October 6, 2016 12:06 PM
Nice fix Mike. Looks good in the collection
    March 2015
Posted by Toshi on Thursday, October 6, 2016 8:38 PM
Even with the issues you pointed out, this build came out great!
Toshi
    January 2015
Posted by M. Brindos on Thursday, October 6, 2016 9:32 PM
Thanks, Max. I don't know how much longer my eyes will hold out, or my nerves will hold, but I'm going to use it while I still have it lol. I've always been fascinated by things in minature lol.
Thank you , Johnny. The collection is looking good. I even dusted off a couple of favorites (with minor repairs lol) to add to the old stereo cabinette I'm using for a display.
Toshi, my friend, good to hear from you. :)  I trust all is going well with the move?
    March 2015
Posted by Toshi on Friday, October 7, 2016 8:21 AM
So far everything is going accordingly.  Thank you for asking.  I love your collection.  It's very inspirational.
Toshi
    March 2012
Posted by mustang1989 on Friday, October 7, 2016 10:47 AM
Good lookin' P-40 Mike! Yes
Posted by Gamera on Friday, October 7, 2016 11:27 AM
After all that frustration the end results don't look too shabby! Nice job! Yes
    February 2012
Posted by lawdog114 on Saturday, October 8, 2016 3:31 AM
It turned out great Mike, definitely better than before. You should be proud of it.
    January 2015
Posted by M. Brindos on Saturday, October 8, 2016 9:42 AM
Thank you. Its definitely growing on me, from a distance lol. It turned out okay in the end and I thought it was close to going in the trash a few months ago.
    June 2003
Posted by allan on Thursday, October 13, 2016 1:09 AM
Very nice work on the P-40, Mike. She's sexy!
No bucks, no Buck Rogers
    January 2015
Posted by M. Brindos on Thursday, October 13, 2016 1:13 AM
Thank you Allan! :)
