Weekend Build Complete - 1/48 Tamiya RAF Mustang III
    January 2015
Posted by BrandonD on Monday, November 7, 2016 12:43 PM
I have been in a bit of a rut lately, and haven't finished a model since July, for a number of reasons, so when I saw that Lewbud ishosting a weekend group build, I really wanted to give it a go, and took the plunge this past weekend.
I picked up the kit - Tamiya's 1/48 RAF Mustang III - for $16 on sale at one of the local hobby shops, and having built the P-51B before, I knew the fit and whatnot would be good to give it a go on the weekend.
Also, the plane I chose to build didn't show too much wear and tear, which means less work overall.
I took this shot on Thursday, and planned to start the build on Friday.
I realized that completing something in a weekend - my normal rate is about one a month - would be a challenge, so I made a list of everything I needed to do, and set benchmarks for when they needed tobe completed to keep on schedule.
The plan was to skip out of work a bit early on Friday and get started by 4:30, and have the plane primered by bedtime, with some seam work probably left to do Saturday morning.
I got started right at 4 p.m.
Step one was to shoot Mr. Surfacer 1500 Black primer on most of the interior surfaces. As soon as I was done, I quick-cleaned the airbrush and shot Testors Yellow Zinc Chromate on the wheel wells, then Mr. Paint Duraluminum on the bare metal parts (flap innards, geat legs, gear doors, etc.), and then Model Master Interior Green on the cockpit tub.
It assembled quickly, and I had to be a little careful because the paint was just mostly dr to the touch.
The belts are Eduard, and I was fresh out of my stash of pre-painted harness, so I used an older set of plain ones and just painted them quickly (closed canopy, so not too visible, but just visible enough that if I didn't include them, it would feel like a glaring omission).
I gave all parts a quick wash with Flory Dark Dirt, then assembled the airframe.
As you can see, that was done by 7:05 p.m. To give the glue some time to set up, I grabbed dinner and went to work masking the canopy.
It needed some help holding together in front of the canopy, so I gave it a clamp.
I laid down some super glue to fill the seam, then sanded it and primered.
I had that done by 10:30 p.m., and noticed there was still a seam. I ran a thin line of Mr. Dissolved Putty along it, then sanded it once it was dry, getting rid of the seam for good.
Tamiya's color call-out does not show any stripes on the wings of the No. 315 (Polish) squadron commander's bird, but reference photos I have showed them, so I went ahead and shot the white stripes, nose band and prop spinner before bed.
And that was the end of day one.
When I woke up on Saturday, I took the dog outback and let her run around while I masked the white bits, then I sprayed the fuselage band Sky.
I went for a run while that dried, then came back and masked it.
ANd this is where I got rushed for time.
Saturday was my dad's birthday, and I was planning to leave to head to my parents' house at 3 p.m. As you can see, I had the thing ready for paint by 12:10, which doesn't leave a ton of time for a three-color scheme, but I was feeling confident.
Medium Sea Gray went down easily on the underside, and I went and grabbed a coffee while the paint was drying so I could mask it.
When I got back, I masked with Tamiya tape de-tacked by sticking itto my forearm before applying to paint I normally would wait longer to let dry.
Then I started shooting the Ocean Gray, and I ran into a problem - my airbrush clogged, and no amount of work could get it un-clogged. Of all the times for this to happen!
But no, it wasn't clogged. I'd just forgotten to turn the air compressor on, and with a 3 gal. tank, you can actually spray quite a while before you realize that!
So I finished the Ocean Gray and switchted to RAF Dark Green (all these colors are Tamiya acrylics, by the way). I freehanded the green for the camouflage scheme and took itinside to remove the masks.
Et voila. My benchmark for Day Two was to have decals on before I went to bed, so I needed to clear it before I left for my parents' house.
Right after this pic was taken, I went back into the garage and shot the X-22 Clear coat, then misted it with thinner for a glassy surface for the decals, then hurried off to see my dad.
I got home just before midnight and set to work on the decals, finishing them up just before 2 a.m.
