1/72 Dassault Ouragan (Heller)
Posted by VanceCrozier on Tuesday, November 29, 2016 7:52 AM
Just populating this thread to get the build properly logged. Big Smile
I can't NOT do the shark's teeth option...
The overall silver Frenchie version doesn't look bad either, also has that "double unit marking" on either side of the nose,
It was a steal!
Not much to the assembly.
Very sharky!
Decals.... colour still looks good, but the carrier film had yellowed some -  hung them in a window to bleach that out a little.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by VanceCrozier on Tuesday, November 29, 2016 7:55 AM
Closed canopy is the option here.
Yep, low parts count.
Taped up - no major issues.
The only spot that looks like it will have any work is the rear wing underside to lower fuselage joint.
No ordnance included here. The Israelis used these mostly as a ground-attack platform. I've got a set of unguided rockets from a late-mark Academy Spitfire. Think I'll try to modify some old drop tanks to play the part of napalm tanks, I saw a pic last night of that setup. The other option seems to be a pair of 500-pound bombs.
Tags: 1/72 , Heller , Dassault , IAF , Ouragan
Posted by VanceCrozier on Tuesday, November 29, 2016 7:58 AM
For anyone who thinks it's just an urban legend, YES, it really does work.
9-10 days of good Canadian sunlight...
Tags: decals , bleaching , sun
    May 2016
Posted by Revenant on Tuesday, November 29, 2016 8:17 AM
Confused.    So...9-10 days of Canadian sunlight would equate to how many days of Georgian sunlight?
Posted by VanceCrozier on Tuesday, November 29, 2016 8:21 AM
Revenant
Whistling about three hours. Sad
    November 2003
Posted by tempestjohnny on Tuesday, November 29, 2016 8:45 AM
I'll be watching this. Built this when I was a kid in the early 80's
Posted by VanceCrozier on Tuesday, November 29, 2016 8:59 AM
Next up, the cockpit. As the canopy will be closed I won't be going overboard with detailing here. Added some masking tape harness straps as they'll be quite visible.
Noseweights set me back a grand total of 4 cents Canadian, fit in there just right.
Attachment points sorted out for the rocket racks...
SQUIRREL!!!!
Peanuts for SQUIRREL!!! Nothing but the good stuff. I'm secretly hoping he starts wearing a monocle.
Right, where was I? Fuselage sealed up, wings assembled & attached, elevators attached. Very little putty needed topside, a little more on the underside, but to be honest I saw a lot of "If I'd done this instead of that" moments that could've reduced the putty even more.
    April 2010
Posted by Theuns on Tuesday, November 29, 2016 10:51 AM
10 days of Canadian sunlight would ba about the same a 1-2 here in South Africa in the summer LOL.
Theuns
Posted by VanceCrozier on Tuesday, November 29, 2016 10:58 AM
Theuns
Theuns
Very likely, we get lots of sun, most of it is for decoration only.  :)
Posted by VanceCrozier on Tuesday, November 29, 2016 11:00 AM
So, this brief bench session was mostly spent carefully blending & buffing the putty spots. There wasn't a whole lot to be done, but I was trying to preserve as much of the raised panel lines as I can.
Posted by VanceCrozier on Tuesday, November 29, 2016 11:02 AM
Spent a little time cleaning up the landing gear. The nose gear is probably "scale proper", but I've got a bad feeling about it not being broken. 1mm?
Annd the cockpit is still sorta-visible after being trapped between the fuselage halves. Sorta.
I found a few small pinholes in my puttied areas. Instead of more putty that would have to be applied-sanded-polished all over again, I brushed on some Future, which I had out anyway to dip the canopy in.
Posted by VanceCrozier on Tuesday, November 29, 2016 11:04 AM
Picked away at some fiddlybits. Landing gear parts, gear bay covers. ALSO in this pic is the scrap of cardboard I used to get my curve for the funky bomb pylons that this machine has. Transferred that onto sheet styrene, sanded & refined, then looked & thought they weren't thick enough, so I've laminated them to another scrap of styrene.
Primer on here now, had a superglue fingerprint that had to be cleaned up & re-primed. Propeller Everything else looked good though.
