Well, this would be the worst kit I have ever built I think. Typical Kinetic instructions that are vague and leave you guessing where parts go or wrong call outs.
The decals are supposed to be Cartograf, but are the worst decals I have ever used, even using my normal method of spraying down Klear before applying them, and using Micro sol, the walkways and tail insignia wrinkled so bad and did not set, Ihad to sand back some areas and paint over. Some other decals did not even set at all and came off when I was wiping back the wash.
I only persevered with the build because I had put so much time into it and the kit is not exactly cheap, otherwise I would have binned it.
I used Tamiya, Gunze, Italeri and Vallejo acrylics, Gunze Lacquer and Metalizer, Flory dark dirt wash and Vallejo matte varnish
Not at all happy with the final result, but like I said, I finished it off because of the time I had put in to it