I did't want to kick on the compressor to lay down another gloss coat, but there was enough pressure left in the tank to spray over the decals, which was all I really needed to do.
I generally don't care for Tamiya's decals, but these ones were Scale Master or whatever Tamiya used sometimes in the kits from this era. They went down pretty well for the most part. I did cut some corners I normally wouldn't have. For example, the roundels on the upper wing surface didn't want to snug down over the detail, so instead of applying repeated coats of Micro Sol, I applied one, waited until the decals wrinkled up, then used a moistened paper towel to carefully smooth them out and press them down. Fortunately this didn't cause any problems.
Unfortunately, I'd planned to use the yellow leading edge decals, but they disintegrated when I put them on the plane, so I knew I'd have to mask and shoot them in the morning.
That was the end of Day Two.
For Day Three, I had until 3 p.m. to finish (becuase of the time change). But I knew I had to pick up my girlfriend at some point between 12 and 2, so I had to work fast.
I masked and sprayed the wing leading edges with Model Master Insignia Yellow, super-glued the main gear legs, added the doors and really felt like I was cruising.
And at 10:50 the girlfriend texted me and said she was ahead of schedule and could I leave to pick her up right away.
NOOOOOO!
But I said yeah, and then rushed to the finish, painting the gun barrels, formation and nav lights and gluing the gun camera lens in place while everything was decidedly wet. I took a couple pics just in case, but managed to come home to rotate my laundry, hang the bombs and shoot completion pics a bit later.
I actually forgot to take the last bit of canopy mask off before I did this, and you can see it at the top of the windscreen. I pulled it off right after, but didn't have time to take more photos before I rushed out the door.
ANd here are some pics of the actual aircraft. It was lost in 1944 along with the pilot, Eugeniusz Horbaczewski, after a dogfight with some Fw-190s in which he downed three.
Note that Tamiya doesn't have the white stripes on the wings in the color call-out, and also instructs you to use the shrouded exhaust, but these pics show theexhaust without shrouds.
Anyway, I barely finished thisone in the time I had, but it was honestly the most fun I've had modeling in a long time. The challenge was a blast, and I highly recommend you all go join the group build. I can't wait to see what everyone else builds in it, and I hope to see your builds, too.
Thanks for reading this long post, or even just looking at the pics Wink
-BD-
    July 2004
Posted by stikpusher on Monday, November 7, 2016 3:07 PM
YesYes
outstanding work in 48 hours! Your pre planning paid off handsomely!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2006
Posted by jgeratic on Monday, November 7, 2016 4:16 PM
Splendid job! Yes
regards,
Jack
    January 2015
Posted by Aggieman on Monday, November 7, 2016 4:31 PM
Stellar work in such a quick time and with that big deadline you faced.
    November 2003
Posted by tempestjohnny on Monday, November 7, 2016 7:52 PM
BD that is too cool. Came out great.
    March 2015
Posted by Toshi on Monday, November 7, 2016 8:10 PM
Very inspiring especially in such a record time!  Amazing!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    November 2003
Posted by mississippivol on Monday, November 7, 2016 9:50 PM
Wow!
    January 2015
Posted by TheMongoose on Monday, November 7, 2016 10:44 PM
I enjoyed the reality of it all. Probably everything you go through in a month only compressed like an episode of 24 into one weekend. The plane looks great, you've definitely got skills!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    June 2014
Posted by BrandonK on Monday, November 7, 2016 10:50 PM
You really kicked that out in a hurry. Beautiful job. It looks stunning.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    May 2006
Posted by Shipwreck on Tuesday, November 8, 2016 6:49 AM
Marathon Man, that is one nice Mustang. It would take me three months to build that kit! So, thanks for the encouragement. It is possible!
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    July 2016
Posted by Johnny1000 on Tuesday, November 8, 2016 9:45 AM
Congrats! That looks really good regardless of the lightening turnaround. Well done.
-J
    April 2016
Posted by Hodakamax on Tuesday, November 8, 2016 9:57 AM
Fun post Brandon! Good coverage, photography and build! Great job!
