1/48 He-219 (Tamiya)
    January 2017
Posted by Redman7176 on Monday, January 30, 2017 3:08 PM
Starting up a 1/48 Tamiya He-219. The camo on this one is going to be a challenge for sure. This is a Tamiya kit, so 99% of this will be built out of the box. The only aftermarket items are canopy masks for painting, and photo etched seatbelts. I started out with the cockpit which is pre-weighted. I definitely need more experience working with the photo etched seat belts, those could be better.
I also have painted the flame dampers with a rust effect, I just learned watching a Youtube video. I airbrushed 4 shades of rust color, and thinned down a couple colors making a filter to hand paint staining in various colors. Lastly used a paint brush and tooth pick to flick create small rust specks on the surface to make more convincing. First time I have tried this, came out pretty cool it looks rusty. \m/
Cockpit
Seam removal
flame dampers
Posted by Bish on Monday, January 30, 2017 3:23 PM
Nice work, those belts look fine to me. Looking forward to how you do the camo.
    January 2009
Posted by fermis on Monday, January 30, 2017 3:39 PM
NICE! LOVE this plane!
That rust effect is awesome...would look great on some fuel drums in the background of a base!
Your belts don't look bad. Personally, I really don't like PE belts. I will use the hardware from them though, and replace the strap portions with strips of Tamiya tape. The tape is easy to twist/bend and put in a more "natural" pose. Of all the planes I have climbed into to go fly, the belts were never neatly placed as you see on models. Aside from the newer Cessnas that have a car style belt...lap belts were always on the floor and shoulder straps were always hangin off the back of the seat.
    January 2017
Posted by Redman7176 on Monday, January 30, 2017 3:50 PM
I usually I prefer a nice resin seat with seatbelts moulded in. None available that I could find for this bird. So intsead of the decal seatbelts, I opted for the photo etch belts.
Love the tip about the Tamiya tape. Thanks for that.
The camo should definitley be a challenge. Luckily they included a to scale camo layout in the instructions. I think I am going to photocopy the page, and cut out each of the spots with an Xacto, and use as paper mask to get the pattern roughed in. Then go back and adjust/ touch up as necessary. At least that the plan right now. Haha.
Posted by Bish on Monday, January 30, 2017 4:09 PM
I prefer to use fabric belts for larger scale builds, in 72nd i don't mind the PE ones to much. Hope your method for the camo turns out, i have managed to avoid it so far myself.
    January 2009
Posted by fermis on Monday, January 30, 2017 4:09 PM
I freehanded the paint jobs on both mine. If you can get a fine/small spray pattern from your a/b, I'd recommend that route, over a paper mask. You'll get a nice soft edge.
This one is 1/72
!/48 Tamiya kit...
It's tedious and hand cramping as all get out, but I think the results are completely worth it!
    February 2014
Posted by silentbob33 on Monday, January 30, 2017 4:17 PM
That looks really good so far, I would be happy with the seatbelts if I did it that nice. Your dampers look amazing though! When I built this kit, I made copies of the full-size camo pattern that came in the box and cut a mask for painting. I got mixed results, but I'm overall happy with it. If I were to do it again, I'd do it Fermis' way.
On my bench: Academy 1/35 UH-60L Black Hawk
    January 2017
Posted by Redman7176 on Monday, January 30, 2017 4:18 PM
Those look great! I definitley dont want a sharp edge.The pattern is rather intimidating.
So....fine needle with low air pressure (10-15psi) and super thinned color for the spots when freehanding? I have a basic double action Badger 150 airbrush.
Posted by Bish on Monday, January 30, 2017 4:35 PM
fermis, did you do the dark colur first or the light one.
    March 2015
Posted by Toshi on Monday, January 30, 2017 5:10 PM
Everything looks fantastic, belts inclouded!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    January 2015
Posted by BrandonD on Monday, January 30, 2017 5:17 PM
Nice airbrushing work! That came out great.
-BD-
    April 2015
Posted by Mopar Madness on Monday, January 30, 2017 5:44 PM
My thumb and forefinger and cramping up just looking at that great camouflage!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    January 2009
Posted by fermis on Monday, January 30, 2017 7:37 PM
Redman7176
As far as air p[ressure, you're in the ballpark. I don't thin my paint too much, maybe just a wee bit more than what you normally would...inevitably, at some point, a cramped hand is bound to over-do it on the trigger, leaving a nasty spot! I will dilute the paint with some dull coat...that keeps the mix a little thicker (like you'd normally use), you build up the color slowly. I don't know the ratios, I kinda make it up as I go, until I'm comfortable with it...trial-n-error on a paint mule!
I'm not familiar with the 150. I do have a 155, but I only use it for clear coats, as I can't get a super fine spray pattern out of it. I use a cheap ($20) 2x action a/b from Harbor Freight...I could paint a pin head with that thing and not get any paint on my fingers!
