What's the best material for aircraft antenna?
    June 2016
Posted by TxAggie05 on Monday, June 6, 2016 10:01 PM
Howdy all!
I'm building a 109g6 in 1/48th scale. Im wondering what's the best material to use for aircraft antenna. I've heard to stay away from cotton thread.  I've seen some plastic filament that is made taught when a soldering iron is run under it. Is this fishing wire?  If so, what size Diameter?  I've heard of EZ wire. Is this good?  What's the best bang for your buck?
Thanks in advance!
    June 2016
Posted by David from PA on Tuesday, June 7, 2016 2:27 PM
I always use Maxima .012mm (2lb test) monofillament. Mine is "chameleon" but I think it comes in different colors. I use a flat wood toothpick sanded to proper shape for the masts.
Dave in PA
David From PA
    January 2006
Posted by DiscoStu on Tuesday, June 7, 2016 10:02 PM
I just started using EZ-Line and I love it.  Very forgiving with a ton of flex
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
    September 2003
Posted by checkmateking02 on Tuesday, June 7, 2016 10:15 PM
Stretched sprue also works well--and it's cheap.
    September 2012
Posted by GMorrison on Tuesday, June 7, 2016 10:21 PM
EZ Line, (mike drop).
But seriously, I bought a spool for less that $ 5 and I'll never run out.
    March 2015
Posted by Toshi on Wednesday, June 8, 2016 12:37 AM
EZ-Line.  They make several sizes.  Just tell them what scale you need it for as in 1:24, 1:32, 1:48, and or 1:72.  The rail road enthusiasts use EZ Line for their telephone pole lines.  Stretches up to 700x's it's actual length, as so advertised.  Instant adhesion with CA.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by Bish on Wednesday, June 8, 2016 1:08 AM
EZ line is really useful, though i have found with slim antenna's, it can bend them slightly. I either use that or fine fishing line.
    September 2011
Posted by falconmod on Wednesday, June 8, 2016 7:13 AM
Where can you get it?
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    July 2014
Posted by modelcrazy on Wednesday, June 8, 2016 7:18 AM
EZ line and fly tying line.
Steve
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, June 8, 2016 8:34 AM
Fishing line is another cheap alternative.
You can buy EZ line here:
http://berkshirejunction.com/ez-line/
Other places you can find are : eBay, Amazon.
Posted by Don Stauffer on Wednesday, June 8, 2016 9:21 AM
I like monofilament thread- no fuzz.  While you can get monofilament thread from sewing and craft places, fly tieing supply places sell a thinner thread than what I can get at the craft stores.  The diameter needed depends, of course on scale.  But for 1:72 you really need to get the really small stuff, 5 or 10 mil.
    May 2016
Posted by wildcat13 on Wednesday, June 8, 2016 10:38 AM
I use EZ wire and love it. It stretches to fit. Give it a try. $14 for 100ft roll but well worth it.
    January 2009
Posted by fermis on Wednesday, June 8, 2016 10:52 AM
checkmateking02
With Stupid
All I've ever used...so I can't comment on the other options.
fox
    January 2007
Posted by fox on Wednesday, June 8, 2016 8:23 PM
E-Z Line is all I use. Had a couple of antennas broken when someone pushed on the thread line at shows. Switched to E-Z Line and no more broken antennas or disconnected wires.
Jim  Captain
 Main WIP:
    February 2012
Posted by lawdog114 on Wednesday, June 8, 2016 10:24 PM
I use smoke colored invisible thread for aerial lines. Its okay but does come undone with the slightest nudge. I am intrigued by the EZ line. I may try it. Which one recommended for 1/48 aircraft?
    August 2009
Posted by JOE RIX on Wednesday, June 8, 2016 11:49 PM
I've used E-Z Line for while now and sure love the stuff. Then recently I found Uschi Rigging Line and bought some. Very much like E-Z but, it comes in even smaller size which is more in scale for 1/72. I have yet to use it but, it will be on my very next kit. Appears to be dynamite line.
Here's the homepage:
http://www.uschivdr.com/products-in-detail/rigging/
Joe: I believe that the fine E-Z line would be suitable for 1/48. It's a tad bit large for 1/72 in my opinion. The medium size might also work.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    February 2012
Posted by lawdog114 on Thursday, June 9, 2016 3:29 AM
JOE RIX
Thanks Joe...I'll check it out
Posted by Don Stauffer on Thursday, June 9, 2016 9:09 AM
lawdog114
I use that stuff- the smokey monofilament- a lot.  PITB to tie knots in it, but you can do it.  At mast end, I tie a knot around the mast and secure with CA.  On tail end, I drill a little hole in vertical stab and glue the end of the line in the hole.  The miniscule cross section surface area dooms butt joints, they do break off too easily.
    January 2006
Posted by Wirraway on Friday, June 10, 2016 9:25 PM
I have been using horsehair lately, with good results. Free too, if there are any gee-gees in the vicinity. Manes always get caught in barbed wire, just pick it off. Comes in Shades from Black through to Tan, you can tie knots in it, and it will stretch a lot before breaking.
"Growing old is inevitable; growing up is optional"
" A hobby should pass the time - not fill it"  -Norman Bates
GIF animations generator gifup.com
Posted by Don Stauffer on Saturday, June 11, 2016 9:19 AM
One thing to do is to use a little arithmetic.  A typical antenna wire may be in the range of 50 to 100 mil (0.050 to 0.100).  Now, simply divide by the scale, to find out what would be the scale diameter.  We find in  1:72 that antennas would be less than a mil- hard to find, while even 1:48 would be a mil to two mil.
Hard to find thread or wire in scale thickness.  Next step is to reduce visual contrast.  Avoid pure white, silver, or black colors, which are high visibility, and use a medium gray or brown color.  Same thing on ship rigging- avoid pure black or white.  Tan is okay, but use a very dark gray rather than black unless it is a large scale ship.