Max
    May 2013
Posted by Greg on Tuesday, November 8, 2016 10:42 AM
Ditto to all the above, and I agree with Max, this IS a fun post.
I've wondered how anyone does something like this in so short a time. Your timeline adds a sense of reality to a 2 day build. And you did a really nice job, too.
I'm still amazed, though......
Posted by jeaton01 on Tuesday, November 8, 2016 9:57 PM
Gonna do it again next weekend? Big Smile  Nice model!
John
    February 2007
Posted by Buckeye on Wednesday, November 9, 2016 11:33 AM
That came out great, especially for a marathon build! Well done!
Posted by Gamera on Wednesday, November 9, 2016 11:42 AM
Yeah, that's a sharp job- even more so considering the time constraints. Takes me more like 48 weeks to get anything finished...
    January 2009
Posted by fermis on Wednesday, November 9, 2016 12:12 PM
Very nice "power build"!
    October 2005
Posted by antoni on Thursday, November 10, 2016 4:10 AM
BrandonD
Horbaczewski flew three mustangs in succession, FB166, FB382, FB387, all coded PK*G. They are often confused with each other. FB382 had exhaust shrouds, FB387 did not. Tamiya have also repeated a number of error with the markings, check the orientation of the chessboards in the photograph. The chessboards and squadron badge were on both sides of the fuselage. The colour of the bombs was yellow not white. There would a black letter 'G' under the chin. The yellow leading edge stripes ran the entire wing span from root to tip.
BrandonD
No it was not. This is nonsense made up by people that assume everything and never check anything. On 18th August 1944 Horbaczewski was lost with FB355 PK*K, FB387 was not available. FB387 was built as a P-51C with USAAF serial 42-103537. After delivery is spent some time in storage until allocated to 315 Squadron at Brenzett at the end of July 1944. Horbaczewski chose it as his personal aircraft to replace FB382. After Horbaczweski failed to return on 18th August, FB387 continued to be used by the squadron until late October when it was transferred, with other Mustangs, to 316 Squadron. It did not last long there. On the night of 9th November F/Lt Janusz Walawski hit a lorry while taxiing at Andrews Field. It was sent for repair but recategorised as damaged beyond repair and SOC.
    January 2015
Posted by BrandonD on Thursday, November 10, 2016 11:32 AM
Thanks everyone for the kind words. It was a lot of fun building it so fast.
Antoni - thanks for the clarification. I'm sorry that I fell into the trap of misinformation. Thanks for the clarifications. I have an extra chessboard, so will go back and add that to the other side of the fuselage. May extend the yellow as well. I see what you mean about the orientation of the chessboards. That's really annoying. I wish I'd caught that and just cut the decal to rotate it 90 degrees.
Jeaton01 - Definitely not doing another one this weekend haha. If I do anther weekend build, it will likely be 1/72 or a V-1 with no cockpit to deal with.
-BD-
    June 2008
Posted by lewbud on Friday, November 11, 2016 11:30 PM
BrandonD, once again great job.  Gentlemen, if you're up to the challenge, the sign up sheet is in the Group Builds forum.  We'd love to have you.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    December 2010
Posted by 1943Mike on Saturday, November 12, 2016 12:30 AM
I think it's a great job - quick build or not.
(Never say no to a girlfriend you'd like to keep Wink)
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
fox
    January 2007
Posted by fox on Saturday, November 12, 2016 4:26 PM
Toast Toast Toast I couldn't even get the pit done in a weekend. Fantastic job.
Jim  Captain
 Main WIP:
    January 2015
Posted by BrandonD on Monday, November 14, 2016 3:25 PM
Thanks, guys.
And Mike - absolutely, haha. She would actually not care at all if I took the weekend to do a build, but it just made sense to do it when she was out of town already.
-BD-
    February 2012
Posted by lawdog114 on Monday, November 14, 2016 8:54 PM
Perhaps the perfect kit for a weekend build. Errors or not (like it matters), she's stunning bro. No need to apologize for anything. Thanks for taking us along on this one.