Bish
You know the rules!!! Lighter colors first!
On that 72nd kit...I did go back with the lighter color though, around the spots, to touch things up....I had a few "slips".
Posted by Bish on Tuesday, January 31, 2017 4:53 AM
fermis
Redman7176
Bish
Thanks. I have seen some people say they go the other way. But i was thinking the same as you and going overit with ba very thin lighter coat after wards. I have a few of the Dragon kits to do and have been putting them off for to long.
    November 2003
Posted by tempestjohnny on Tuesday, January 31, 2017 6:03 AM
Coming along great. Ive seen the parts of the one at the Udvar Hazy Center in Washington DC. Impressive plane
    January 2017
Posted by Redman7176 on Tuesday, January 31, 2017 8:49 AM
Thanks for all the feedback guys, much appreciated. Yes I hope to begin pre-shading sometime this week.
    January 2017
Posted by Redman7176 on Friday, February 3, 2017 4:24 PM
I decided to mask off and install the canopy in preparation for spraying the body color, as some of the camo goes up onto the canopy frame work. Also this protects the painted cockpit, I usually have good luck doing it this way.
However, this time I got the canopy masked off and glued down with white Elmer's glue. After getting a couple of inital light base coats sprayed onto the fuselage, I now hear something rattling around in the cockpit. My guess is the control stick came loose.
I guess my question is, have any of you guys cracked off the canopy after it has been glued down? I would like to get back in there to fix this, but don't want to make a small problem worse. Anyone have any suggestions as to a good way to get the canopy back off?
    January 2009
Posted by fermis on Friday, February 3, 2017 7:18 PM
If you've only used white glue, you should be able score it...CAREFULLY!...with a nice, sharp blade...remove the canopy...clean up around the edges should be easy enough. Better to do this before proceeding with any paint!
    February 2012
Posted by lawdog114 on Saturday, February 4, 2017 1:41 AM
Looking great....what scheme are you going with?  Here's one of mine if you need reference.
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/171152.aspx
I look forward to more...
    January 2017
Posted by Redman7176 on Saturday, February 4, 2017 9:54 AM
Thanks ill give that a shot, appreciate the tip. Yes
    January 2003
Posted by leemitcheltree on Saturday, February 4, 2017 5:09 PM
Redman....GREAT work so far!  The 'pit and the exhausts are outstanding!!
BUT.....do yourself a favor.  Save up if you need to...and get yourself a really nice super-fine airbrush for cammo patterns like this.
I bought an Iwata HP-BH with the small color cup.  this thing is WICKED!!!  Double action, with an inbuilt airflow screw - INFINITELY adjustable.  Trust me - once you use something like that, you'll wonder how you EVER painted models without one.
Keep posting pics!  It's looking fantastic!
Cheers, LeeTree
Remember, Safety Fast!!!
    January 2017
Posted by Redman7176 on Saturday, February 4, 2017 7:16 PM
Thanks for the kind words Leemitcheltree! I actually have been looking to upgrade in the airbrush department. I am going to look at that HP-BH, I have always had Iwata at the top of my list. Do you use the 0.2mm nozzle, or the 0.3mm?
Thanks for the suggestion!
    April 2010
Posted by Theuns on Sunday, February 5, 2017 4:29 AM
The cammo looks fantastic
Theuns
    January 2017
Posted by Redman7176 on Thursday, March 9, 2017 8:00 AM
Got the camo laid down. The paper mask I made was useful for getting the spots in place but it produced too hard of an edge.
I went back and re-sprayed each spot as to feather the edges. I need to go back and touch up some areas. Came out alright I guess.
    August 2013
Posted by Jay Jay on Thursday, March 9, 2017 8:49 AM
Your camo came out waaaay better than alright. Super job
    January 2009
Posted by fermis on Thursday, March 9, 2017 10:04 AM
Ditto I agree...looks great!
MOOORRRE!!!
    January 2017
Posted by Redman7176 on Thursday, March 9, 2017 4:13 PM
Thanks guys, I upgraded from my Badger 150 airbrush, to a new Iwata Eclipse HP-CS. I love it so far. Huge difference.
Here are a few pics of the paper mask I made to initially lay down the camo. It came with the kit, I made a photo copy and glued it to another sheet of paper to make it more rigid. I then cut out all the little camo spots with an Xacto. Took a couple hours total to do. Tonight I need to go back and touch up, then will be ready for a gloss coat, and panel line wash. Stick out tongue
    February 2014
Posted by silentbob33 on Thursday, March 9, 2017 4:26 PM
That's the same thing I did with mine, but you did a much better job.
Posted by Bish on Thursday, March 9, 2017 4:57 PM
Nice job on that, and thats one impessive mask.
    November 2003
Posted by tempestjohnny on Thursday, March 9, 2017 5:40 PM
Bish
Well said