Posted by VanceCrozier on Tuesday, November 29, 2016 11:13 AM
Next steps were... 1) Tamiya primer, lots of time to cure 2) Underside painted with custom mixed enamels "silk gray", left for ? 4, 5 days to properly dry.lots of time. 3) As I always do, brush-applied Future. Immediately left hideous streaks, making me concerned it wasn't just colour-shifting, but moving paint too?? 4) left that to dry out until Saturday night. Still a little streaking visible. Gave the entire underside a spray of dullcoat to get some enamel in between the acrylic layers, let that sit for a day. 5) Next day, finish applying the Future. I've never seen that happen before? It may have only been a colour shift, and more obvious because it was on a very pale colour? I think??
Posted by VanceCrozier on Tuesday, November 29, 2016 11:15 AM
Figured I'd finish forming the bomb pylons. They still need the attachment points, but I'm happy with the size/shape now.
Not much to show, butt, any progress... y'know...
Posted by VanceCrozier on Tuesday, November 29, 2016 11:16 AM
Rockets from an Academy Spitfire. Tails added, ejector pin holes puttied. I'm thinking there should be a 2nd "connector rail" or whatever it would be called at the rear of those rockets though?
Posted by VanceCrozier on Tuesday, November 29, 2016 12:48 PM
Annnnd digging through my Tamiya acrylics, I think I can actually do some mixing & get what I'm looking for.
The blue-green mix:
The earth/brown mix:
Tags: 1/72 , Heller , IAF , Ouragan , Dassaoult
Posted by VanceCrozier on Tuesday, November 29, 2016 12:52 PM
Grabbed one of the rudder ID decals from the French option. Sample decal checked out fine.
Posted by VanceCrozier on Tuesday, November 29, 2016 12:55 PM
And paint has been slung:
2 coats of Future laid down, decals applied:
The decals were a little stiff/paper-y, but I really only had any trouble with the big toothy smile laying down on that compound curve. Not horrible, I'll get it set as well as I can with solution + Future, then carefully sand away any raised areas, touch it up with paint.
Posted by VanceCrozier on Tuesday, November 29, 2016 12:58 PM
Not happy with my attempted napalm tanks. scrapped'em, scavenged a pair of iron bombs in their place. Rockets need to be touched up as well. Sometimes I hate the zoom-ins, but it does show faults better than the old eyeball for some reason. Didn't like the original rocket colour, repainted them, touchups to the rails tonight. Bomb#1 worked fine, bomb#2, the decal stripe got all screwed up, gotta fix that.
Posted by VanceCrozier on Tuesday, November 29, 2016 1:02 PM
BEFORE
AFTER a couple rounds of hand-applied touchups using Vallejo acrylics, annnd 4 or 5 applications of Future to level things out. Not perfect, but, better.
    May 2016
Posted by Revenant on Tuesday, November 29, 2016 1:57 PM
Stick out tongue.      Hmmmmmmm...nice save on the shark mouth...
You are knocking this build out quickly...what's the deal?
Posted by VanceCrozier on Tuesday, November 29, 2016 2:50 PM
Well, the deal is, it's not a QUICK build at all, I just hadn't posted up my progress here, so I'm playing catchup. Whistling I actually started picking away at it in the summer, shelved it for several months, & just realllly got back into it a few weeks back.
    March 2015
Posted by Toshi on Tuesday, November 29, 2016 3:55 PM
Nicely done.  I am looking forward to your final reveal!  This is a very interesting build.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    May 2016
Posted by Revenant on Tuesday, November 29, 2016 4:40 PM
VanceCrozier
Censored
    August 2013
Posted by Jay Jay on Wednesday, November 30, 2016 7:20 AM
Nice job so far on this interesting aircraft. TY for taking the time to post all your progress.
    March 2012
Posted by mustang1989 on Wednesday, November 30, 2016 4:38 PM
Nice save on that decal up front Vance. Good to see you back on it.Yes
 Forum | Modelers Social Club Forum (proboards.com)
    May 2016
Posted by Revenant on Wednesday, November 30, 2016 7:09 PM
AngryAn update would be kinda nice...
Posted by VanceCrozier on Monday, December 5, 2016 11:51 AM
Revenant
lol, the update is.... COMPLETE. Err, well, complete enough for me to take final pics. I always seem to spot something after the pics, that I want to touch up. So these are my 99% pics.
Posted by VanceCrozier on Monday, December 5, 2016 11:54 AM
VC's traditional "99% pics"...
Posted by VanceCrozier on Monday, December 5, 2016 11:55 AM
