Guillows TBF Avenger
    April 2016
Posted by Donanton on Wednesday, April 20, 2016 12:47 PM
Figured I'd post my progress on my Avenger.
    April 2016
Posted by Donanton on Wednesday, April 20, 2016 1:12 PM
http://imgur.com/4yIgz3r
http://imgur.com/u1baTeM
Yes, there's ribs missing, I'll install and cut them next.
I cant make the top 2 images show themselves.  I'm using imgur and their BBcode for forums on all 4 pics.
    July 2014
Posted by modelcrazy on Wednesday, April 20, 2016 1:35 PM
What are you going to use for covering material Are you planning on flying it? If so, rubber band free flight of installing micro servos?
Steve
    March 2015
Posted by Toshi on Wednesday, April 20, 2016 3:09 PM
Very nice start, you have my full attention.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    April 2016
Posted by Donanton on Wednesday, April 20, 2016 3:27 PM
I might just skin it.  I'm planning on making some larger versions RC and out of foam board once this one is done.  Theyll be cheap to fix and lightweight.
fox
    January 2007
Posted by fox on Wednesday, April 20, 2016 7:29 PM
Haven't built one of their kits in a few years. Lots of fun. Still have 1/2 doz. in the closet. Built a couple of Peanut scale ones a while back for the grandkids. They lasted about 15 minutes out at the ballfield.
Jim  Captain
 Main WIP:
    January 2003
Posted by Darren Roberts on Wednesday, April 20, 2016 9:07 PM
Ahh, such good memories of those. I might just have to break one out for the heck of it.
    June 2003
Posted by allan on Wednesday, April 20, 2016 9:31 PM
What scale is this?
No bucks, no Buck Rogers
    April 2016
Posted by Donanton on Thursday, April 21, 2016 10:09 AM
Guillows says its "approximately" 1/30. They give a scale but everything from a zero to a fw190 to a tbf has the same wingspan of 1/30.
    February 2007
Posted by Buckeye on Thursday, April 21, 2016 11:23 AM
Very cool,  haven't build one of these since high school.
    April 2016
Posted by Donanton on Thursday, April 21, 2016 12:27 PM
The newer laser cut ones are world easier than the die cut old ones.  I've got a fw190 I'm dreading as its die cut because of the rib slots which often breakaway part of the rib if not done perfectly.
Great kits though.
    April 2016
Posted by Donanton on Friday, April 22, 2016 7:32 AM
Got some small rib work done.
    March 2015
Posted by Toshi on Friday, April 22, 2016 7:45 AM
Wow!  Such intricate detail.  You're the man!
Toshi
    April 2016
Posted by Donanton on Friday, April 22, 2016 8:23 AM
Being as I don't follow directions, I had to (or have a small saw) I had to sand these pieces apart then install the pieces.
Posted by Don Stauffer on Friday, April 22, 2016 9:16 AM
Looking great!  Sometimes for formers and such from the sheet stock, I trace the part on 020 styrene, cut it out, and then laminate the plastic piece to the balsa.  Saves filling and a lot of sanding if the piece will be visible and painted.
    July 2014
Posted by modelcrazy on Friday, April 22, 2016 9:28 AM
Yes, coming along nicely. While I haven't done it in a while, I use to scratch build my wood models. Consequently I have multiple plans from the past manufacturers as well and not so past designers in FF and RC.
If anyone is interested in a certain AC I can check my inventory to see what I have on my files. They would need to be printed out but the plans are free.
Steve
    June 2014
Posted by Tanker - Builder on Friday, April 22, 2016 9:29 AM
Ah ;
     Those were some models back then .Hey ! where'd you get those neat looking pins ?      Tanker - Builder
    April 2016
Posted by Donanton on Friday, April 22, 2016 1:16 PM
They're insect pins.  Sometimes used for bird taxidermy.
    April 2016
Posted by Donanton on Monday, April 25, 2016 11:55 AM
Ive got an update with way too much light!
The wing is not glued in, it's just there for placement and fitting.
Posted by Gamera on Monday, April 25, 2016 1:49 PM
Gosh, I haven't built a stick and tissue model in years. Lookin' good, there's just something about these that a plastic model can't match!
    August 2013
Posted by Jay Jay on Tuesday, April 26, 2016 8:04 AM
I did my only stick and tissue model as  kid. The stick part came out very well. I must have used too much water on the tissue part as i remember because after it dried, it twisted the wings so bad I just threw it away.
Ty for posting your W.I.P . you're inspiring me give it another go.
Posted by Don Stauffer on Tuesday, April 26, 2016 8:26 AM
Jay Jay
I did both stick and tissue, and the non-flying balsa scale models carved from solid wood blocks.  That was all there was, no plastic kits till I was about 9 or 10.  I hear they were earlier in GB.
Sometimes pinning the wing or tail surface to a firm plank of wood helped prevent warps.  You had to pin it through small blocks to raise the bottom surface off the plank to let it dry without sticking to plank. If blocks were all same height, it did hold the model part flat.
There has been a resurgence of balsa flying models, with laser cutting services.  Small cottage industries can get into business easier, with less investment- sort of like resin casting with plastic models.  Search out a good, larger hobby shop, or look up the web site for Penn Valley Hobbies, who carries many of these small mfgs.
    August 2015
Posted by crown r n7 on Tuesday, April 26, 2016 10:40 AM
So far so good.what are you going to cover the ribs with tissue or monokote ?
 Nick.
    April 2016
Posted by Donanton on Monday, June 13, 2016 11:32 AM
HAHA!  I'm not done yet!
Copioius crooked ribs!
I'm gonna leave this a naked skeleton.
    March 2015
Posted by Toshi on Monday, June 13, 2016 11:37 AM
That will look like an excellent build.  So far so good, you got me excited on the TBF!
Toshi
    April 2016
Posted by Donanton on Monday, June 13, 2016 12:17 PM
Thanks Toshi.
After seeing how easy this laser cut tbf was to build, I'm kind of dreading the die stamped fw190 I have "waiting in the wings."
    April 2016
Posted by Donanton on Friday, June 17, 2016 8:06 AM
Now we have 2 wings.  Eventually I'll even post a front view.
