Yesterday's plaster was not dry enough paint so the whole work session went to the ABM. Finished the engine by repairing the errant ignition wires. Two sets were replaced with the additional Eduard parts, but I had to make two more sets from scratch using conductors scavanged from some hook up wire. Actually, I wish I would have done this for all the leads.
First step was to clip off the little plastic nubs on the ignitiion harness ring, file a little flat spot, make a *** mark with the pointy end of a divider and then drill with a #80 drill. I did break a couple of the new skinny carbide drills. The wires were CA'd into the holes and then clipped to a similar length of the Eduard PE ones. After getting all the wires in I repainted them black and repainted the copper-colored ring to Tamiya gold since you see engines with brass rings. The arrow points out the copper conductor used for the new wires
The engine needed the propellor governor and the oil sump pressure module. The instructions call for these two parts added much later in the assembly, but I wanted to make sure that they were installed correctly AND painted.
There's a little tiny pulley that attaches to the governor, and of course, it pop out of existence in this dimension from the tweezers. So I machined another one on the Taig Lathe. This was CA'd into place.
After installation I painted these two parts. I also added some rusty brown weathering powders to the exhaust collector to ton down the brown. With that, the radial was complete. In this picture, the engine was not glued to the baffle plate. I also added an alcohol/India Ink wash on the cylindes to kill some of the shine.
Before mounting the firewall, the engine needed to be glued to the baffle (and the motor mount on the other side). I painted the baffle's face Vallejo Dark Sea Blue. Before doing so, I masked the center circle where the engine will glue. Trial fittings showed interference between the exhaust outlets and the relief notches in the baffle. I used the Dremel with a small mill to remove enough material so the engine sat flat against the baffle. I used solvent cement first and clamp it together. After it set I reinforced this critical joint with thin CA.
The engine mounts:
Instructions were ambiguous as to whether they should be glued to the firewall first and then the motor mount or vice versa. I chose incorrectly. I glued all four to the firewall and attempted, unsuccessfully, to glue all eight contact points into the motor mount. There was tension of them, and I get seven pins in and #8 would pop out. I'd get #8 in and 3 and 5 would pop out and so on. As usually happens when things start going south, applying more pressure did not help and eventually two thing happened; pins broke off in the motor mount and parts were coming off the firewall.
After gluing everything back together, I airbrushed the firewall interior green.
Time for some drastic action! I realized that the mount struts should be glue firmly into the engine mount first and then the firewall. To do this I added some 0.032" brass wire and drilled the broken off stubs to receive the brass. I CA'd all four struts into the mount and when set, I solvent cemented and CA'd the firewall to the struts. This time, everything was square and intact. I had to touch up paint several areas, but it's ready for some additional Eduard details. Notice too that I added, the oil drain pipe that will get some more details before disappearing into the depths.
Here's the assembled engine and mounts.
Hopefully, tomorrow the plaster on the mountain will be able to be painted. If not, I'll be doing more ABM work.
